Create a network
Create a classic network
  1. On the top navigation bar, click Cloud Services, and then select Classic Networks from the Network menu.
  1. Click Create and configure network parameters.
Figure-1 Creating a classic network
  1. Click the name of the created network in the network list, and then click Create on the Subnet tab. Configure subnet parameters as needed.
Figure-2 Creating a subnet
  1. If router functions are required, create a router and connect the router to the created network. For more information, see "About classic networks".
Create a VPC
  1. On the top navigation bar, click Cloud Services, and then select VPCs from the Network menu.
  1. Click Create to create a VPC.
Figure-3 Creating a VPC
  1. From the left navigation pane, select Private Networks and then click Create to create a VPC private network.
Figure-4 Creating a VPC private network
  1. If router functions are required, create a router and connect the router to the created network. For more information, see "About VPCs."
