Configuration procedure
Figure-1 Configuration procedure
Table-1 Backup configuration procedure
Step
Verify prerequisites
Verify that the prerequisites in "Prerequisites" are met.
Connect to EISOO backup software
Connect to EISOO backup software.
Create a backup task
Define backup policies and backup sources for backup tasks.
Perform manual backup
Optional.
Back up a cloud host in real time.
Restore a cloud host
Optional.
Restore a failed cloud host or create a new cloud host from a backup file.
