On the top navigation bar, click Cloud Services, and then select Backup from the Compute menu.
Click More for a backup task and then select Restore.
Configure cloud host restoration parameters as described in Table-1, and then click OK.
Table-1 Configuring cloud host restoration parameters
Parameter |
Data Source |
Source cloud host. |
Select Restoration Location |
1. Click Not Set. 2. Configure the AZ, network, and name for the cloud host to created. 3. Click OK. |
Select Policy |
Configure whether to force the new cloud host to boot up after restoration. |
