Do not upload a renamed VDI desktop image package. If you do so, some files will remain when you delete the package from the system. |
From the left navigation pane, select Images.
Click the Desktop Images tab.
Click Import.
Select image type VDI, configure the parameters, upload the image file, and click OK.
Select Image Pool: Select the target storage path for the imported image. If no image pool is available, you can go to the image pool management page and create an image pool as described in "Create an image pool."
