Migrate a VM
VM migration changes the carriers of a VM, including computing resources and storage resources. For example, you can change the host where a VM runs, or change the storage pool that stores disks (image files) of a VM.
VM migration can includes the following migrations based on the VM state:
VM migration includes the following migrations based on the application mode of a VM:
Table-1 Networks used in VM migration
VM state
Migration method
Host
Storage
Host and Storage
Online
Migration network and management network
Management network
Offline
Management network
Management network
For more information about the management network and migration network, see "Manage virtual switches."
If you change the host and storage for a VM or change only the host for a VM, the system uses the following rules to select the networks:
Application scenarios
Configuration Workflow
After a VM is migrated, you can view its migration information. For more information about this task, see "View the migration history of a VM."
  1. From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name > VM name.
  1. Click Migrate.
  1. Select a migration type, and then configure parameters as needed.
  1. Click OK.
