This task might cause VM network anomaly. When you perform this task, make sure you are fully aware of its impacts. |
From the left navigation pane, select Data Center > Virtualization > Cluster name.
Click the vSwitches tab.
Click Edit for a virtual switch.
Edit the parameters as described in "Parameters," and then click OK.
You cannot delete a virtual switch in use.
Click Delete for a virtual switch.
Click OK.
Select a virtual switch, and then click Delete for a host in the attached host list.
