Add a VOI course
The system supports adding a VOI course by creating or importing the VOI course. You can use the system image ISO file to create a VOI course, or import an existing VOI course image file to create the course.
Create a VOI course
  1. From the left navigation pane, select Images.
  1. Click the Courses tab.
  1. Click Create.
  1. Select a VOI course type, complete other basic course settings, and then click Save & Proceed.
  1. Enter the software installation procedure, and start to "Build a VOI course."
·          Before you create a course, upload the  package and required software to the shared disk from the Images > Shared Software page.
·          On the Images > Shared Software page, you can click Create Folder to create subfolders under the default folder for saving uploaded software and files, and click Upload Files to upload files or software to the subfolders.
·          The management platform supports bulk file upload, resuming file upload, and filtering files by username or user who uploaded a file.
·          During the software installation process, you can click Finish at any time to quit software installation. To continue building the course, click the  icon for the course to open the course console.
Import a VOI course
Perform this task to import a VOI course image to Space Console. The imported VOI course image can be used directly but cannot be further developed.
  1. Click Import, select the VOI course type, upload the VOI course image, and configure relevant settings.
  1. Click Finish.
The imported course is displayed in the course list.
Creating a VOI course
Importing a VOI course
