Select nodes to deploy UIS-Sec
UIS-Sec can be deployed as VMs to a native site on the UIS cloud platform. Before deploying UIS-Sec, contact with the sales agent to obtain the component package for the UIS-Sec functionality.
You can deploy multiple UIS-Sec gateway VMs and use the gateway VMs in a cluster or in multiple clusters to achieve redundancy.
  1. On the top navigation bar, click Cloud Services.
  1. From the left navigation pane, select Deployment Guides > UIS-Sec page.
  1. Click Deploy UIS-Sec in the Step 3 tile.
  1. Click the  icon for the target native site to access the Web interface of the standard-edition UIS.
  1. On the top navigation bar, click System.
  1. From the left navigation pane, select Component Management > Component Repository.
  1. Click Upload, and then upload the UIS-Sec gateway component package.
Figure-1 Uploading a component package
  1. From the left navigation pane, select Component Management > Components.
Figure-2 Components page
  1. On the UIS-Sec Gateway Component tab, Click Deploy.
  1. Select uis_net_gw as the component type, select the component package, and select whether to enable DPDK from the Advanced Features list.
Figure-3 Deploying the UIS-Sec gateway component
  1. Click Next.
  1. Select the target hosts. You can select one or two hosts. If you select two hosts, the system considers the two hosts as a cluster.
Figure-4 Selecting the target hosts
  1. Click Next.
  1. Configure the management cluster VIP and management network IP settings. For more information about the parameters, see "Parameters."
  1. Click Finish.
After a successfully deployment, you can view the deployed UIS-Sec gateway component on the Component Management > Components page.
