Configure DPDK
To create a DPDK-enabled vSwitch, you must enable DPDK for the physical host, specify the isolation CPUs for DPDK, and specify the memory size as 2 G.
  1. On the top navigation bar, click Cloud Resources.
You are placed on the Sites > Native Sites page.
  1. Click the  icon for the target native site to access the Web interface of the standard-edition UIS.
  1. On the top navigation bar, click Hosts.
Figure-1 Hosts page
  1. From the left navigation pane, select the target host.
  1. Click the Advanced tab.
  1. Click DPDK Settings.
  1. Enable DPDK.
Figure-2 Enabling DPDK
  1. Click the Edit icon  for each NUMA node, specify the HugePage memory as 2 GB, and select the isolation CPUs specified in "Configure host boot options," and then click OK.
Figure-3 Specifying the HugePage memory and isolation CPUs
  1. Click Save.
