On the top navigation bar, click Hosts.
Figure-1 Host management page
Select the target host, and then click the Advanced tab.
Click the DPDK tab.
Enable DPDK.
Figure-2 Enabling DPDK
Click the Edit icon
for a NUMA node, set the HugePages memory size to 2GB, select the CPUs that you have selected in step 5 of "Configure boot settings," and then click OK.
Figure-3 Binding HugePages memory and CPUs
Configure the other NUMA node in the same way.
