Create vSwitch vs_gateway
When you deploy UIS-Sec gateway component VMs, the system by default uses the vSwitch named vs_gateway. Using any other vSwitch might affect services. As a best practice, create vSwitch vs_gateway before deploying UIS-Sec gateway component VMs and use this vSwitch for deployment.
UIS-Sec gateway component VMs can operate in either of the following modes:
Topics
