Create vSwitch vs_gateway with DPDK disabled
Before deploying UIS-Sec gateway component VMs on a host, create vSwitch vs_gateway for the host, and bind the vSwitch to a minimum of one available Ethernet interface on the host. As a best practice to ensure data availability, bind the vSwitch to two available Ethernet interfaces on the host.
To create vSwitch vs_gateway with DPDK disabled:
  1. On the top navigation bar, click Network.
  1. From the left navigation pane, select Advanced Network Management.
  1. Click Create Network Bridge vs_gateway.
Figure-1 vSwitches
  1. Click Add.
  1. Set the vSwitch name to vs_gateway, select Service as the network type, disable DPDK in the advanced settings, and then click Next.
Figure-2 Adding vSwitch
  1. Click Select Host to select the hosts that use the vSwitch, configure physical interfaces of the hosts, and then click Finish.
Figure-3 Selecting physical interfaces
