The security group template defines the initial rules for the default security group. By default, the default security group contains four rules, as shown in Default security group and security group template, which permit all inbound and outbound traffic. To enable organizations to have fine traffic control capabilities immediately after they are created, the cloud administrator can edit the security group template to add or delete rules.
The edited security group template takes effect on the default security group rules of newly created organizations and does not take effect on those of the existing organizations. |
Click Create.
Configure security group rule parameters as required. The peer type of a default rule supports only IP or network. For more information, see "Configure a security group rule."
Click OK.
On the top navigation bar, click Cloud O&M. From the left navigation pane, select Flavors & Templates > Security Group Template.
Select one or more rules.
