Upload an image
  1. On the top navigation bar, click Cloud Services.
  1. From the left navigation pane, select Compute & Storage > Images.
  1. On the Public or Private tab, click Create.
Only a cloud administrator can create a public image, and the image is visible to all users in the system.
A private image is visible to all users in an organization if that image is created by the organization administrator. If it is created by a cloud administrator, it is visible only to that cloud administrator.
  1. Configure the following image parameters as shown in Figure-1:
Figure-1 Configuring image parameters
  1. Select an image upload mode. Options include Upload from Local and Remote.
Figure-2 Uploading an image
  1. Click Create.
