On the top navigation bar, click Cloud Services.
From the left navigation pane, select Compute & Storage > Images.
On the Public or Private page, click Create to create a public or private image.
Table-1 Configuring image parameters
Parameter |
Operating System Version |
Select an operating system version. By default, the system provides operating system versions frequently used by CAS and VMware. If the target version cannot be found, click Cloud O&M on the top navigation bar, select Flavors & Templates > Image Types from the left navigation pane, and then click the Private tab to add a new operating system version. |
Upload Mode |
Select an upload method. If the file size is 5G or smaller, select Upload from Local. If the file size exceeds 5G, select Remote. |
For information about parameters not mentioned above, see "Upload an image." |
