Perform this task to edit or delete virtual switches on a host and view virtual interface traffic.
This task might cause VM network anomaly. When you perform this task, make sure you are fully aware of its impacts. |
From the navigation pane, select Data Center > Virtualization > Host pool name > Cluster name > Host name.
Click the vSwitches tab.
Configure Edit for the target virtual switch.
Configure virtual switch parameters as needed, and then click OK.
For information about virtual switch parameters, see "Add a virtual switch."
You cannot delete a virtual switch that is being used. |
Configure Delete for the target virtual switch.
Click OK.
