Add a virtual switch
Perform this task to add a virtual switch for the management network, service network, storage network, migration network, or backup network.
  1. From the navigation pane, select Data Center > Virtualization > Host pool name > Cluster name > Host name.
  1. Click the vSwitches tab.
  1. Click Add.
  1. Configure basic and advanced virtual switch settings as needed, and then click Next.
  1. Configure network settings, and then click OK. If you select multiple physical NICs, click Next to configure link aggregation and load sharing, and then click OK.
