Configure cluster HA
About cluster HA
Cluster HA depends on shared storage and dynamic migration technologies to provide simple and efficient HA services for applications running on all VMs in the cluster. It reduces service interruption caused by host hardware failure. Cluster HA is applicable to scenarios that require service continuity. After you enable HA for the cluster, Space Console monitors running state of all hosts and VMs in the cluster.
Cluster HA has the following features:
Application scenarios
Enable HA cluster to ensure continuity of services in case of failure and to automate maintenance in a virtualization environment.
Configure an NTP server as described in "Configure the NTP server" for heartbeat packets to carry the same time within an HA-enabled cluster.
  1. From the navigation pane, select Data Center > Virtualization > Host pool name > Cluster name.
  1. Click HA.
  1. Configure the parameters, and then click OK.
