Create a VDI image source VM
The system provides low-performance, medium-performance, and high-performance VDI image source VMs by default. Additionally, the system also allows you to select the VDI configuration customized in Flavor configuration.
  1. From the navigation pane, select Desktop Images > Desktop Images.
  1. Click the Image Source VMs tab. Click Create.
  1. On the page that opens, select image type VDI, configure the image source VM parameters, and click OK.
