00-Preface
Chapters Download (100.58 KB)
The installation guide describes preparing for installation, installing the firewall, logging in to the firewall, hardware replacement, hardware management and maintenance, and troubleshooting.
· Audience.
· Conventions.
· Network planners.
· Network administrators working with the firewall.
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
Convention |
Boldface |
Convention |
NOTE: |
Convention |
Represents an access point. |
We appreciate your comments.
