00-Preface
Chapters Download (81.49 KB)
The installation guide describes preparing for installation, installing the firewall, logging in to the firewall, hardware replacement, hardware management and maintenance, and troubleshooting.
· Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the firewall
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
NOTE: |
Convention |
Represents an access point. |
We appreciate your comments.
