00-Preface
Chapters Download (81.08 KB)
This command reference describes the commands for configuring PPP and PPPoE.
· Audience.
· Conventions.
· Network planners.
· Network administrators.
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
Convention |
Boldface |
Convention |
NOTE: |
Convention |
Represents an access point. |
We appreciate your comments.
