03-Object group commands
Chapters Download (80.70 KB)
network (IPv4 address object group view)
network (IPv6 address object group view)
service (service object group view)
Use description to configure a description for an object group.
No description is configured for an object group.
Object group view
context-admin
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as This is an IPv4 object-group for an IPv4 address object group.
[Sysname] object-group ip address ipgroup
[Sysname-obj-grp-ip-ipgroup] description This is an IPv4 object-group
Use display object-group to display information about object groups.
display object-group [ { { ip | ipv6 } address | mac-address | service | port } [ default ] [ name object-group-name ] | name object-group-name ]
context-admin
context-operator
ip address: Specifies the IPv4 address object groups.
ipv6 address: Specifies the IPv6 address object groups.
mac-address: Specifies the MAC address object groups.
service: Specifies the service object groups.
default: Specifies the default object groups.
name object-group-name: Specifies an object group by its name, a case-insensitive string of 1 to 31 characters.
# Display information about all object groups.
<Sysname> display object-group
IP address object group obj1: 0 object(in use)
IP address object group obj2: 6 objects(out of use)
0 network host address 1.1.1.1
10 network host name host
20 network subnet 1.1.1.1 255.255.255.0
30 network range 1.1.1.1 1.1.1.2
40 network group-object obj1
50 network user-group group1
IPv6 address object-group obj3: 0 object(in use)
IPv6 address object-group obj4: 5 objects(out of use)
0 network host address 1::1:1
20 network subnet 1::1:0 112
30 network range 1::1:1 1::1:2
40 network group-object obj3
Service object-group obj5: 0 object(in use)
Service object-group obj6: 6 objects(out of use)
0 service 200
10 service tcp source lt 50 destination range 30 40
20 service udp source range 30 40 destination gt 30
30 service icmp 20 20
40 service icmpv6 20 20
50 service group-object obj5
MAC object-group obj7: 0 object(in use)
MAC object-group obj8: 2 objects(out of use)
0 MAC address 0010-dc28-11ac
10 MAC group-object obj7
# Display information about object group obj2.
<Sysname> display object-group name obj2
IP address object-group obj2: 5 objects(out of use)
# Display information about all IPv4 address object groups.
<Sysname> display object-group ip address
IP address object-group obj1: 0 object(in use)
# Display information about IPv6 address object group obj4.
<Sysname> display object-group ipv6 address name obj4
in use |
The object group is used by an ACL or object group. |
out of use |
The object group is not used. |
Use mac to configure a MAC address object.
Use undo mac to delete a MAC address object.
[ object-id ] mac { mac-address | group-object object-group-name }
undo mac { mac-address | group-object object-group-name }
undo object-id
No MAC address objects exist.
MAC address object group view
context-admin
object-id: Specifies an object ID in the range of 0 to 4294967294. If you do not specify an object ID, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the system automatically assigns 30.
mac-address: Specifies a MAC address in format H-H-H.
group-object object-group-name: Specifies a MAC address object group by its name, a case-insensitive string of 1 to 31 characters.
You can execute this command multiple times to create multiple MAC address objects for a MAC address object group.
This command creates a MAC address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
When you use the group-object object-group-name option, follow these guidelines:
· The object group to be used must be a MAC address object group.
· If the specified object group does not exist, the system creates a MAC address object group with the name you specified and uses the object group for the object.
· Two object groups cannot use each other at the same time.
· The system supports a maximum of five object group hierarchy layers. For example, if groups 1, 2, 3, and 4 use groups 2, 3, 4, and 5, respectively, group 5 cannot use another group and group 1 cannot be used by another group.
# Configure a MAC address object with MAC address 0010-dc28-a4e9.
[Sysname] object-group mac-address groupmac
[Sysname-obj-mac-objectmac] mac 0010-dc28-a4e9
object-group
Use network to configure an IPv4 address object.
Use undo network to delete an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo object-id
No IPv4 address objects exist.
context-admin
host: Configures an IPv4 address object with the host address or name.
address ip-address: Specifies an IPv4 host address.
name host-name: Specifies a host name, a case-insensitive string of 1 to 60 characters.
subnet ip-address { mask-length | mask | wildcard wildcard }: Configures an IPv4 address object with the subnet address followed by a mask length in the range of 0 to 32 or a mask in dotted decimal notation. The wildcard wildcard option specifies a wildcard mask in dotted decimal notation. A wildcard mask of zeros represents a host address.
range ip-address1 ip-address2: Configures an IPv4 address object with the address range.
group-object object-group-name: Specifies an IPv4 address object group by its name, a case-insensitive string of 1 to 31 characters.
user user-name: Specifies a user by its name, a case-sensitive string of 1 to 55 characters.
user-group user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
domain domain-name: Specifies the name of a domain to which the user or the user group belongs, a case-insensitive string of 1 to 255 characters. The string cannot contain question marks (?). If you do not specify this option, the command considers that the user or the user group does not belong to any domains.
This command fails if you use it to configure or change an IPv4 address object to be identical with an existing object.
This command creates an IPv4 address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
If you configure a subnet with the mask length of 32 or the mask of 255.255.255.255, the system configures the object with a host address.
When you use the range ip-address1 ip-address2 option, follow these guidelines:
· If ip-address1 is equal to ip-address2, the system configures the object with a host address.
· If ip-address1 is not equal to ip-address2, the system compares the two IPv4 addresses, configures a range starting with the lower IPv4 address, and performs the following operations:
¡ Configures the object with an address range if the two addresses are in different subnets.
¡ Configures the object with a subnet address if the two addresses are in the same subnet.
· The object group to be used must be an IPv4 address object group.
· If the specified object group does not exist, the system creates an IPv4 address object group with the name you specified and uses the object group for the object.
# Configure an IPv4 address object with the host address of 192.168.0.1.
[Sysname-obj-grp-ip-ipgroup] network host address 192.168.0.1
# Configure an IPv4 address object with the host name of pc3.
[Sysname-obj-grp-ip-ipgroup] network host name pc3
# Configure an IPv4 address object with the IPv4 address of 192.167.0.0 and mask length of 24.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.167.0.0 24
# Configure an IPv4 address object with the IPv4 address of 192.166.0.0 and mask of 255.255.0.0.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.166.0.0 255.255.0.0
# Configure an IPv4 address object with the address range of 192.165.0.100 to 192.165.0.200.
[Sysname-obj-grp-ip-ipgroup] network range 192.165.0.100 192.165.0.200
# Configure an IPv4 address object using object group ipgroup2.
[Sysname-obj-grp-ip-ipgroup] network group-object ipgroup2
# Configure an IPv4 address object with the IPv4 address of 192.167.0.1 and wildcard mask of 0.0.255.0.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.167.0.1 wildcard 0.0.255.0
# Configure an IPv4 address object using user user1 in domain domain1.
[Sysname-obj-grp-ip-ipgroup] network user user1 domain domain1
# Configure an IPv4 address object using user group usergroup1 in domain domain1.
[Sysname-obj-grp-ip-ipgroup] network user-group usergroup1 domain domain1
Use network to configure an IPv6 address object.
Use undo network to delete an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length | range ipv6-address ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo object-id
No IPv6 address objects exist.
context-admin
object-id: Specifies an object ID in the range of 0 to 4294967294. If you do not configure an object ID, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the system automatically assigns 30.
host: Configures an IPv6 address object with the host address or name.
address ipv6-address: Specifies an IPv6 host address.
subnet ipv6-address prefix-length: Configures an IPv6 address object with the subnet address followed by the prefix length in the range of 1 to 128.
range ipv6-address1 ipv6-address2: Configures an IPv6 address object.
group-object object-group-name: Specifies an IPv6 address object group by its name, a case-insensitive string of 1 to 31 characters.
This command fails if you use it to configure or change an IPv6 address object to be identical with an existing object.
This command creates an IPv6 address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
If you configure a subnet address with the prefix length of 128, the system configures the object with a host address.
When you use the range ipv6-address1 ipv6-address2 option, follow these guidelines:
· If ipv6-address1 is equal to ipv6-address2, the system configures the object with a host address.
· If ipv6-address1 is not equal to ipv6-address2, the system compares the two IPv6 addresses, configures a range starting with the lower IPv6 address, and performs the following operations:
· The object group to be used must be an IPv6 address object group.
· If the specified object group does not exist, the system creates an IPv6 address object group with the name you specified and uses the object group for the object.
# Configure an IPv6 address object with the host address of 1::1.
[Sysname] object-group ipv6 address ipv6group
[Sysname-obj-grp-ipv6-ipv6group] network host address 1::1
# Configure an IPv6 address object with the host name of pc3.
[Sysname-obj-grp-ipv6-ipv6group] network host name pc3
# Configure an IPv6 address object with the IPv6 address of 1:1:1::1 and prefix length of 24.
[Sysname-obj-grp-ipv6-ipv6group] network subnet 1:1:1::1 24
# Configure an IPv6 address object with the address range of 1:1:1::1 to 1:1:1::100
[Sysname-obj-grp-ipv6-ipv6group] network range 1:1:1::1 1:1:1::100
# Configure an IPv6 address object using object group ipv6group2.
[Sysname-obj-grp-ipv6-ipv6group] network group-object ipv6group2
# Configure an IPv6 address object using user user1 in domain domain1.
[Sysname-obj-grp-ipv6-ipv6group] network user user1 domain domain1
# Configure an IPv6 address object using user group usergroup1 in domain domain1.
[Sysname-obj-grp-ipv6-ipv6group] network user-group usergroup1 domain domain1
Use network exclude to exclude an IPv4 or IPv6 address from an address object.
Use undo network exclude to restore the default.
object-id network exclude ip-address
undo object-id network exclude ip-address
No IPv4 or IPv6 address in an address object is excluded.
context-admin
object-id: Specifies an address object by its ID in the range of 1 to 4294967294. The specified address object must have been created.
ip-address: Specifies the IPv4 or IPv6 address to be excluded.
You can execute this command multiple times to exclude multiple IPv4 or IPv6 addresses from an address object.
# Configure an IPv4 address object with the IPv4 address of 192.166.0.0 and mask of 255.255.0.0, and exclude IPv4 address 192.166.0.10 from the address object.
[Sysname-obj-grp-ip-ipgroup] 10 network subnet 192.166.0.0 255.255.0.0
[Sysname-obj-grp-ip-ipgroup] 10 network exclude 192.166.0.10
# Configure an IPv6 address object with the IPv6 address of 1:1:1::1 and prefix length of 24, and exclude IPv6 address 1:1:1::10 from the address object.
[Sysname-obj-grp-ipv6-ipv6group] 10 network subnet 1:1:1::1 24
[Sysname-obj-grp-ipv6-ipv6group] 10 network exclude 1:1:1::10
Use object-group to create an object group and enter its view, or enter the view of an existing object group.
Use undo object-group to delete an object group.
object-group { { ip | ipv6 } address | mac-address | port | service } object-group-name
undo object-group { { ip | ipv6 } address | mac-address | port | service } object-group-name
Default object groups exist.
context-admin
ip address: Creates an IPv4 address object group.
ipv6 address: Creates an IPv6 address object group.
mac-address: Creates a MAC object group.
service: Creates a service object group.
object-group-name: Specifies an object group name, a case-insensitive string of 1 to 31 characters. The object group name must be globally unique.
The object-group command execution results vary with the specified object group.
· If the specified group does not exist, the system creates a new object group and enters the object group view.
· If the specified group exists but the group type is different from that in the command, the command fails.
The undo object-group command execution results vary with the specified object group.
· If the specified group does not exist, the system executes the command without any system prompt.
· If the specified group exists and the group type is the same as that in the command, the system deletes the group.
· If the specified object group is being used by an ACL, object policy, or another object group, the command fails.
Default object groups cannot be deleted.
# Create an IPv4 address object group named ipgroup.
# Create an IPv6 address object group named ipv6group.
# Create a MAC object group named groupmac.
# Create a service object group named servicegroup.
[Sysname] object-group service servicegroup
Use object-group rename to rename an object group.
object-group rename old-object-group-name new-object-group-name
context-admin
old-object-group-name: Specifies the name of the object group to be renamed, a case-insensitive string of 1 to 31 characters.
new-object-group-name: Specifies a new name for the object group, a case-insensitive string of 1 to 31 characters. The object group name must be globally unique.
You can only rename non-default object groups.
# Rename object group ipgroup1 to ipgroup2.
[Sysname] object-group rename ipgroup1 ipgroup2
object-group
Use security-zone to specify a security zone for an IP address object group.
Use undo security-zone to restore the default.
security-zone security-zone-name
undo security-zone
No security zone is specified for an IP address object group.
context-admin
security-zone-name: Specifies the security zone name, a case-insensitive string of 1 to 31 characters. The string cannot contain hyphens (-) or percent signs (%) and cannot be any.
This feature enables fast selection of IP address object groups when you specify IP address filtering criteria for a security policy from the Web interface. If a security policy uses an IP address object group specified with a security zone, you can specify only IP address object groups from the same security zone or that do not belong to any security zone.
You can specify only one security zone for an IP address object group. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the security zone for IPv4 address object group 1 as Local.
[Sysname] object-group ip address 1
[Sysname-obj-grp-ip-1] security-zone Local
object-group
Use service to configure a service object.
Use undo service to delete a service object.
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
undo service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
undo object-id
No service objects exist.
Service object group view
context-admin
object-id: Configures an object ID in the range of 0 to 4294967294. If you do not configure an ID for the object, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the automatically assigned ID is 30.
protocol: Configures the protocol number in the range of 0 to 255, or the protocol name such as TCP, UDP, ICMP, and ICMPv6.
source: Configures a service object with a source port when the protocol is TCP or UDP.
destination: Configures a service object with a destination port when the protocol is TCP or UDP.
eq: Configures a port equal to the specified port.
lt: Configures a port smaller than the specified port.
gt: Configures a port greater than the specified port.
port: Specifies a port number in the range of 0 to 65535.
range port1 port2: Configures a service object with a port range. The value range for the port1 and port2 arguments is 0 to 65535.
icmp-type: Configures the ICMP message type in the range of 0 to 255.
icmp-code: Configures the ICMP message code in the range of 0 to 255.
icmpv6-type: Configures the ICMPv6 message type in the range of 0 to 255.
icmpv6-code: Configures the ICMPv6 message code in the range of 0 to 255.
group-object object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 31 characters.
This command fails if you use it to configure or change a service object to be identical with an existing object.
This command creates a service object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
When you use the lt port option, follow these guidelines:
· The value of port cannot be 0.
· If the value of port is 1, the system configures the object with a port number of 0.
· If the value of port is in the range of 2 to 65535, the system configures the object with a port number range of [0, port–1].
When you use the gt port option, follow these guidelines:
· The value of port cannot be 65535.
· If the value of port is 65534, the system configures the object with a port number of 65535.
· If the value of port is in the range of 0 to 65533, the system configures the object with a port number range of [port+1, 65535].
When you use the range port1 port2 option, follow these guidelines:
· If port1 is equal to port2, the system configures the object with the port number port1.
· If port1 is smaller than port2, the system configures the object with the port number range.
· If port1 is greater than port2, the system changes the range to [port2, port1] and configures the object with the changed port number range.
· If port1 is 0, the range is displayed as lt port2+1.
· If port2 is 65535, the range is displayed as gt port1–1.
When use the group-object object-group-name option, follow these guidelines:
· The object group to be used must be a service object group.
· If the specified object group does not exist, the system creates a service object group with the name you specified and uses the object group for the object.
# Configure a service object with a protocol number of 100.
[Sysname-obj-grp-service-servicegroup] service 100
# Configure a service object with the source and destination port numbers for the TCP service.
[Sysname-obj-grp-service-servicegroup] service tcp source eq 100 destination range 10 100
# Configure a service object with the message type and code for the ICMP service.
[Sysname-obj-grp-service-servicegroup] service icmp 100 150
# Configure a service object using object group servicegroup2.
[Sysname-obj-grp-service-servicegroup] service group-object servicegroup2
