H3C LA2608 Indoor Wireless Gateway Compliance and Safety Manual-6W103
01-Text
Chapters Download  (1.14 MB)
01-Text
Safety Information/Sicherheits informationen/安全信息··· 1
Overview/Überblick/概述·· 1
Warning Symbol Conventions/ Erläuterung der Symbole/应用惯例·· 1
Important Safety Information/Wichtige Sicherheitshinweise/重要安全信息·· 2
Electricity Safety/Elektrische Sicherheit/用电安全·· 5
Hazardous Voltage/Gefährliche Spannungen /危险电压·· 5
Regulatory Compliance Information· 6
Regulatory compliance standards· 6
European Directives compliance· 7
Wireless CE Marking· 7
EU Country Restriction in 2.4GHz band· 9
USA regulatory compliance· 9
FCC Part 15· 9
FDA· 10
Canada regulatory compliance· 10
ICES-003· 10
RF Compliance· 11
Japan regulatory compliance· 12
VCCI 12
MII 12
EN55022, AS/NZS CISPR 22, CISPR22 compliance· 12
EN55032, AS/NZS CISPR 32, CISPR32 compliance· 12
Environmental notices· 13
Waste Electrical and Electronic Equipment (WEEE) statements· 13
English recycling notice· 13
Bulgarian recycling notice· 13
Czech recycling notice· 14
Danish recycling notice· 14
Dutch recycling notice· 14
Estonian recycling notice· 15
Finnish recycling notice· 15
French recycling notice· 15
German recycling notice· 16
Greek recycling notice· 16
Hungarian recycling notice· 16
Italian recycling notice· 17
Latvian recycling notice· 17
Lithuanian recycling notice· 17
Polish recycling notice· 18
Portuguese recycling notice· 18
Romanian recycling notice· 18
Slovak recycling notice· 19
Spanish recycling notice· 19
Swedish recycling notice· 19
RoHS material content declarations· 20
Turkey RoHS material content declaration· 20
Ukraine RoHS material content declaration· 20
India RoHS material content declaration· 20
Perchlorate material — Special handling may apply· 20
Note
Note
Before any operation is performed, please read the operation instructions and precautions carefully to minimize the possibility of accidents. The Note, Caution, Warning and Danger items in other manuals do not cover all safety precautions that should be followed. They are only the supplements to the safety precautions for operations as a whole.
When installing / operating the product, the precautions and special safety instructions provided with the products must be followed in full.
Note
Anmerkung
Lesen Sie sich vor der Inbetriebnahme die Betriebsanleitung und die Hinweise zu Vorsichtsmaßnahmen sorgfältig durch, um die Wahrscheinlichkeit von Unfällen zu minimieren. Die unter Hinweis, Achtung, Warnung und Gefahr genannten Informationen in anderen Handbüchern umfassen nicht sämtliche Sicherheitsmaßnahmen, die Sie ergreifen sollten.
Note
为了避免可能发生的事故,请在进行任何操作前,仔细阅读设备安装手册和本章节的安全规范。手册中 出现的说明、注意、警告、危险,不能涵盖所有的安全预防,仅仅是在整个操作过程中的安全提示和补充。
在操作本设备时,请认真执行产品手册规定的安全规范。
The symbols in this manual are shown in the following table. They are used to remind the reader of the safety precautions during equipment installation and maintenance.
Die in diesem Handbuch verwendeten Symbole sind in der folgenden Tabelle dargestellt. Diese Symbole sollen das Personal während der Installation und Instandhaltung der Ausrüstung an die Wichtigkeit der im Handbuch aufgeführten Sicherheitsvorschriften erinnern.
以下表格中的安全标识,是用来提示读者在进行设备安装和维护时的安全预防要求。
Table 1  Safety symbol and description/Sicherheitssymbole und Beschreibung/安全标识和描述
Safety Symbol
Symbole
安全标识
Erläuterung
Generic alarm symbol: To suggest a general safety concern.
Alarm: Hinweis auf ein generelles Sicherheitsproblem.
一般注意标识:用于一般安全提示。
ESD protection symbol: To suggest electrostatic-sensitive equipment.
ESD-Schutz: Hinweis auf ESD-gefährdete Bauteile.
防静电标识:用于表示设备对静电敏感。
Electric shock symbol: To suggest a danger of hazardous Voltage.
Elektrischer Schlag: Zeigt Gefährdungen durch gefährliche Spannungen an.
电击防护标识:用于表示高压危险。
Caution: You must read all of the installation instructions in the Installation Guide supplied with your equipment and the following safety instructions before installation or operation.
Achtung: Sie müssen vor der Installation oder Bedienung das mit Ihrer Anlage mitgelieferten Installationshandbuch und die folgende Sicherheitshinweise lesen.
注意:在安装和操作本设备时,务必阅读设备安装手册的内容,以及下文的所有安全说明。
Caution: Do not block ventilation openings while the system is on, and keep at least 10 cm distance from ventilation openings and walls or other things which may block the openings.
Achtung: Blockieren Sie die Lüftungsmündungen nicht, wenn das System läuft. Stellen Sie die Lüftungsmündungen mindestens 10 cm entfernt von den Wänden oder anderen Sachen, die die Mündungen blockieren können.
注意:设备在工作时必须确保通风口的畅通,确保设备离墙壁或是其它的可能堵塞通风口的物体的间距至少10cm
Warning: The separate earthing terminal must be permanently connected to earth.
Warnung:  Die separate Erdungsschiene muss dauerhaft geerdet sein.
警告:单独的接地端子必须永久连接到地。
Caution: The protective earthing / grounding conductor packaged with this product should be appropriately modified by a qualified electrician to lengths where required by local regulations. The conductor should be cut to length, and terminated with a suitably certified connector. Note that for rack mounted equipment the conductor must be terminated within the rack enclosure grounding system. The supplemental grounding cable must be maintained within the rack system at all times.
Achtung: Der im Lieferumfang dieses Produkts enthaltene Schutzleiter/Erdungsleiter muss von einem qualifizierten Elektriker auf die entsprechende Länge gekürzt werden, sofern von lokalen Bestimmungen und Richtlinien verlangt. Der Schutzleiter sollte auf die korrekte Länge zugeschnitten und mit einem geeigneten zertifizierten Anschluss terminiert werden. Beachten Sie, dass bei Rack montierten Geräten die Leiter innerhalb des Erdungssystems des Rackgehäuses mit einem Abschlusswiderstand versehen werden müssen. Das zusätzliche Erdungskabel muss innerhalb des Rack-Systems stets instandgehalten werden.
注意:包装在本产品中的保护接地导体必须由合格的电工按照当地法规要求对长度进行适当的修改。该导体需要被切到适当的长度,并端接在一个通过认证的适当的连接器上。请注意,安装在机架上的设备,其保护接地导体必须端接在机架外壳的接地系统内。辅助接地电缆必须一直保持在机架系统内。
Warning: When installing the unit, always make the ground connection first and disconnect it last. Never defeat the ground conductor or operate the equipment in the absence of a suitably installed ground conductor. Check installation before operation.
Warnung: Beachten Sie, dass bei der Installation des Systems stets zuerst die Erdverbindung angebracht wird und die Erdverbindung stets als letztes getrennt wird. Betreiben Sie die Ausrüstung niemals ohne eine passende, installierte Erdung. Trennen Sie das System nicht von der Erdung. Überprüfen Sie die Erdung vor der Inbetriebnahme.
警告:进行设备安装时,必须确保接地连接是最先连接和最后断开。不允许破坏设备的接地导线或是在无接地连接的情况下操作设备,操作前要进行检查。
Warning: Before an ac power cable is either plugged in to or removed from a unit, the ac power source supplying this cable must be switched off.
Warnung: Bevor ein Wechselstromnetzkabel entweder an eine Einheit angeschlossen oder von dieser abgezogen wird, muss die Wechselstromquelle, die dieses Kabel speist, ausgeschaltet werden.
警告:在安装、移动电源线之前,请切断电源。
Warning: To reduce the risk of fire, use only No. 26 AWG or larger telecommunication line cord.
Warnung: Um die Brandgefahr zu minimieren dürfen ausschließlich Nr. 26 AWG oder Telekommunikationskabel mit größerem Drahtdurchmesser verwendet werden.
警告:为了降低发生火灾的危险,请使用NO.26 AWG或更粗的通信线缆。
Warning: No operation can be done on the device and cables during a thunder storm.
Warnung: Wenn die Gefahr eines Blitzeinschlages besteht, darf weder an der Vorrichtung noch an den Kabeln gearbeitet werden.
警告:雷雨风暴期间不要操作设备或者电缆。
Warning: To avoid electric shock, do not connect safety extra-low voltage (SELV) circuits to telephone network voltage (TNV) circuits
Warnung: Um den elektrischen Schlag zu vermeiden, schließen Sie den Kreis von Schutzkleinspannung(SELV) nicht an den Kreis von Telefonnetzspannung(TNV) an.
警告:为了防止电击危险,不要把安全特低电压电路(SELV)连接到通信网络电压电路(TNV)上。
Caution: To ensure the equipment is mounted on the wall firmly,  please use a screw at least 0.3 mm diameter and the screw head at least 0.65 mm diameter.
Achtung: Um das Gerät an der Wand zu befestigen, benutzen Sie Nagel mit einem Mindestdurchmesser von 0.3 mm. Der Durchmesser der Nagelkappe muss mindestens 0.65 mm betragen.
注意为确保设备紧固的安装在墙上请用直径最小是0.3mm螺钉并且螺帽的直径要大于0.65mm
Warning: When installing the product on the wall you must choose a suitable fixing.
Achtung: Wenn Sie das Produkt an der Wand anbringen, müssen Sie eine passende Befestigungslösung wählen.
警告:将设备安装到墙上时,必须选取合适的固定方式。
Warning: When mounting the product on a wall, do not mount it with ventilation holes facing up or down.
Warnung: Wenn das Produkt an einer Wand montiert wird, installieren Sie ihn nicht mit den Lüftungsöffnungen nach oben oder unten gerichtet.
警告:将设备安装到墙上时,请勿将散热孔朝上或朝下。
Warning: When making connections, be careful not to push the product up and off the wall.
Warnung: Achten Sie darauf, das Produkt nicht nach oben und von der Wand zu schieben, wenn Sie die Anschlüsse vornehmen.
警告:进行连接时,请不要向上推动设备,以免设备从墙上掉落。
Warning: The unit must be permanently connected to the protective ground before operation. The cross-sectional area of the protective earthing / grounding conductor shall be at least 0.75 mm2 or 18 AWG.
Warnung: Diese Anlage muss vor der Inbetriebnahme ständig an den Schutzleiter angeschlossen werden. Die Querschnittsfläche des Schutzerdungsleiters soll mindestens 0.75 mm2 oder 18 AWG betragen.
警告:进行设备操作前,请确保设备永久接地,并且确保接地线截面不小于0.75 mm2 18 AWG
Warning Power Cord Table:
The power cord set must be approved for the country where it is used.
WARNUNG Netzkabel Tabelle:
Das Netzkabel muss für das Land, in dem es verwendet wird, zugelassen werden.
警告:电源线表格:
电源线组件必须满足使用的国家认证要求。
U.S.A. and Canada
·     The cord set must be UL approved and CSA certified
·     The minimum specification for the flexible cord is:
·     No. 18 AWG
·     Type SPT-2
·     2 conductor.
·     The cord set must have a rated current carrying capacity of at least 2.5A.
·     The attachment plug must be an earth-grounding type with a NEMA 1-15 (15A, 125V) configuration
United Kingdom
·     The supply plug must comply with BS1363 (3-pin, 13A) and be fitted with a 5A fuse that complies with BS1362
·     The mains cord must <HAR> or <BASEC> marked and be of type H03VVH2F2X0.75 (minimum).
Europe
·     The supply plug must comply with CEE 7/16 (“SCHUKO”)
Denmark
Switzerland
·     The supply plug must comply with SEV/ASE 1011
Argentina
(for 2 pins)
·     The power cord set must be certified by UL, IRAM, TÜV(or other authorized certification body), for two conductors cables.
·     The attachment plug must be a non-grounding type with an IRAM-2063 (10 A, 250 V) configuration
中国
·     电源线组件必须通过CCC认证。
·     使用符合GB1002,额定值为250V/10A的单相两级插头
·     电源线最小线径为0.75mm2
The appliance coupler (the connector to the unit and not the connector to the wall plug) must have a configuration for mating with an EN 60320 / IEC 320 C8 appliance inlet.
Die Gerätesteckvorrichtung (der Anschluss an die Anlage, nicht an den Wandstecker) muss mit einer Konfiguration nach EN 60320 / IEC 320 C8 versehen.
Caution: Fiber optic ports – optical safety
Achtung : Glasfaseranschlüsse – optische Sicherheit
注意:光纤接口 - 光口安全
Never look at the transmit laser while the power is on. Never look directly at the fiber ports and the fiber cable ends when they are powered on.
Schauen Sie niemals in den Laserstrahl, wenn die Einheit eingeschaltet ist. Schauen Sie niemals direkt in die Glasfaseranschlüsse und die Enden des Glasfaserkabels, wenn diese eingeschaltet sind.
当设备工作时,请不要直视光接口和光纤接头。
Caution: Use of controls or adjustments of the performance or procedures other than those specified herein may result in hazardous laser emissions.
Achtung : Werden Steuerelemente, Leistungseinstellungen oder Prozeduren anders als hier angegeben verwendet, kann gefährliche Laserstrahlung auftreten.
注意:不遵守本手册规定而任意改动光模块的功能或性能可能导致激光辐射的危险。
·     Conducting articles, such as a watch, hand chain, bracelet or ring should be removed during the installation.
·     Es ist nicht erlaubt während dieser Arbeiten leitende Gegenstände wie Uhren, Armbänder, Armreifen und Ringe am Körper zu tragen.
·     在操作中不能穿戴导电性的物品,如:手表,手琏,手镯和项链等。
·     Do not use this product near water.
·     Verwenden Sie dieses Produkt nicht in der Nähe von Wasser.
·     请勿在靠近水的地方使用此产品。
Table 2 Regulatory compliance standards
Discipline
Standards
EMC
FCC Part 15 (CFR 47) CLASS B
ICES-003 CLASS B
VCCI CLASS B
CISPR 22 CLASS B
EN 55022 CLASS B
AS/NZS CISPR22 CLASS B
CISPR 32 CLASS B
EN 55032 CLASS B
AS/NZS CISPR32 CLASS B
CISPR 24
EN 55024
EN 61000-3-2
EN 61000-3-3
ETSI EN 300 386
EN 301 489-1
EN 301 489-17
EN 301 489-7
EN 301 489-24
GB 9254
GB 17625.1
YD/T 993
Safety
UL 60950-1
CAN/CSA C22.2 No 60950-1
IEC 60950-1
EN 60950-1
AS/NZS 60950-1
FDA 21 CFR  Subchapter J
GB 4943.1
RF
FCC Bulletin OET-65C
FCC part15 subpart C/E
FCC part22
FCC part24
RSS-210
RSS-GEN
RSS-132
RSS-133
EN 300 328
EN 301 893
EN 301 511
EN 301 908-1
EN 301 908-2
EN 50385
EN 62311
These products comply with the European Radio & Telecommunication Terminal Equipment Directive 1999/5/EC (until 12th June 2016) and the RoHS Directive 2011/65/EU. From 13th June 2016 these products comply with the Low Voltage Directive 2014/35/EU, the EMC Directive 2014/30/EU and the RoHS Directive 2011/65/EU.
The most up to date copy of the signed EU Declaration of Conformity can be downloaded from:
http://www.h3c.com.hk/Technical_Documents
http://www.h3c.com/cn/Technical_Documents
Wireless CE Marking
Table 3 Equipment may be operated in the following country:
AT
BE
CY
CZ
DK
EE
FI
FR
DE
GR
HU
IE
IT
LV
LT
LU
MT
NL
PL
PT
SK
SI
ES
SE
GB
IS
LI
NO
CH
BG
RO
TR
HR
1.     Select the country in which this product is installed to ensure product operation is in compliance with local regulations. For information on how to select the country, refer to theH3C A-Series Access Controllers WLAN Command Reference”.
2.     Intended use: IEEE 802.11 b/g/n radio LAN device.
3.     These products/this product must maintain a minimum distance of 20cm from body to antenna.Under these conditions These products will meet the Basic Restriction limits of 1999/519/EC(Council Recommendation of 12 July 1999 on the limitation of exposure of the general public to electromagnetic fields(0Hz-300GHz)).
R&TTE declaration statements:
Česky [Czech]
H3C Technologies Co., Limited tímto prohlašuje, že tento Zařízení je ve shodě se základními požadavky a dalšími příslušnými ustanoveními směrnice 1999/5/ES.
Dansk [Danish]
Undertegnede H3C Technologies Co., Limited erklærer herved, at følgende udstyr zařízení overholder de væsentlige krav og øvrige relevante krav i direktiv 1999/5/EF.
Deutsch [German]
Hiermit erklärt H3C Technologies Co., Limited, dass sich das Gerät Ausrüstung in Übereinstimmung mit den grundlegenden Anforderungen und den übrigen einschlägigen Bestimmungen der Richtlinie 1999/5/EG befindet.
Eesti [Estonian]
Käesolevaga kinnitab H3C Technologies Co., Limited seadmed vastavust direktiivi 1999/5/EÜ põhinõuetele ja nimetatud direktiivist tulenevatele teistele asjakohastele sätetele.
English
Hereby, H3C Technologies Co., Limited, declares that this Equipment is in compliance with the essential requirements and other relevant provisions of Directive 1999/5/EC.
Español [Spanish]
Por medio de la presente H3C Technologies Co., Limited declara que el equipo cumple con los requisitos esenciales y cualesquiera otras disposiciones aplicables o exigibles de la Directiva 1999/5/CE.
Ελληνική [Greek]
ΜΕ ΤΗΝ ΠΑΡΟΥΣΑ H3C Technologies Co., Limited ΔΗΛΩΝΕΙ ΟΤΙ εξοπλισμός ΣΥΜΜΟΡΦΩΝΕΤΑΙ ΠΡΟΣ ΤΙΣ ΟΥΣΙΩΔΕΙΣ ΑΠΑΙΤΗΣΕΙΣ ΚΑΙ ΤΙΣ ΛΟΙΠΕΣ ΣΧΕΤΙΚΕΣ ΔΙΑΤΑΞΕΙΣ ΤΗΣ ΟΔΗΓΙΑΣ 1999/5/ΕΚ.
Français [French]
Par la présente H3C Technologies Co., Limited déclare que l'appareil équipement est conforme aux exigences essentielles et aux autres dispositions pertinentes de la directive 1999/5/CE.
Italiano [Italian]
Con la presente H3C Technologies Co., Limited dichiara che questo attrezzatura è conforme ai requisiti essenziali ed alle altre disposizioni pertinenti stabilite dalla direttiva 1999/5/CE.
Latviski [Latvian]
Ar šo H3C Technologies Co., Limited deklarē, ka iekārta atbilst Direktīvas 1999/5/EK būtiskajām prasībām un citiem ar to saistītajiem noteikumiem.
Lietuvių [Lithuanian]
Šiuo H3C Technologies Co., Limited deklaruoja, kad šis įranga atitinka esminius reikalavimus ir kitas 1999/5/EB Direktyvos nuostatas.
Nederlands [Dutch]
Hierbij verklaart H3C Technologies Co., Limited dat het toestel uitrusting in overeenstemming is met de essentiële eisen en de andere relevante bepalingen van richtlijn 1999/5/EG.
Malti [Maltese]
Hawnhekk, H3C Technologies Co., Limited, jiddikjara li dan tagħmir  jikkonforma mal-ħtiġijiet essenzjali u ma provvedimenti oħrajn relevanti li hemm fid-Dirrettiva 1999/5/EC.
Magyar [Hungarian]
Alulírott, H3C Technologies Co., Limited nyilatkozom, hogy a aprīkojums megfelel a vonatkozó alapvetõ követelményeknek és az 1999/5/EC irányelv egyéb elõírásainak.
Polski [Polish]
Niniejszym H3C Technologies Co., Limited oświadcza, że urządzenie jest zgodny z zasadniczymi wymogami oraz pozostałymi stosownymi postanowieniami Dyrektywy 1999/5/EC.
Português [Portuguese]
H3C Technologies Co., Limited declara que este equipamento está conforme com os requisitos essenciais e outras disposições da Directiva 1999/5/CE.
Slovensko [Slovenian]
H3C Technologies Co., Limited izjavlja, da je ta oprema v skladu z bistvenimi zahtevami in ostalimi relevantnimi določili direktive 1999/5/ES.
Slovensky [Slovak]
H3C Technologies Co., Limited týmto vyhlasuje, že zariadenie spĺňa základné požiadavky a všetky príslušné ustanovenia Smernice 1999/5/ES.
Suomi [Finnish]
H3C Technologies Co., Limited vakuuttaa täten että laitteet tyyppinen laite on direktiivin 1999/5/EY oleellisten vaatimusten ja sitä koskevien direktiivin muiden ehtojen mukainen.
Svenska [Swedish]
Härmed intygar H3C Technologies Co., Limited att denna utrustning står I överensstämmelse med de väsentliga egenskapskrav och övriga relevanta bestämmelser som framgår av direktiv 1999/5/EG.
Íslenska [Icelandic]
Hér með lýsir H3C Technologies Co., Limited yfir því að búnaður er í samræmi við grunnkröfur og aðrar kröfur, sem gerðar eru í tilskipun 1999/5/EC.
Norsk [Norwegian]
H3C Technologies Co., Limited erklærer herved at utstyret utstyr er i samsvar med de grunnleggende krav og øvrige relevante krav i direktiv 1999/5/EF.
Hrvatska [Croatian]
Ovime tvrtka H3C Technologies Co., Limited izjavljuje da je ova oprema usklađena s osnovnim preduvjetima i drugim važnim odredbama direktive 1999/5/EZ.
These products may be used indoors or outdoors in all countries of the European Community using the 2.4GHz band: Channel 1-13, except where noted below.
1.     In Italy the end-user must apply for a license from the national spectrum authority to operate this device outdoors.
FCC Part 15
US Federal Communications Commission (FCC) EMC Compliance
These products have been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not  occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can  be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
·     Reorient or relocate the receiving antenna.
·     Increase the separation between the equipment and receiver.
·     Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
·     Consult the dealer or an experienced radio/ TV technician for help.
These products comply with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
1.     This device may not cause harmful interference.
2.     This device must accept any interference received, including interference that may cause undesired operation.
If the customer modifies the equipment without the authorization of H3C, which directly or indirectly contribute to the equipment incompliance with FCC requirements for Class B digital devices, H3C is not liable for such interference problem and the expenses incurred there from shall be covered by the customers.
RF Requirements
1.     RF exposure Hazard Warning
This device generates and radiates radio-frequency energy. To ensure compliance with the requirements of FCC radio-frequency exposure, a minimum body to antenna distance of 20cm (8 inch) must be maintained when the device is installed and operated.
This device generates and radiates radio-frequency energy. In order to comply with FCC radio frequency radiation exposure compliance requirements, a separation distance of at least 2.5 cm (1.0 inch) must be maintained between the antenna of the device and all persons.
2.     RF Frequency Requirements
This equipment complies with FCC RF radiation exposure limits set forth for an uncontrolled environment. This device and its antenna must not be co-located or operating in conjunction with any other antenna or transmitter.
This device is for indoor use only when it is operated at 5.15 to 5.25GHz frequency range.
High power radars are allocated as primary users of the 5.25 to 5.35GHz and 5.65 to 5.85GHz bands. These radar stations can cause interference with and /or damage this device.
Antennas
Only use the supplied antenna. Unauthorized antennas, modifications or change to the antennas could violate FCC regulations and void the user’s authority to operate the equipment.
FDA
These products conform to the applicable requirements of 21 CFR Subchapter J.
ICES-003
This Class B digital apparatus complies with Canadian Standard  ICES-003.
Cet appareil numérique de la class B est conforme à la norme NMB-003 du Canada.
RF Compliance
These products comply with RSS-210 of Industry Canada.
Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of this device.
L ‘ utilisation de ce dispositif est autorisée seulement aux conditions suivantes: (1) il ne doit pas produire de brouillage et (2) l’ utilisateur du dispositif doit étre prêt à accepter tout brouillage radioélectrique reçu, même si ce brouillage est susceptible de compromettre le fonctionnement du dispositif.
The term "IC" before the equipment certification number only signifies that the Industry Canada technical specifications were met.
To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (EIRP) is not more than that required for successful communication. To prevent radio interference to the licensed service, this device is intended to be operated indoors and away from windows to provide maximum shielding. Equipment (or its transmit antenna) that is installed outdoors is subject to licensing.
Pour empecher que cet appareil cause du brouillage au service faisant l'objet d'une licence, il doit etre utilize a l'interieur et devrait etre place loin des fenetres afin de Fournier un ecram de blindage maximal. Si le matriel (ou son antenne d'emission) est installe a l'exterieur, il doit faire l'objet d'une licence.
This device must not be co-located or operated in conjunction with any other unauthorized antenna or transmitter.
Radiation Exposure Statement:
This equipment complies with IC RSS-102 with radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance 20cm between the radiator & your body.
Déclaration d'exposition aux radiations:Cet équipement est conforme aux limites d'exposition aux rayonnements IC établies pour un environnement non contrôlé. Cet équipement doit être installé et utilisé avec un minimum de 20 cm de distance entre la source de rayonnement et votre corps.
Table 4 Frequency band and channels in Canada and USA
Allowed Frequency Bands and Channel Numbers – 2.4GHz
Allowed Frequency Bands and Channel Numbers – 5GHz
Restriction
11bg & 11n HT20 : 2412~2462MHz (ch1-11)
11n HT40
2422~2452MHz (ch3-9)
11a & 11n &11ac
HT20&VHT20:
5180~5320 MHz, 5500~5700MHz(*), 5745~5825MHz
Ch #s : 36,40,44,48,52,56,60,64,100,104,108,112,116 ,132,136,140, 149, 153, 157, 161,165
HT40& VHT40:
5190~5310MHz, 5510~5670 MHz(*), 5755~5795MHz
Ch#s :38,46,54,62, 102,110, 134, 151, 159
VHT80:
5210~5290MHz, 5530MHz, 5775MHz
Ch#s :42, 58, 106, 155
5GHz DFS required bands :
5250~5350MHz; 5470~5725MHz
This device is Indoor use only in Canada when operating in below frequency bands:
5150~5250MHz
Note: (*). No operation in band 5600-5650MHz in USA and Canada
VCCI
These products comply with the requirements of VCCI Class B Information Technology Equipment (ITE).
Warning
This is a Class B equipment. Although this equipment is intended for use in a residential
environment, it could cause poor reception if used near a radio or a television receiver. Please
follow instructions in the instruction manual. VCCI-B
この装置は、クラスB機器です。この装置は、住宅環境で使用することを目的としていますが、この装置がラジオやテレビジョン受信機に近接して使用されると、受信障害を引き起こすことがあります。取扱説明書に従って正しい取り扱いをして下さい。 VCCI-B
MII
This product complies with the ARIB requirements in the W52, W53 and W56 2.4GHz frequency bands. This product is indoor use only.
These products complies/comply with the requirements of EN55022, AS/NZS CISPR 22, CISPR22 for Class B Information Technology Equipment (ITE).
These products comply with the requirements of EN55032, AS/NZS CISPR 32, CISPR 32 for Class B Information Technology Equipment (ITE).
H3C is committed to providing our customers with information about the chemical substances in our products as needed to comply with legal requirements such as REACH (Regulation EC No 1907/2006 of the European Parliament and the Council).
Türkiye Cumhuriyeti: EEE Yönetmeliğine Uygundur
Обладнання відповідає вимогам Технічного регламенту щодо обмеження використання деяких
небезпечних речовин в електричному та електронному обладнанні, затвердженого постановою
Кабінету Міністрів України від 3 грудня 2008 № 1057
This product complies with the "India E-waste (Management and Handling) Rule 2011" and prohibits use of lead, mercury, hexavalent chromium, polybrominated biphenyls or polybrominated diphenyl ethers in concentrations exceeding 0.1 weight % and 0.01 weight % for cadmium, except for the exemptions set in Schedule 2 of the Rule.
Perchlorate material Special handling may apply
Perchlorate material - special handling may apply.
See http://www.dtsc.ca.gov/hazardouswaste/perchlorate/.
This product’s real-time clock battery or coin cell battery may contain perchlorate and may require special handling when recycled or disposed of in California.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
