11-Network Management and Monitoring Configuration Examples
00-S12500_NTP_Configuration_Examples
Chapters Download  (203.77 KB)
00-S12500_NTP_Configuration_Examples 203.77 KB
Introduction· 1
Prerequisites 1
General configuration restrictions and guidelines 1
Example: Configuring the NTP client/server mode· 2
Network requirements 2
Software version used· 2
Configuration restrictions and guidelines 2
Configuration procedures 2
Verifying the configuration· 3
Configuration files 3
Example: Configuring the NTP symmetric active/passive mode· 4
Network requirements 4
Software version used· 4
Configuration restrictions and guidelines 4
Configuration procedures 5
Verifying the configuration· 5
Configuration files 6
Example: Configuring the NTP broadcast mode· 6
Network requirements 6
Software version used· 7
Configuration restrictions and guidelines 7
Configuration procedures 7
Verifying the configuration· 8
Configuration files 9
Example: Configuring the NTP multicast mode· 9
Network requirements 9
Software version used· 10
Configuration restrictions and guidelines 10
Configuration procedures 10
Verifying the configuration· 12
Configuration files 12
Example: Configuring the NTP broadcast mode with authentication· 14
Network requirements 14
Software version used· 14
Configuration restrictions and guidelines 14
Configuration procedures 15
Verifying the configuration· 16
Configuration files 17
Example: Configuring the SNTP client/server mode· 18
Network requirements 18
Software version used· 18
Configuration restrictions and guidelines 18
Configuration procedures 18
Verifying the configuration· 19
Configuration files 19
Related documentation· 20
Introduction
This document provides NTP configuration examples.
NTP synchronizes timekeeping among distributed time servers and clients (defined in RFC 5905). NTP provides consistent timekeeping for all clock-dependent devices and applications within the network.
SNTP is a simplified version of NTP. It uses the same packet format and packet exchange procedure as NTP, but it provides faster synchronization at the price of time accuracy, and occupies fewer system resources. SNTP supports only the client/server mode. NTP supports the following association modes, as shown in Table 1.
Table 1 NTP association modes
Mode
Application scenario
Client/server
This mode is intended for configurations where devices of a higher stratum synchronize to devices with a lower stratum.
Symmetric active/passive
This mode is most often used between two or more servers with the same stratum to operate as a backup for one another. If a server fails to communicate with all the servers of a higher stratum, the server can synchronize to the servers of the same stratum.
Broadcast
Broadcast mode is intended for configurations where a broadcast server sends clock synchronization messages to synchronize clients in the same subnet.
Broadcast mode is less accurate than the client/server and symmetric active/passive modes because only the broadcast server sends clock synchronization messages.
Multicast
A multicast server can provide time synchronization for clients in the same subnet or in different subnets.
Multicast mode is less accurate than the client/server and symmetric active/passive modes.
This document assumes that you have basic knowledge of NTP.
When you configure NTP, follow these restrictions and guidelines:
·     You cannot configure both NTP and SNTP on the same device.
·     For consistent system time on the device, configure NTP or SNTP only on one MDC if the device has multiple MDCs.
As shown in Figure 1, configure NTP to meet the following requirements:
·     Switch A's local clock is a reference source, with the stratum level 2.
·     Switch B operates in client mode.
·     Switch A is the NTP server for Switch B.
Figure 1 Network diagram
This configuration example was created and verified on S12500-CMW710-R7129.
When you configure the NTP client/server mode, follow these restrictions and guidelines:
·     For the client to synchronize to the NTP server, a server must be synchronized by other devices or use its local clock as a reference source.
·     A client can synchronize to a server, but a server cannot synchronize to a client.
1.     Set the IP address for each interface as shown in Figure 1. (Details not shown.)
2.     Configure Switch A:
# Enable the NTP service.
[SwitchA] ntp-service enable
# Specify the local clock as the reference source, with the stratum level 2.
[SwitchA] ntp-service refclock-master 2
3.     Configure Switch B:
[SwitchB] ntp-service enable
# Specify Switch A as the NTP server of Switch B.
[SwitchB] ntp-service unicast-server 1.0.1.11
# Display the NTP status on Switch B.
[SwitchB] display ntp-service status
 Clock status: synchronized
 Clock stratum: 3
 System peer: 1.0.1.11
 Local mode: client
 Reference clock ID: 1.0.1.11
 Leap indicator: 00
 Clock jitter: 0.000015 s
 Stability: 0.000 pps
 Clock precision: 2^-16
 Root delay: 0.93079 ms
 Root dispersion: 7949.87488 ms
 Reference time: d3d3a1a7.57bcbf32  Mon, Aug 13 2012 15:54:15.342
The output shows that Switch B has synchronized to Switch A. The clock stratum level is 3 on Switch B and 2 on Switch A.
Configuration files
·     Switch A:
 ntp-service enable
·     Switch B:
 ntp-service enable
As shown in Figure 2, configure NTP to meet the following requirements:
·     Switch B operates in client mode and Switch A is the NTP server for Switch B.
·     Switch C operates in symmetric-active mode and Switch B is the passive peer of Switch C.
Figure 2 Network diagram
When you configure the NTP symmetric active/passive mode, follow these restrictions and guidelines:
·     For the symmetric-passive peer to process NTP messages from a symmetric-active peer, enable NTP by using the ntp-service enable command on a symmetric passive peer.
·     For time synchronization, either the symmetric-active peer, the symmetric-passive peer, or both must be in synchronized state.
·     A symmetric active peer and a symmetric passive peer can be synchronized to each other. When they are in synchronized state, the peer with a higher stratum synchronizes to the peer with a lower stratum.
1.     Set the IP address for each interface as shown in Figure 2. (Details not shown.)
[SwitchB] ntp-service unicast-server 3.0.1.31
4.     Configure Switch C:
# Enable the NTP service on Switch C after Switch B has synchronized to Switch A.
[SwitchC] ntp-service enable
# Configure Switch B as a symmetric passive peer.
[SwitchC] ntp-service unicast-peer 3.0.1.32
# Display the NTP status of Switch B after clock synchronization.
 Clock stratum: 3
 System peer: 3.0.1.33
 Local mode: sym_passive
 Reference clock ID: 3.0.1.33
 Leap indicator: 00
 Root delay: 0.51880 ms
 Root dispersion: 15885.80322 ms
 Reference time: d3d3ac88.fa1db5e9  Mon, Aug 13 2012 16:40:40.977
# Display the NTP status of Switch C after clock synchronization.
[SwitchC] display ntp-service status
 Clock stratum: 4
 Nominal frequency: 64.0000 Hz
 Actual frequency: 64.0000 Hz
 Clock precision: 2^7
 Clock offset: -21.1982 ms
 Root delay: 15.00 ms
 Root dispersion: 775.15 ms
 Peer dispersion: 34.29 ms
 Reference time: 15:22:47.083 UTC Sep 19 2005 (C6D95647.153F7CED)
The output shows that Switch C has synchronized to Switch B. The clock stratum level is 4 on Switch C and 3 on Switch B.
Configuration files
·     Switch A:
 ntp-service enable
·     Switch B:
 ntp-service enable
·     Switch C:
 ntp-service enable
As shown in Figure 3, configure NTP to meet the following requirements:
·     Switch C's local clock is a reference source, with the stratum level 2.
·     Switch C operates in broadcast server mode and sends out broadcast messages from VLAN-interface 2.
·     Switch A and Switch B operate in broadcast client mode, and receive broadcast messages on VLAN-interface 2.
Figure 3 Network diagram
When you configure the NTP broadcast mode, follow these restrictions and guidelines:
·     For the broadcast client to synchronize to the broadcast server, a broadcast server must be synchronized by other devices or use its local clock as a reference source.
·     A broadcast client can synchronize to a broadcast server, but a broadcast server cannot synchronize to a broadcast client.
1.     Set the IP address for each interface as shown in Figure 3. (Details not shown.)
2.     Configure Switch C:
# Enable the NTP service on Switch C.
[SwitchC] ntp-service refclock-master 2
# Configure Switch C to operate in broadcast server mode and send broadcast messages through VLAN-interface 2.
[SwitchC]vlan 2
[SwitchC-vlan2]quit
[SwitchC-Vlan-interface2] undo shutdown
[SwitchC-Vlan-interface2] ntp-service broadcast-server
3.     Configure Switch A:
# Configure Switch A to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[SwitchA]vlan 2
[SwitchA-vlan2]quit
[SwitchA-Vlan-interface2] undo shutdown
[SwitchA-Vlan-interface2] ntp-service broadcast-client
4.     Configure Switch B:
# Configure Switch B to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[SwitchB]vlan 2
[SwitchB-vlan2]quit
[SwitchB-Vlan-interface2] undo shutdown
[SwitchB-Vlan-interface2] ntp-service broadcast-client
# Switch A and Switch B get synchronized upon receiving a broadcast message from Switch C. Display the NTP status of Switch A after clock synchronization.
[SwitchA-Vlan-interface2] display ntp-service status
 Clock stratum: 3
 System peer: 3.0.1.31
 Reference clock ID: 3.0.1.31
 Leap indicator: 00
 Clock jitter: 0.000214 s
 Root delay: 0.50354 ms
 Root dispersion: 3950.56152 ms
 Reference time: d3d3b9cb.fa186ac0  Mon, Aug 13 2012 17:37:15.976
The output shows that Switch A has synchronized to Switch C. The clock stratum level is 3 on Switch A and 2 on Switch C.
Configuration files
·     Switch C:
 ntp-service enable
vlan 2
interface Vlan-interface2
 ip address 3.0.1.31 255.255.255.0
·     Switch A:
 ntp-service enable
vlan 2
 ip address 3.0.1.30 255.255.255.0
·     Switch B:
 ntp-service enable
vlan 2
 ip address 3.0.1.32 255.255.255.0
As shown in Figure 4, configure NTP to meet the following requirements:
·     Switch C operates in multicast server mode and sends out multicast messages from VLAN-interface 2.
·     Switch A and Switch D operate in multicast client mode and receive multicast messages on VLAN-interface 3 and VLAN-interface 2, respectively.
Figure 4 Network diagram
When you configure the NTP multicast mode, follow these restrictions and guidelines:
·     For the multicast client to synchronize to the multicast server, a multicast server must be synchronized by other devices or use its local clock as a reference source.
·     A multicast client can synchronize to a multicast server, but a multicast server cannot synchronize to a multicast client.
1.     Set the IP address for each interface as shown in Figure 4. (Details not shown.)
# Configure Switch C to operate in multicast server mode and send multicast messages through VLAN-interface 2.
[SwitchC]vlan 2
[SwitchC-vlan2]quit
[SwitchC-Vlan-interface2] ntp-service multicast-server
3.     Configure Switch D:
<SwitchD> system-view
[SwitchD] ntp-service enable
# Configure Switch D to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchD]vlan 2
[SwitchD-vlan2]quit
[SwitchD] interface vlan-interface 2
[SwitchD-Vlan-interface2] undo shutdown
[SwitchD-Vlan-interface2] ntp-service multicast-client
# Enable IP multicast routing and IGMP.
[SwitchB] multicast routing-enable
[SwitchB]vlan 2
[SwitchB-vlan2]quit
[SwitchB-Vlan-interface2] pim dm
[SwitchB] vlan 3
[SwitchB-vlan3] port GigabitEthernet 3/0/1
[SwitchB-vlan3] quit
[SwitchB-Vlan-interface3] undo shutdown
[SwitchB-Vlan-interface3] igmp enable
[SwitchB-Vlan-interface3] igmp static-group 224.0.1.1
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] undo shutdown
[SwitchB-GigabitEthernet3/0/1] igmp-snooping static-group 224.0.1.1 vlan 3
5.     Configure Switch A:
# Configure Switch A to operate in multicast client mode and receive multicast messages on VLAN-interface 3.
[SwitchA]vlan 3
[SwitchA-vlan3]quit
[SwitchA-Vlan-interface3] undo shutdown
[SwitchA-Vlan-interface3] ntp-service multicast-client
# Display the NTP status of Switch D after clock synchronization.
[SwitchD-Vlan-interface2] display ntp-service status
 Clock stratum: 3
 Leap indicator: 00
 Clock jitter: 0.000305 s
 Root delay: 0.96130 ms
 Root dispersion: 16.52527 ms
 Reference time: d3d3bcde.fa197f8e  Mon, Aug 13 2012 17:50:22.976
The output shows that Switch D has synchronized to Switch C. The clock stratum level is 3 on Switch D and 2 on Switch C.
# Display the NTP status of Switch A after clock synchronization.
[SwitchA-Vlan-interface3] display ntp-service status
 Clock stratum: 3
 Local mode: bclient
 Leap indicator: 00
 Root delay: 0.90027 ms
 Root dispersion: 12.84790 ms
 Reference time: d3d4b196.e4f2a7c6  Tue, Aug 14 2012 11:14:30.894
Configuration files
·     Switch C:
 ntp-service enable
vlan 2
·     Switch D:
 ntp-service enable
vlan 2
·     Switch B:
 ntp-service enable
vlan 2
vlan 3
 pim dm
interface Vlan-interface3
 ip address 1.0.1.10 255.255.255.0
 igmp enable
interface GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 3
·     Switch A:
 ntp-service enable
vlan 3
 ip address 1.0.1.11 255.255.255.0
As shown in Figure 5, configure NTP to meet the following requirements:
·     Switch C's local clock is a reference source, with the stratum level 3.
·     Switch A and Switch B operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
·     NTP authentication is enabled on Switch A, Switch B, and Switch C.
Figure 5 Network diagram
When you configure the NTP broadcast mode with authentication, follow these restrictions and guidelines:
·     When you configure NTP authentication in broadcast mode, do the following:
?     Enable NTP authentication.
?     Configure an authentication key.
?     Set the key as a trusted key on both the broadcast client and server.
?     Configure an NTP authentication key on the broadcast server.
·     For NTP authentication, the key IDs and key values configured on the broadcast server and client must be the same.
1.     Set the IP address for each interface as shown in Figure 5. (Details not shown.)
# Enable NTP authentication on Switch A. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Enter the key in plain text, and specify it as a trusted key.
[SwitchA] ntp-service authentication enable
[SwitchA] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchA] ntp-service reliable authentication-keyid 88
# Configure Switch A to operate in NTP broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
[SwitchA] vlan 2
[SwitchA-vlan2]quit
# Enable NTP authentication on Switch B. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Enter the key in plain text and specify it as a trusted key.
[SwitchB] ntp-service authentication enable
[SwitchB] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchB] ntp-service reliable authentication-keyid 88
# Configure Switch B to operate in broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
[SwitchB] vlan 2
[SwitchB-vlan2]quit
# Specify the local clock as the reference source, with the stratum level 3.
[SwitchC] ntp-service refclock-master 3
# Configure Switch C to operate in NTP broadcast server mode and send NTP broadcast packets through VLAN-interface 2.
[SwitchC] vlan 2
[SwitchC-vlan2]quit
# Enable NTP authentication on Switch C. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Enter the key in plain text, and specify it as a trusted key.
[SwitchC] ntp-service authentication enable
[SwitchC] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchC] ntp-service reliable authentication-keyid 88
# Specify Switch C as an NTP broadcast server, and associate key 88 with Switch C.
[SwitchC-Vlan-interface2] ntp-service broadcast-server authentication-keyid 88
Verify that Switch A and Switch B can synchronize their local clocks to Switch C after NTP authentication is enabled on Switch C.
# Display NTP service status on Switch B.
[SwitchB-Vlan-interface2] display ntp-service status
 Clock stratum: 4
 Local mode: client
 Leap indicator: 00
 Clock jitter: 0.006683 s
 Clock precision: 2^-10
 Root delay: 0.00127 ms
 Root dispersion: 2.89877 ms
 Reference time: d0d287a7.3119666f  Sat, Jan  8 2011  6:50:15.191
The output shows that Switch B has synchronized to Switch C. The clock stratum level is 4 on Switch B and 3 on Switch C.
# Display IPv4 NTP association information for Switch B.
[SwitchB-Vlan-interface2] display ntp-service sessions
       source          reference       stra reach poll  now offset  delay disper
 [1245]3.0.1.31        127.127.1.0        3     3   64   68   -0.0 0.0000    0.0
 Total sessions : 1
The output shows that an association has been set up between Switch B and Switch C.
Configuration files
·     Switch A:
 ntp-service enable
ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$fZ51vG6
nEZoybjDKlM6huQYwq5g227NIYw==
vlan 2
·     Switch B:
 ntp-service enable
vlan 2
·     Switch C:
 ntp-service enable
vlan 2
As shown in Figure 6, configure NTP to meet the following requirements:
·     Switch B operates in SNTP client mode, and Switch A is the NTP server for Switch B.
·     NTP authentication is configured on Switch A and SNTP authentication is configured on Switch B.
Figure 6 Network diagram
When you configure the SNTP authentication in client/server mode, follow these restrictions and guidelines:
·     Enable authentication on both the NTP server and the SNTP client.
·     Configure the SNTP client with the same authentication key ID and key value as the NTP server, and specify the key as a trusted key on both the NTP server and the SNTP client.
·     Associate the specified key with the NTP server on the SNTP client.
1.     Set the IP address for each interface as shown in Figure 6. (Details not shown.)
# Configure the local clock of Switch A as a reference source, with the stratum level 2.
# Enable NTP authentication.
# Configure an NTP authentication key, with the key ID of 10 and key value of aNiceKey. Enter the key in plain text.
[SwitchA] ntp-service authentication-keyid 10 authentication-mode md5 simple aNiceKey
# Specify the key as a trusted key.
[SwitchA] ntp-service reliable authentication-keyid 10
# Enable the SNTP service.
[SwitchB] sntp enable
# Enable SNTP authentication on Switch B.
[SwitchB] sntp authentication enable
# Configure an SNTP authentication key, with the key ID of 10 and key value of aNiceKey. Enter the key in plain text.
[SwitchB] sntp authentication-keyid 10 authentication-mode md5 simple aNiceKey
[SwitchB] sntp reliable authentication-keyid 10
# Specify Switch A as the NTP server of Switch B, and associate the server with key 10.
[SwitchB] sntp unicast-server 1.0.1.11 authentication-keyid 10
# Display SNTP association information for Switch B.
[SwitchB] display sntp sessions
SNTP server     Stratum   Version    Last receive time
1.0.1.11        2         4          Tue, May 17 2011  9:11:20.833 (Synced)
The output shows that an association has been established between Switch B and Switch A, and Switch B has synchronized to Switch A.
Configuration files
·     Switch A:
 ntp-service enable
 ntp-service authentication-keyid 10 authentication-mode md5 cipher $c$3$cl9hOWY
Vdulw8Wql/zmIH4mwn8OcbXO1v5l9
·     Switch B:
sntp enable
sntp authentication-keyid 10 authentication-mode md5 cipher $c$3$FjioZoTZyZSGTN
3OI5Lv3yTIYGVi4FzK4T92
 sntp unicast-server 1.0.0.11 authentication-keyid 10
·     H3C S12500 Routing Switch Series Network Management and Monitoring Configuration Guide
·     H3C S12500 Routing Switch Series Network Management and Monitoring Command Reference
