06-Layer 3 - IP Routing Configuration Examples
00-S12500_IP_FRR_Configuration_Examples
Chapters Download  (169.35 KB)
00-S12500_IP_FRR_Configuration_Examples 169.35 KB
Introduction
This document provides configuration examples for static route FRR, OSPF FRR, and RIP FRR.
IP FRR was introduced to speed up route convergence by providing backup routes. When a switch detects a failure by using BFD, it handles the failure locally by replacing the invalid route with the backup route, instead of flooding the routing information or performing route calculation. Before the route convergence is complete, the backup route is used to forward packets. The network interruption time is minimized, and it approximately equals the time for failure detection plus the time for replacing the invalid route with the backup route.
The following routing protocols implement IP FRR in different ways:
·     For static routing, specify a backup output interface and backup next hop when you configure a static route.
·     For OSPF and IS-IS, the following methods are available:
?     Use a routing policy to designate a backup next hop for packets matching a specific IP prefix.
?     Use the fast-reroute auto command to enable OSPF and IS-IS to automatically calculate a backup next hop.
OSPF FRR and IS-IS FRR configurations are similar. This document provides only an example for configuring OSPF FRR.
·     For RIP, use a routing policy to designate a backup next hop for packets matching a specific IP prefix.
This document assumes that you have basic knowledge of H3C IP FRR.
General configuration restrictions and guidelines
IP tunnels, such as IPv6 over IPv4 tunnels, do not support IP FRR, because they do not support BFD to detect link failures.
Example: Configuring static route FRR
Network requirements
As shown in Figure 1, configure static route FRR to make sure when Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 1 Network diagram
Requirements analysis
To meet the network requirements, you must perform the following tasks:
·     For Switch S and Switch D to immediately detect unidirectional failures on Link A, enable BFD on Switch S and Switch D.
·     For the backup link (Link B) to take effect immediately when Link A fails, enable FRR on Switch S and Switch D.
Software version used
This configuration example was created and verified on S12500-CMW710-R7129.
When you configure static route FRR, follow these restrictions and guidelines:
·     FRR takes effect only for static routes with both the output interface and next hop specified. When you configure static routes, you must specify both the output interface and next hop for the static routes.
·     Do not use static route FRR and static route BFD at the same time.
Configuration procedures
1.     Configure IP addresses and subnet masks for interfaces on the switches, as shown in Figure 1. (Details not shown.)
2.     Configure static route FRR:
# On Switch S, configure the source IP address of BFD echo packets. ICMP redirection might be enabled on the peer device. Therefore, H3C recommends configuring an IP address that is not in use as the source IP address of BFD echo packets.
<SwitchS> system-view
[SwitchS] bfd echo-source-ip 10.1.1.1
# On Switch S, configure a static route to Loopback 0 of Switch D, and specify a backup output interface and backup next hop for the static route.
[SwitchS] ip route-static 4.4.4.4 32 Vlan-interface200 13.13.13.2 backup-interface Vlan-interface100 backup-nexthop 12.12.12.2
# On Switch D, configure the source IP address of BFD echo packets. ICMP redirection might be enabled on the peer device. Therefore, H3C recommends configuring an IP address that is not in use as the source IP address of BFD echo packets.
<SwitchD> system-view
[SwitchD] bfd echo-source-ip 40.4.4.4
# On Switch D, configure a static route to Loopback 0 of Switch S. Specify a backup output interface and backup next hop for the static route.
[SwitchD] ip route-static 1.1.1.1 32 Vlan-interface200 13.13.13.1 backup-interface Vlan-interface101 backup-nexthop 24.24.24.2
3.     On Switch A, configure static routes to Loopback 0 of Switch S and Switch D.
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 101 24.24.24.4
[SwitchA] ip route-static 1.1.1.1 32 vlan-interface 100 12.12.12.1
# Display route 4.4.4.4/32 on Switch S to view the backup next hop information.
<SwitchS> display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
   Protocol: Static          Process ID: 0
  SubProtID: 0x0                    Age: 00h42m37s
       Cost: 0               Preference: 60
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NBRID: 0x11000002          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x10040        OrigNextHop: 13.13.13.2
      Label: NULL           RealNextHop: 13.13.13.2
    BkLabel: NULL             BkNextHop: 12.12.12.2
  Tunnel ID: Invalid          Interface: Vlan-interface200
BkTunnel ID: Invalid        BkInterface: Vlan-interface100
# Display route 1.1.1.1/32 on Switch D to view the backup next hop information.
[SwitchD] display ip routing-table 1.1.1.1 verbose
  Summary Count : 1
Destination: 1.1.1.1/32
  SubProtID: 0x0                    Age: 00h56m00s
      Flags: 0x10040        OrigNextHop: 13.13.13.1
      Label: NULL           RealNextHop: 13.13.13.1
    BkLabel: NULL             BkNextHop: 24.24.24.2
BkTunnel ID: Invalid        BkInterface: Vlan-interface101
Configuration files
·     Switch S:
 version 7.1.034, Release 7129
 sysname SwitchS
vlan 1
vlan 100
vlan 200
 ip address 12.12.12.1 255.255.255.0
interface Vlan-interface200
 ip address 13.13.13.1 255.255.255.0
interface GigabitEthernet3/0/21
 port link-type trunk
 port trunk permit vlan 100
 undo port trunk permit vlan 1
interface GigabitEthernet3/0/22
 port trunk permit vlan 200
·     Switch D:
 sysname SwitchD
vlan 1
vlan 101
vlan 200
 ip address 24.24.24.4 255.255.255.0
 ip address 13.13.13.2 255.255.255.0
interface GigabitEthernet4/0/47
 port trunk permit vlan 101
interface GigabitEthernet4/0/48
·     Switch A:
 ip address 24.24.24.2 255.255.255.0
 ip address 12.12.12.2 255.255.255.0
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
Example: Configuring OSPF FRR
As shown in Figure 2, configure OSPF FRR to make sure when Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 2 Network diagram
·     For the backup link (Link B) to take effect immediately when Link A fails, enable FRR on Switch S and Switch D by using routing policies to designate backup next hops.
When you configure OSPF FRR, follow these restrictions and guidelines:
·     Do not use OSPF FRR and OSPF BFD at the same time.
·     Do not use the fast-reroute auto command together with the commands vlink-peer, sham-link, enable traffic-adjustment, and enable traffic-adjustment advertise.
1.     Configure IP addresses for interfaces and enable OSPF on the switches:
# Configure the IP address and subnet mask for each interface, as shown in Figure 2. (Details not shown.)
# Configure OSPF on the switches to make sure Switch S, Switch A, and Switch D can communicate with each other at the network layer and implement dynamic route update. (Details not shown.)
2.     Configure OSPF FRR:
# On Switch S, configure IP prefix list abc to permit packets destined for network 4.4.4.4/32.
[SwitchS] ip prefix-list abc index 10 permit 4.4.4.4 32
# On Switch S, configure routing policy frr to specify the backup output interface as VLAN-interface 100 and backup next hop as 12.12.12.2.
[SwitchS] route-policy frr permit node 10
[SwitchS-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchS-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchS-route-policy-frr-10] quit
# On Switch S, enable OSPF FRR by using routing policy frr.
[SwitchS] ospf 1
[SwitchS-ospf-1] fast-reroute route-policy frr
[SwitchS-ospf-1] quit
[SwitchD] bfd echo-source-ip 4.4.4.4
# On Switch D, configure IP prefix list abc to permit packets destined for network 1.1.1.1/32.
[SwitchD] ip prefix-list abc index 10 permit 1.1.1.1 32
# On Switch D, configure routing policy frr to specify the backup output interface as VLAN-interface 101 and backup next hop as 24.24.24.2.
[SwitchD-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchD-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchD-route-policy-frr-10] quit
# On Switch D, enable OSPF FRR by using routing policy frr.
[SwitchD] ospf 1
[SwitchD-ospf-1] fast-reroute route-policy frr
[SwitchD-ospf-1] quit
[SwitchS] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.0/24
   Protocol: OSPF            Process ID: 1
  SubProtID: 0x1                    Age: 01h22m08s
       Cost: 2               Preference: 10
      NBRID: 0x13000004          LastAs: 0
      Flags: 0x10041        OrigNextHop: 13.13.13.2
When the link between Switch S and Switch D fails, BFD immediately detects the failure, and FRR performs a link switchover. The backup next hop is used to forward packets until OSPF completes route convergence, ensuring service continuity.
# Use the debugging rib urt command to view how the route management module activates the backup route.
%Aug 14 20:55:20:677 2012 mdc1 BFD/5/BFD_CHANGE_FSM: -MDC=1; Sess[13.13.13
.1/13.13.13.2, LD/RD:1026/1026, Interface:Vlan200, SessType:Echo, LinkType:INET]
, Sta: UP->DOWN, Diag: 1
*Aug 14 20:55:21:009 2012 mdc1 RM/7/DEBUG: -MDC=1;
 OSPF route 24.24.24.0/24 was deleted in vpn default-vrf.
      Flags: 0x0         Process: 1     SubProto: 0       Label: 0
      NbrID: 0x13000004   Metric: 0         Pref: 0    (B)Label: 0
     AttrID: 0x0        Priority: 3      ModFlag: 0x0
*Aug 14 20:55:21:059 2012 mdc1 RM/7/DEBUG: -MDC=1;
 OSPF route 4.4.4.0/24 was added in vpn default-vrf.
      Flags: 0x41        Process: 1     SubProto: 1       Label: -1
      NbrID: 0x13000005   Metric: 3         Pref: 10   (B)Label: -1
     AttrID: 0xffffffff Priority: 3      ModFlag: 0x0
*Aug 14 20:55:21:109 2012 mdc1 RM/7/DEBUG: -MDC=1;
 OSPF route 4.4.4.0/24 was deleted in vpn default-vrf.
      Flags: 0x41        Process: 1     SubProto: 0       Label: -1
      NbrID: 0x13000007   Metric: 0         Pref: 0    (B)Label: -1
*Aug 14 20:55:21:160 2012 mdc1 RM/7/DEBUG: -MDC=1;
 route 24.24.24.0/24 in default-vrf was calculated, ErrCode: 0.
      PubFlags: 0x0400(0x12)  Priority: LOW       IDNtfy: 0x13000005
      OldProto: UnSpec       ActiveCnt: 1        IDFlush: 0x13000005
*Aug 14 20:55:21:211 2012 mdc1 RM/7/DEBUG: -MDC=1;
 route 4.4.4.0/24 in default-vrf was calculated, ErrCode: 0.
%Aug 14 20:56:00:084 2012 mdc1 OSPF/5/OSPF_NBR_CHG: -MDC=1; OSPF 1 Neighbo
r 13.13.13.2(Vlan-interface200) from Full to Down.
Configuration files
·     Switch S:
interface GigabitEthernet3/0/1
ospf 1
 area 0.0.0.0
  network 12.12.12.0 0.0.0.255
  network 13.13.13.0 0.0.0.255
  network 1.1.1.0  0.0.0.255
·     Switch D:
ospf 1
 area 0.0.0.0
  network 24.24.24.0 0.0.0.255
  network 4.4.4.0  0.0.0.255
Example: Configuring RIP FRR
As shown in Figure 3, configure RIP FRR to make sure when Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 3 Network diagram
When you configure RIP FRR, follow these restrictions and guidelines:
·     Do not use RIP FRR and RIP BFD at the same time.
·     RIP FRR is effective for only non-recursive RIP routes that are learned from directly connected neighbors.
1.     Configure IP addresses for interfaces and enable RIPv2 on the switches:
# Configure the IP address and subnet mask for each interface, as shown in Figure 3. (Details not shown.)
# Configure RIP on the switches to make sure Switch S, Switch A, and Switch D can communicate with each other at the network layer and implement dynamic route update. (Details not shown.)
2.     Configure RIP FRR:
[SwitchS] ip ip-prefix abc index 10 permit 4.4.4.4 32
[SwitchS-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface100 backup-nexthop 12.12.12.2
# On Switch S, enable RIP FRR by using routing policy frr.
[SwitchS] rip 1
[SwitchS-rip-1] fast-reroute route-policy frr
[SwitchS-rip-1] quit
[SwitchD-route-policy-frr-10] apply fast-reroute backup-interface Vlan-interface101 backup-nexthop 24.24.24.2
# On Switch D, enable RIP FRR by using routing policy frr.
[SwitchD] rip 1
[SwitchD-rip-1] fast-reroute route-policy frr
[SwitchD-rip-1] quit
<SwitchS> display ip routing-table 4.4.4.4 32 verbose
Summary Count : 1
   Protocol: RIP             Process ID: 1
  SubProtID: 0x2                    Age: 00h15m23s
       Cost: 74              Preference: 15
  OrigTblID: 0x2                OrigVrf: default-vrf
      NBRID: 0x14000002          LastAs: 0
When the link between Switch S and Switch D fails, BFD immediately detects the failure, and FRR performs a link switchover. The new route is adopted by RIP.
%Aug 14 20:41:41:913 2012 mdc1 BFD/5/BFD_CHANGE_FSM: -MDC=1; Sess[13.13.13
.1/13.13.13.2, LD/RD:1025/1025, Interface:Vlan200, SessType:Echo, LinkType:INET]
*Aug 14 20:41:44:138 2012 mdc1 RM/7/DEBUG: -MDC=1;
 RIP route 24.24.24.0/24 was deleted in vpn default-vrf.
      NbrID: 0x14000001   Metric: 0         Pref: 0    (B)Label: 0
*Aug 14 20:41:44:189 2012 mdc1 RM/7/DEBUG: -MDC=1;
 RIP route 4.4.4.0/24 was added in vpn default-vrf.
      Flags: 0x41        Process: 1     SubProto: 2       Label: -1
      NbrID: 0x14000000   Metric: 84        Pref: 15   (B)Label: -1
*Aug 14 20:41:44:239 2012 mdc1 RM/7/DEBUG: -MDC=1;
 RIP route 4.4.4.0/24 was deleted in vpn default-vrf.
      NbrID: 0x14000002   Metric: 0         Pref: 0    (B)Label: -1
*Aug 14 20:41:44:290 2012 mdc1 RM/7/DEBUG: -MDC=1;
      PubFlags: 0x0c00(0x12)  Priority: LOW       IDNtfy: 0x14000000
      OldProto: RIP         ActiveCnt: 1        IDFlush: 0x14000000
*Aug 14 20:41:44:341 2012 mdc1 RM/7/DEBUG: -MDC=1;
Configuration files
·     Switch S:
 port access vlan 100
 port access vlan 200
rip 1
 undo summary
 version 2
 network 1.0.0.0
 network 12.0.0.0
 network 13.0.0.0
 apply fast-reroute backup-interface Vlan-interface100 backup-nexthop 12.12.12.2
·     Switch D:
rip 1
 undo summary
 version 2
 network 4.0.0.0
 network 13.0.0.0
 network 24.0.0.0
Related documentation
·     H3C S12500 Routing Switch Series Layer 3IP Routing Configuration Guide
·     H3C S12500 Routing Switch Series Layer 3IP Routing Command Reference
·     H3C S12500 Routing Switch Series High Availability Configuration Guide
·     H3C S12500 Routing Switch Series High Availability Command Reference
