Part 13 - Maintenance and Debugging
01-FTP Commands
Chapters Download  (108.46 KB)
01-FTP Commands
1  FTP Configuration Commands
FTP Server Configuration Commands
display ftp-server
display ftp-server
View
Default Level
3: Manage level
None
Use the display ftp-server command to display the FTP server configuration.
After configuring FTP server parameters, you may verify them with this command.
Related commands: ftp server enable, ftp timeout, ftp update.
# Display the FTP server configuration.
<Sysname> display ftp-server
   FTP server is running
   Max user number:              1
   User count:                   1
   Timeout value(in minute):     30
   Put Method:                   fast
Table 1-1 display ftp-server command output description
Max user number
Maximum number of login users at one time
User count
Number of the current login users
Timeout value (in minute)
Allowed idle time of an FTP connection. If there is no packet exchange between the FTP server and client during the whole period, the FTP connection will be disconnected.
Put Method
File update method of the FTP server:
l  fast: Fast update, or
l  normal: Normal update
display ftp-user
display ftp-user
View
Default Level
3: Manage level
None
Use the display ftp-user command to display detailed information about current FTP users.
# Display the detailed information of FTP users.
<Sysname> display ftp-user
  UserName             HostIP    Port    Idle              HomeDir
       ftp       192.168.1.54    1190       0               flash:
# If the name of the logged-in user exceeds 10 characters, the exceeded characters will be displayed in the next line and right justified, for example, if the logged-in user name is administrator, the information is displayed as follows:
administra
       tor      192.168.0.152    1031       0               flash:
Table 1-2 display ftp-user command output description
UserName
Name of the currently logged-in user
HostIP
IP address of the currently logged-in user
Port
Port which the currently logged-in user is using
Idle
Duration time of the current FTP connection, in minutes
HomeDir
Authorized path of the present logged-in user
free ftp user
free ftp user username
View
Default Level
3: Manage level
username: Username. You can use the display ftp-user command to view the logged-in user name of the current FTP connection.
Use the free ftp user command to manually release the FTP connection established with the specified username.
Note that if the user to be released is transmitting a file, the connection between the user and the FTP server is terminated after the file transmission.
# Manually release the FTP connection established with username ftpuser.
<Sysname> free ftp user ftpuser
Are you sure to free FTP user ftpuser? [Y/N]:y
<Sysname>
ftp server acl
ftp server acl acl-number
undo ftp server acl
View
Default Level
3: Manage level
acl-number: Basic access control list (ACL) number, in the range 2000 to 2999.
Use the ftp server acl command to control FTP clients’ access to the device using an ACL.
Use the undo ftp server acl command to restore the default.
By default, no ACL is used to control FTP clients’ access to the device.
Associated with an ACL, the FTP server can deny the FTP requests of some FTP clients and only permit the access of clients allowed by the ACL rules. This configuration only filters the FTP connections to be established, and has no effect on the established FTP connections and operations. If you execute the command for multiple times, the last specified ACL takes effect.
# Associate the FTP service with ACL 2001 to allow only the client 1.1.1.1 to access the device through FTP.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule 0 permit source 1.1.1.1 0
[Sysname-acl-basic-2001] rule 1 deny source any
[Sysname-acl-basic-2001] quit
[Sysname] ftp server acl 2001
ftp server enable
ftp server enable
undo ftp server
View
Default Level
3: Manage level
None
Use the ftp server enable command to enable the FTP server and allow the login of FTP users.
Use the undo ftp server command to disable the FTP server.
By default, the FTP server is disabled to prevent attacks.
# Enable the FTP server.
[Sysname] ftp server enable
ftp timeout
ftp timeout minute
undo ftp timeout
View
Default Level
3: Manage level
minute: Idle-timeout timer in minutes, in the range 1 to 35791.
Use the ftp timeout command to set the idle-timeout timer.
Use the undo ftp timeout command to restore the default.
By default, the FTP idle time is 30 minutes.
After you log in to an FTP server, if the connection is disrupted and the FTP server is not notified, the system will maintain the connection, which will cause the occupation of the system resources and affect the login of other FTP users. To address this problem, you can set an idle-timeout timer so that the FTP server can disconnect from the user if no information is received or/and transmitted before the timer expires.
# Set the idle-timeout timer to 36 minutes.
[Sysname] ftp timeout 36
ftp update
ftp update { fast | normal }
undo ftp update
View
Default Level
3: Manage level
fast: Fast update.
normal: Normal update.
Use the ftp update command to set the file update mode that the FTP server uses while receiving data.
Use the undo ftp update command to restore the default, namely, the normal mode.
# Set the FTP update mode to normal.
[Sysname] ftp update normal
FTP Client Configuration Commands
l   In this section, the configuration procedure of entering FTP client view is omitted. You must use the ftp command to enter FTP client view to configure in this view. For details, refer to ftp.
l   Before executing the FTP client configuration commands in this section, make sure you have configured the correct authorities for users on the FTP server, such as viewing the files under the current directory, reading/downloading specified files, creating the directory/uploading files, and renaming/removing files.
ascii
ascii
View
FTP client view
Default Level
3: Manage level
None
Use the ascii command to set the file transfer mode to ASCII.
By default, the file transfer mode is ASCII.
The carriage return characters vary with operating systems. For example, to indicate the end of a line and transfer to the next line, the H3C device system and Windows system use characters /r/n, and the Linux system uses characters /n. Therefore, after the file transmission between two systems that use different carriage return characters, such as Linux system and H3C device system, the FTP transmission mode must be applied to ensure the correct resolution of the files.
FTP transfers files in two modes:
l   Binary mode: for program file or picture transmission.
l   ASCII mode: for text file transmission.
Related commands: binary.
# Set the file transfer mode to ASCII.
[ftp] ascii
200 Type set to A.
binary
binary
View
FTP client view
Default Level
3: Manage level
None
Use the binary command to set the file transfer mode to binary (also called flow mode).
By default, the transfer mode is ASCII mode.
Related commands: ascii.
# Set the file transfer mode to binary.
[ftp] binary
200 Type set to I.
bye
bye
View
FTP client view
Default Level
3: Manage level
None
Use the bye command to disconnect from the remote FTP server and return to user view. If the device establishes no connection with the remote FTP server, you will return to user view directly.
Related commands: close, disconnect, quit.
# Terminate the connection with the remote FTP server and return to user view.
[ftp] bye
221 Server closing.
cd
cd { directory | .. | / }
View
FTP client view
Default Level
3: Manage level
directory: Name of the target directory, in the format of [drive:/]path. For the detailed explanation of the drive and path arguments, see File Management Configuration in the Configuration Guide - Part 2 - System Configuration. If no drive information is provided, the argument represents a folder or subfolder under the current directory.
..: Returns to an upper directory. If the current working directory is the root directory, or no upper directory exists, the current working directory does not change when the cd .. command is executed. This argument does not support command online help.
/: Returns to the root directory of the storage medium. The keyword does not support command line online help.
Use the cd command to change the current working directory on the remote FTP server.
You can use this command to access another authorized directory on the FTP server.
Related commands: pwd.
# Change the working directory to the sub-directory logfile of the current directory.
[ftp] cd logfile
250 CWD command successful.
# Change the working directory to the sub-directory folder of the authorized directory.
[ftp] cd /folder
cdup
cdup
View
FTP client view
Default Level
3: Manage level
None
Use the cdup command to exit the current directory and enter the upper directory of the FTP server.
Execution of this command will not change the working directory if the current directory is already the authorized directory (that is, work-directory).
Related commands: cd, pwd.
# Change the current working directory path to the upper directory.
[ftp] pwd
257 "/ftp/subdir" is current directory.
[ftp] cdup
200 CDUP command successful.
[ftp] pwd
257 "/ftp" is current directory.
close
close
View
FTP client view
Default Level
3: Manage level
None
Use the close command to terminate the connection to the FTP server, but remain in FTP client view.
This command is equal to the disconnect command.
# Terminate the connection to the FTP server and remain in FTP client view.
[ftp] close
221 Server closing.
[ftp]
debugging
debugging
undo debugging
View
FTP client view
Default Level
3: Manage level
None
Use the debugging command to enable FTP client debugging.
Use the undo debugging command to disable FTP client debugging.
By default, FTP client debugging is disabled.
# The device serves as the FTP client. Enable FTP client debugging and use the active mode to download file sample.file from the current directory of the FTP server.
<Sysname> terminal monitor
<Sysname> terminal debugging
<Sysname> ftp 192.168.1.46
Trying 192.168.1.46 ...
Press CTRL+K to abort
Connected to 192.168.1.46.
220 FTP service ready.
User(192.168.1.46:(none)):ftp
331 Password required for ftp.
Password:
230 User logged in.
[ftp]undo passive
[ftp] debugging
[ftp] get sample.file
---> PORT 192,168,1,44,4,21
200 Port command okay.
 The parsed reply is 200
---> RETR sample.file
150 Opening ASCII mode data connection for /sample.file.
 The parsed reply is 150
FTPC: File transfer started with the signal light turned on.
FTPC: File transfer completed with the signal light turned off.
.226 Transfer complete.
FTP: 3304 byte(s) received in 4.889 second(s), 675.00 byte(s)/sec.
[ftp]
Table 1-3 debugging command output description
---> PORT
Give an FTP order, with data port numbers being…
The parsed reply is
The received reply code, which is defined in RFC 959.
---> RETR
Download the file
File transfer starts, and the signal light is turned on.
File transfer is completed, and the signal light is turned off.
delete
delete remotefile
View
FTP client view
Default Level
3: Manage level
remotefile: File name.
Use the delete command to permanently delete a specified file on the remote FTP server. A deleted file cannot be restored.
To do this, you must be a user with the delete permission on the FTP server.
# Delete file temp.c.
[ftp] delete temp.c
250 DELE command successful.
dir
dir [ remotefile [ localfile ] ]
View
FTP client view
Default Level
3: Manage level
remotefile: Name of the file or directory on the remote FTP server.
localfile: Name of the local file to save the displayed information.
Use the dir command to view the detailed information of the files and subdirectories under the current directory on the remote FTP server.
Use the dir remotefile command to display the detailed information of the specified file or directory on the remote FTP server.
Use the dir remotefile localfile command to display the detailed information of the specified file or directory on the remote FTP server, and save the displayed information into a local file specified by the localfile argument.
You can use the dir command to display the folder- and file-related information, such as the size, and the date they were created. If you only need to view the name of all the files and subdirectories under the current directory, you can use the Is command.
# View the detailed information of the files and subdirectories under the current directory on the remote FTP server.
[ftp] dir
227 Entering Passive Mode (192,168,1,46,5,68).
125 ASCII mode data connection already open, transfer starting for /*.
drwxrwxrwx   1 noone    nogroup         0 Aug 08  2006 logfile
-rwxrwxrwx   1 noone    nogroup  20471748 May 11 10:21 test.bin
-rwxrwxrwx   1 noone    nogroup      4001 Dec 08  2007 config.cfg
-rwxrwxrwx   1 noone    nogroup      3608 Jun 13  2007 startup.cfg
drwxrwxrwx   1 noone    nogroup         0 Dec 03  2007 test
-rwxrwxrwx   1 noone    nogroup       299 Oct 15  2007 key.pub
FTP: 394 byte(s) received in 0.189 second(s), 2.00K byte(s)/sec.
[ftp]
# View the information of the file ar-router.cfg, and save the result to aa.txt.
[ftp] dir ar-router.cfg aa.txt
227 Entering Passive Mode (192,168,1,50,17,158).
125 ASCII mode data connection already open, transfer starting for /ar-router.cfg.
....226 Transfer complete.
FTP: 67 byte(s) received in 4.600 second(s), 14.00 byte(s)/sec.
View the content of aa.txt.
[ftp] quit
<Sysname> more aa.txt
-rwxrwxrwx   1 noone    nogroup      3077 Jun 20 15:34 ar-router.cfg
disconnect
disconnect
View
FTP client view
Default Level
3: Manage level
None
Use the disconnect command to disconnect from the remote FTP server but remain in FTP client view.
This command is equal to the close command.
# Disconnect from the remote FTP server but remain in FTP client view.
[ftp] disconnect
221 Server closing.
ftp
ftp [ server-address [ service-port ] [ [ vpn-instance vpn-instance-name ]| [ source { interface interface-type interface-number | ip source-ip-address } ] ] ]
View
Default Level
3: Manage level
server-address: IP address or host name (a string of 1 to 20 characters) of a remote FTP server.
service-port: TCP port number of the remote FTP server, in the range 0 to 65535. The default value is 21.
vpn-instance vpn-instance-name: Specifies the VPN where the FTP server belongs. The vpn-instance-name argument specifies the instance name of the VPN, a case sensitive string of 1 to 63 characters.
interface interface-type interface-number: Specifies the source interface by its type and number. The primary IP address configured on this interface is the source address of the transmitted packets. If no primary IP address is configured on the source interface, the connection fails.
ip source-ip-address: The source IP address of the current FTP client. This source address must be the one that has been configured on the device.
Use the ftp command to log in to the remote FTP server and enter FTP client view.
Note that:
l   This command applies to IPv4 networks.
l   If you use this command without specifying any parameters, you will simply enter the FTP client view without logging in to the FTP server.
l   If you specify the parameters, you will be prompted to enter the username and password for accessing the FTP server.
# Log in from the current device Sysname1 to the device Sysname2 with the IP address of 192.168.0.211. The source IP address of the packets sent is 192.168.0.212.
<Sysname> ftp 192.168.0.211 source ip 192.168.0.212
Trying 192.168.0.211 ...
Connected to 192.168.0.211.
220 FTP Server ready.
User(192.168.0.211:(none)):abc
331 Password required for abc
Password:
230 User logged in.
[ftp]
ftp ipv6
ftp ipv6 [ server-address [ service-port ] [ source ipv6 source-ipv6-address ] [ -i interface-type interface-number ] ]
View
Default Level
3: Manage level
server-address: IP address or host name of the remote FTP server.
service-port: TCP port number of the FTP server, in the range 0 to 65535. The default value is 21.
source ipv6 source-ipv6-address: Specifies a source IPv6 address for transmitted FTP packets. This address must be an IPv6 address that has been configured on the device.
-i interface-type interface-number: Specifies the type and number of the egress interface. This parameter can be used only in case that the FTP server address is a link local address and the specified egress interface must have a link local address (For the configuration of link local addresses, see IPv6 Basics Configuration in the Configuration Guide - Part 4 - IP Services).
Use the ftp ipv6 command to log in to the FTP server and enter FTP client view.
Note that:
l   This command applies to IPv6 networks.
l   If you use this command without specifying any parameters, you will simply enter the FTP client view without logging in to an FTP server.
l   If you specify the parameters, you will be asked to enter the username and password for accessing the FTP server.
# Log in to the FTP server with IPv6 address 3000::200.
<Sysname> ftp ipv6 3000::200
Trying 3000::200 ...
Connected to 3000::200.
220 Welcome!
User(3000::200:(none)): MY_NAME
331 Please specify the password.
Password:
230 Login successful.
[ftp]
get
get remotefile [ localfile ]
View
FTP client view
Default Level
3: Manage level
remotefile: Name of the file to be downloaded.
localfile: File name used after a file is downloaded and saved locally. If this argument is not specified, the file is saved locally using the source file name to the current working directory, namely the directory where the user executes the ftp command.
Use the get command to download a file from a remote FTP server and save it.
# Download file testcfg.cfg to the root directory of the storage medium of the master, and save it as newest.cfg.
[ftp] get testcfg.cfg newest.cfg
227 Entering Passive Mode (192,168,1,46,4,47).
125 ASCII mode data connection already open, transfer starting for /testcfg.cfg.
FTP: 3608 byte(s) received in 2.050 second(s), 1.00K byte(s)/sec.
# Download file testcfg.cfg to the root directory of the storage medium of the slave (with the member ID 2), and save it as newest.cfg.
[ftp] get testcfg.cfg slot2#flash:/newest.cfg
227 Entering Passive Mode (192,168,1,46,4,48).
FTP: 3608 byte(s) received in 2.322 second(s), 1.00K byte(s)/sec.
lcd
lcd
View
FTP client view
Default Level
3: Manage level
None
Use the lcd command to display the local working directory of the FTP client.
# Display the local working directory.
[ftp] lcd
FTP: Local directory now flash:/clienttemp.
The above information indicates that the working directory of the FTP client before execution of the ftp command is flash:/clienttemp.
ls
ls [ remotefile [ localfile ] ]
View
FTP client view
Default Level
3: Manage level
remotefile: Filename or directory on the remote FTP server.
localfile: Name of a local file used to save the displayed information.
Use the ls command to view the information of all the files and subdirectories under the current directory of the remote FTP server. The file names and subdirectory names are displayed.
Use the ls remotefile command to view the information of a specified file or subdirectory.
Use the ls remotefile localfile command to view the information of a specified file or subdirectory, and save the result to a local file specified by the localfile argument.
The Is command can only display the names of files and directories on the FTP server, whereas the dir command can display other related information of the files and directories, such as the size, and the date they were created.
# View the information of all files and subdirectories under the current directory of the FTP server.
[ftp] ls
227 Entering Passive Mode (192,168,1,50,17,165).
ar-router.cfg
logfile
mainar.bin
arbasicbtm.bin
ftp
test
bb.cfg
testcfg.cfg
FTP: 87 byte(s) received in 0.132 second(s) 659.00 byte(s)/sec.
# View the information of directory logfile, and save the result to file aa.txt.
[ftp] ls logfile aa.txt
227 Entering Passive Mode (192,168,1,46,4,3).
125 ASCII mode data connection already open, transfer starting for /logfile/*.
FTP: 20 byte(s) received in 3.962 second(s), 5.00 byte(s)/sec.
# View the content of file aa.txt.
[ftp] quit
logfile.log
mkdir
mkdir directory
View
FTP client view
Default Level
3: Manage level
directory: Name of the directory to be created.
Use the mkdir command to create a subdirectory under the current directory on the remote FTP server.
To do this, you must be a user with the permission on the FTP server.
# Create subdirectory mytest on the current directory of the remote FTP server.
[ftp] mkdir mytest
257 "/mytest" new directory created.
open
open server-address [ service-port ]
View
FTP client view
Default Level
3: Manage level
server-address: IP address or host name of a remote FTP server.
service-port: Port number of the remote FTP server, in the range 0 to 65535, with the default value of 21.
Use the open command to log in to the IPv4 FTP server under FTP client view.
At login, you will be asked to enter the username and password for accessing the FTP server. If your input is correct, the login succeeds; otherwise, it fails.
If you have logged in to the IPv4 FTP server currently, you cannot use the open command to log in to another server. You need to disconnect with the current server first, and then try to connect with another one.
Related commands: close.
# In FTP client view, log in to the FTP server with the IP address of 192.168.1.50.
<Sysname> ftp
[ftp] open 192.168.1.50
Trying 192.168.1.50 ...
Connected to 192.168.1.50.
User(192.168.1.50:(none)):aa
331 Password required for aa.
Password:
230 User logged in.
[ftp]
open ipv6
open ipv6 server-address [ service-port ] [ -i interface-type interface-number ]
View
FTP client view
Default Level
3: Manage level
service-port: Port number of the remote FTP server, in the range 0 to 65535. The default value is 21.
-i interface-type interface-number: Specifies the egress interface by its type and number. This parameter can be used only in case that the FTP server address is a link local address and the specified egress interface must have a link local address (For the configuration of link local addresses, see IPv6 Basics Configuration in the Configuration Guide - Part 4 - IP Services).
Use the open ipv6 command to log in to the IPv6 FTP server in FTP client view.
# Log in to the FTP server (with IPv6 address 3000::200) in FTP client view.
<Sysname> ftp
[ftp] open ipv6 3000::200
220 Welcome!
Password:
passive
passive
undo passive
View
FTP client view
Default Level
3: Manage level
None
Use the passive command to set the data transmission mode to passive.
Use the undo passive command to set the data transmission mode to active.
The default transmission mode is passive.
Data transmission modes fall into the passive mode and the active mode. The active mode means that the data connection request is initiated by a server. The passive mode means that the data connection request is initiated by a client. This command is mainly used in conjunction with a firewall to restrict the FTP session connection between private and public network users.
# Set the data transmission mode to passive.
[ftp] passive
FTP: passive is on
put
put localfile [ remotefile ]
View
FTP client view
Default Level
3: Manage level
localfile: Name of the local file to be uploaded.
remotefile: File name used after a file is uploaded and saved on the FTP server.
Use the put command to upload a file on the client to the remote FTP server.
If no name is assigned to the file to be saved on the FTP server, the name of the source file is used by default. After a file is uploaded, it will be saved under the user’s authorized directory, which can be set with the authorization-attribute command.
# Upload source file vrpcfg.cfg on the master to the remote FTP server and save it as ftpclient.cfg.
[ftp] put vrpcfg.cfg ftpclient.cfg
227 Entering Passive Mode (192,168,1,46,4,50).
125 ASCII mode data connection already open, transfer starting for /ftpclient.cfg.
FTP: 1366 byte(s) sent in 0.064 second(s), 21.00Kbyte(s)/sec.
# Upload source file a.cfg on the slave (with the member ID 2) to the remote FTP server and save it as ftpclienta.cfg.
[ftp] put slot2#flash:/a.cfg ftpclienta.cfg
227 Entering Passive Mode (192,168,1,46,4,52).
125 ASCII mode data connection already open, transfer starting for /ftpclienta.cfg.
FTP: 1226 byte(s) sent in 0.065 second(s), 18.00Kbyte(s)/sec.
pwd
pwd
View
FTP client view
Default Level
3: Manage level
None
Use the pwd command to display the currently accessed directory on the remote FTP server.
# Display the currently accessed directory on the remote FTP server.
[ftp] cd servertemp
[ftp] pwd
257 "/servertemp" is current directory.
The above information indicates that the servertemp folder under the root directory of the remote FTP server is being accessed by the user.
View
FTP client view
Default Level
3: Manage level
None
Use the quit command to disconnect from the remote FTP server and exit to user view.
# Disconnect from the remote FTP server and exit to user view.
[ftp] quit
221 Server closing.
<Sysname>
remotehelp
remotehelp [ protocol-command ]
View
FTP client view
Default Level
3: Manage level
protocol-command: FTP command.
Use the remotehelp command to display the help information of FTP-related commands supported by the remote FTP server.
If no argument is specified, FTP-related commands supported by the remote FTP server are displayed.
# Display FTP commands supported by the remote FTP server.
[ftp] remotehelp
214-Here is a list of available ftp commands
    Those with '*' are not yet implemented.
   USER   PASS   ACCT*  CWD    CDUP   SMNT*  QUIT   REIN*
   PORT   PASV   TYPE   STRU*  MODE*  RETR   STOR   STOU*
   APPE*  ALLO*  REST*  RNFR*  RNTO*  ABOR*  DELE   RMD
   MKD    PWD    LIST   NLST   SITE*  SYST   STAT*  HELP
   NOOP*  XCUP   XCWD   XMKD   XPWD   XRMD
214 Direct comments to H3C company.
# Display the help information for the user command.
[ftp] remotehelp user
214 Syntax: USER <sp> <username>.
[ftp]
Table 1-4 remotehelp command output description
The following is an available FTP command list.
Those commands with “*” are not yet implemented.
USER
Username
PASS
Password
CWD
CDUP
Change to parent directory
SMNT*
File structure setting
QUIT
Quit
REIN*
Re-initialization
PORT
Port number
PASV
Passive mode
TYPE
Request type
STRU*
File structure
MODE*
Transmission mode
RETR
Download a file
STOR
Upload a file
STOU*
Store unique
APPE*
Appended file
ALLO*
Allocation space
REST*
Restart
RNFR*
Rename the source
RNTO*
Rename the destination
ABOR*
Abort the transmission
DELE
Delete a file
RMD
Delete a folder
MKD
Create a folder
PWD
Print working directory
LIST
List files
NLST
List file description
SITE*
Locate a parameter
SYST
Display system parameters
STAT*
HELP
Help
NOOP*
No operation
XCUP
Extension command, the same meaning as CUP
XCWD
Extension command, the same meaning as CWD
XMKD
Extension command, the same meaning as MKD
XPWD
Extension command, the same meaning as PWD
XRMD
Extension command, the same meaning as RMD
Syntax of the user command: user (keyword) + space + username
rmdir
rmdir directory
View
FTP client view
Default Level
3: Manage level
directory: Directory name on the remote FTP server.
Use the rmdir command to remove a specified directory from the FTP server.
Note that only authorized users are allowed to use this command.
Note that:
l   The directory to be deleted must be empty, meaning you should delete all files and subdirectories under the directory before deleting it. Run the delete command to delete files and subdirectories.
l   After you execute the rmdir command successfully, the files in the remote recycle bin under the directory will be automatically deleted.
# Delete the temp1 directory from the authorized directory on the FTP server.
[ftp] rmdir /temp1
200 RMD command successful.
user
user username [ password ]
View
FTP client view
Default Level
3: Manage level
username: Login username.
password: Login password. You can input this argument after the username argument plus a space; or you can input this argument when the “Password:” prompt appears after you input the username and then press Enter.
Use the user command to relog in to the currently accessed FTP server with another username.
Before using this command, you must configure the corresponding username and password on the FTP server; otherwise, your login fails and the FTP connection is closed.
# User ftp1 has logged in to the FTP server. Use username ftp2 to log in to the current FTP server. (Suppose username ftp2 and password 123123123123 have been configured on the FTP server).
l   Method 1
[ftp] user ftp2
331 Password required for ftp2.
Password:
230 User logged in.
[ftp]
l   Method 2
[ftp] user ftp2 123123123123
230 User logged in.
[ftp]
verbose
verbose
undo verbose
View
FTP client view
Default Level
3: Manage level
None
Use the verbose command to enable the protocol information function to display detailed prompt information.
Use the undo verbose command to disable the protocol information function.
By default, the protocol information function is enabled.
# Enable the protocol information function.
[ftp] verbose
FTP: verbose is on
# Disable the protocol information function and perform the Get operation.
[ftp] undo verbose
FTP: verbose is off
[ftp] get startup.cfg bb.cfg
FTP: 3608 byte(s) received in 0.052 second(s), 69.00K byte(s)/sec.
[ftp]
# Enable the protocol information function and perform the Get operation.
[ftp] verbose
FTP: verbose is on
[ftp] get startup.cfg aa.cfg
227 Entering Passive Mode (192,168,1,46,5,85).
125 ASCII mode data connection already open, transfer starting for /startup.cfg.
FTP: 3608 byte(s) received in 0.193 second(s), 18.00K byte(s)/sec.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
