H3C RF MODULE EWPA1PCID User Manual-6P100
01-Text
Chapters Download  (133.08 KB)
01-Text
01-Text 133.08 KB
This module has been tested and found to comply with the limits for a Class B digital module, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This module generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this module does cause harmful interference to radio or television reception, the user is encouraged to try to correct the interference by one or more of the following measures:
l          Reorient or relocate the receiving antenna.
l          Connect the computer into an outlet on a circuit different from that to which the receiver is connected.
l          Increase the separation between the computer and receiver.
l          Consult the dealer or an experienced radio/TV technician for help.
Caution
Any changes or modifications not expressly approved by the grantee of this module could void the user's authority to operate the equipment.
This module complies with Part 15 of the FCC Rules.
Operation is subject to the following two conditions:
1)        This module may not cause harmful interference
2)        This module must accept any interference received, including interference that may cause undesired operation.
Products that contain a radio transmitter are labelled with FCC ID and may also carry the FCC logo.
Caution
Exposure to Radio Frequency Radiation.
To comply with the FCC RF exposure compliance requirements, the following antenna installation and module operating configurations must be satisfied:
For configurations using an approved external antenna, the separation distance between the antenna and any person’s body (including hands, wrists, feet and ankles) must be at least 20cm (8 inch).
The transmitter shall not be collocated with other transmitters or antennas.
IEEE 802.11b or 802.11g operation of this product in the U.S.A. is firmware-limited to channels 1 through 11.
This module is intended only for OEM integrators under the following conditions:
1)        The antenna must be installed such that 20 cm is maintained between the antenna and users
2)        The transmitter module may not be co-located with any other transmitter or antenna.
As long as 2 conditions above are met, further transmitter test will not be required. However, the OEM integrator is still responsible for testing their endproduct for any additional compliance requirements required with this module installed (for example, LVD TV …etc.).
Caution
This module only could work when being installed into “client device” which could not transmit automatically, such as ROUTER or AP, with the software driver limit.
IMPORTANT NOTE
In the event that these conditions can not be met (for example certain laptop configurations or co-location with another transmitter), then the FCC authorization is no longer considered valid and the FCC ID can not be used on the final product. In these circumstances, the OEM integrator will be responsible for re-evaluating the end product (including the transmitter) and obtaining a separate FCC authorization.
WARNING
This Wireless Mini PCI Adapter does not support ad-hoc mode function.
End Product Labeling
This transmitter module is authorized only for use in module where the antenna may be installed such that 20 cm may be maintained between the antenna and users. The final end product must be labeled in a visible area with the following: “FCC ID: U6IRTV1SAPPCID”.
This Class B digital apparatus complies with Canadian ICES-003.
H3C, Inc. declares the following:
Product Name: H3C RF Module
Model No.: EWPA1PCID
Conforms to the following Product Standards:
Radiated Emission Standards
ETSI EN 301489-1;
ETSI EN 301489-17;
ETSI EN 300 328;
FCC Part 15;
Conducted Emission Standards
ETSI EN 301489-1 ;
ETSI EN 301489-17;
FCC Part 15;
Immunity Standards
ETSI EN 301489-1 ;
ETSI EN 301489-17;
Low Voltage Directive:
EN 60950-1/A11: 2004
Therefore, this product is in conformity with the following regional standards
FCC Class B ⎯ following the provisions of FCC Part 15 directive;
CE Mark ⎯ following the provisions of the EC directive.
EWPA1PCID Module is dual-band, multi-mode, IEEE 802.11b/g WLANs. It integrates a 2.4GHz radio, analog-to-digital and digital-to-analog (ADC/DAC) converters, a base-band processor, multi-protocol media access control (MAC), high speed UART, and a PCI/Card Bus host interface. It enables a high performance, cost effective, low power, compact solution that easily fit onto one side of a Mini PCI or PCI Card.
EWPA1PCID RF Module is one part of H3C MSR 20-1X series routers. With this module inside the Routers, which support WLAN function. As high-quality governmental, business and commercial sites oriented routers, the H3C MSR 20-1X series routers are multifunction routers developed for small businesses, branches of businesses, and home users. While “high-quality business and commercial sites” need to satisfy users’ requirements for broadband, wireless and voice access modes and provide VPN and QoS supports, they have a high demand for the performance, stability, security and manageability of the router devices. The most significant characteristics of the MSR 20-1X series routers are high performance-to-cost ratio and low price. The routers provide different types of built-in communication interfaces to interface with networks of different types of media, and provide an SIC/DSIC slot for interface capability expansion.
This chapter outlines the basic requirement for the installation and configuration of the module.
This module is a part of H3C MSR 20-1X router. You must plug it into the router’s PCI slot, then you can use it.
Hardware Installation
1)        Turn off your router and switch off the power from the main power supply.
2)        Then insert the RF module into your PCI slot. Ensure that the RF module is properly seated into the slot.
3)        Power on your PC.
WLAN Service Configuration
The term "AP" or an AP icon in this document refers to an AP-capable router.
When configuring WLAN service, go to these sections for information you are interested in:
l          WLAN Service Overview
l          802.11 Overview
l          WLAN Topologies
l          Protocols and Standards
l          Configuring WLAN Service
l          Displaying and Maintaining WLAN Service
l          WLAN Service Configuration Example
Wireless Local Area Networks (WLAN) have become very popular because they are very easy to setup and use, and users need not care about the complex wiring connections and relocation problems. A WLAN is not completely wireless because the servers in the backbone are fixed and clients are mobile.
Using the WLAN solution, network operators and enterprises can provide wireless LAN services to their customers. These services include:
l          WLAN client connectivity to conventional 802.3 LANs.
l          Secured WLAN access with different authentication and encryption methods.
l          Seamless roaming of WLAN clients in the mobility domain.
Terminology:
1)        Client
A handheld computer or laptop with a wireless Network Interface Card (NIC) can be a WLAN client.
2)        Access Point
A device that performs the bridging function from wireless to wired conversion and wired to wireless conversion of frames between a client and the Local Area Network (LAN).
3)        Access Controller (AC)
A device that controls and manages all the APs in the WLAN. The AC communicates with an Authentication server for WLAN client authentication.
4)        FAT Access Point (Fat AP)
A device that controls and manages all the wireless stations and performs the bridging operation from wireless to wired conversion and wired to wireless conversion of frames between a client and the LAN.
5)        Wireless Medium
A medium that is used for transmitting frames between clients. Radio Frequency is used as the wireless medium in the WLAN system.
6)        Distribution System
The distribution system is used to forward frames to their destination. It is the backbone to transmit frames between access points.
7)        Split MAC
In Split MAC mode, the services to be managed are distributed between AP and AC. The AP manages real-time services like, beacon generation, power management, fragmentation and defragmentation. The AC manages services related to packet distribution, association, dissociation and reassociation.
8)        Active Scanning
Active Scanning is used by clients to scan surrounding wireless networks and locate the compatible one. A client prepares a list of channels and transmits a probe request frame on each of them. When an AP receives these frames, it responds with its network parameters. Thus the client knows whether the AP can provide wireless services.
9)        Passive Scanning
Type of scanning used by a client when it wants to save the battery power. The client prepares a list of channels to scan and listens to beacons on each of these channels. In this case, the AP needs to periodically broadcast beacon frames.
10)    Authentication
A mechanism to ensure secure connection between client and AC or Fat AP. Two types of authentication mechanisms are used:
l          Open system authentication
l          Shared key authentication
Open System Authentication is the default authentication mechanism. In this mechanism, a client sends an authentication request frame to the AP, which relays this frame to the AC. The AC sends an authentication response to the AP, which conveys this response to the client. See WLAN Security Configuration for more information on shared key authentication.
11)    De-Authentication
The AC or Fat AP sends a de-authentication frame to remove client(s) from the wireless system. De-authentication can occur due to many reasons, such as:
l          Receiving an association/disassociation frame from a client which is unauthenticated.
l          Receiving a data frame from a client which is unauthenticated.
l          Receiving a PS-Poll frame from a client which is unauthenticated.
l          The validity timer for a client expires and the port is not secured and so on.
12)    Association
A client that wants to access the wireless network via an AP, must be associated with that particular AP.
Once the client chooses the compatible network and authenticate to an AP, it sends an association request frame to the AP. The AP sends an association response to the client and adds the client’s information in its database. At a time a client can associate with only one AP. The association is always initiated by the client, but not by the AP.
13)    Dissociation
A client sends a disassociation frame to the AP to end the association between them. Dissociation can occur due to many reasons, such as:
l          Receiving a data frame from a client which is authenticated and unassociated.
l          Receiving a PS-Poll frame from a client which is authenticated and unassociated.
A dissociation frame is either unicast or broadcast.
14)    Re-association
When a client is roaming from one AP area/BSS area to another, it sends a re-association request to the new AP/BSS area. The AP relays this re-association request to the AC. The AC then informs the previous AP to delete the client’s information from its database, informs the new AP to add the client’s information in its database and conveys successful reassociation information to the client.
802.11 Overview
The following functions are provided by the WLAN-MAC:
l          Beacon generation
l          Handling Probe Requests
l          Handling Open System Authentication
l          Handling (Re) Association
l          Handling Deauthentication
l          Handling Disassociation
l          Power Management
l          Fragmentation and Defragmentation
l          Dot11 to Ethernet Frame Conversion
l          Ethernet to Do11 Frame Conversion
l          Keep Alive Mechanism
l          Idle Timeout Mechanism
l          Clear Channel Search
WLAN Topologies
WLAN Topologies for Fat APs
WLAN topologies for Fat APs consist of:
l          Single BSS
l          Multi-ESS
l          Single ESS Multi-BSS
Single BSS
The coverage of an AP is called a Basic Service Set (BSS). Each BSS is identified by a BSSID. The most basic WLAN network can be established with only one BSS. All wireless clients associate with same BSS. If those clients have the same authorization, they can communicate with each other. Figure 6-1 shows a single BSS network.
Figure 6-1 Single BSS network
The clients can communicate with each other or reach a host in the Internet. Communication between clients within the same BSS is carried out through the Fat AP.
Muti-ESS
This topology describes a scenario where more than one ESS exists. When a mobile client joins the Fat AP, it can join one of the available ESSs. Figure 6-2 shows the multi-ESS network.
Figure 6-2 Multiple ESS network
Generally a Fat AP can provide more than one logical ESS at the same time. The Fat AP can broadcast the current information of ESS by Beacon or Probe response frames. Clients can select an ESS it is interested to join.
Different ESS domains can be configured on the fat AP. The fat AP can be configured to allow advertising and accepting clients in these ESS domains once their credentials are accepted.
Single ESS Muti-BSS (The multi-radio case)
This topology describes a scenario where a Fat AP has two radios that are in the same ESS but belong to different BSSs.
Figure 6-3 Single ESS Multiple BSS network
This network scenario can be used 802.11b/g need to be supported. Figure 6-3 shows two clients connected to different radios belong to the same ESS but different BSSs.
l          ANSI/IEEE Std 802.11, 1999 Edition
l          IEEE Std 802.11b
l          IEEE Std 802.11g
l          IEEE Std 802.11i
l          IEEE Std 802.11-2004
Configuration Task List
Table 6-1 Configuration Task List
Configuring Global WLAN Parameters
Optional
Shutting Down a Radio Interface
Optional
Specifying a Country Code
Required
Configuring a WLAN Service Template
Required
Configuring a Radio of an AP
Required
Configuring a Radio Policy on an AC or a Radio of a Fat AP
Required
Follow these steps to configure global WLAN parameters:
Table 6-2 Global WLAN Parameters List
To do…
Use the command…
Remarks
Enter system view
Configure the client idle timeout interval for the Fat AP
wlan client idle-timeout interval
Optional
By default, the idle timeout interval is 3600 seconds.
Configure the keep alive interval for the Fat AP
wlan client keep-alive interval
Optional
By default, keep–alive function is disabled.
Enable the Fat AP to respond to broadcast probe requests
wlan broadcast–probe reply
Optional
Enabled by default.
Follow these steps to shut down a radio interface:
Table 6-3 Shutting Down a Radio Interface
To do…
Use the command…
Remarks
Enter system view
Enter radio interface view
interface wlan-radio interface-number
Shut down the radio interface
shutdown
Optional
By default, the radio interface is enabled.
A country code identifies the country in which you want to operate radios. It determines characteristics such as operating power level and total number of channels available for the transmission of frames. You must set the valid country code or area code before configuring an AP.
Follow these steps to specify the country code:
Table 6-4 Specifying a Country Code
To do…
Use the command…
Remarks
Enter system view
Specify the country code
wlan country-code code
By default, the country code is US.
For information about country codes, refer to WLAN Services Command.
A WLAN service template includes attributes such as SSID, WLAN-ESS interface binding, authentication method (open-system or shared key) information. A service template can be of clear or crypto type. If a clear type service template exists, you cannot change it to crypto. To do so, you must delete the clear type service template, and configure a new service template with type as crypto.
Follow these steps to configure a service template:
Table 6-5 Configuring a WLAN Service Template
To do…
Use the command…
Remarks
Enter system view
Create a WLAN service template and enter WLAN service template view
wlan service-template service-template-number { clear | crypto }
Required
No WLAN service template is created by default.
Specify the service set identifier
ssid ssid-name
Required
By default, no SSID is set.
Disable the advertising of SSID in beacon frames
beacon ssid-hide
Optional
By default the SSID is advertised in beacon frames.
Note that hiding the SSID does very little to increase security.
Specify an authentication method
authentication-method { open system | shared key }
Required
For related configuration about the shared key, refer to WLAN Security in the WLAN Volume.
Specify the maximum associated clients per BSS
client max-count max-number
Optional
By default, the max-number is equal to the maximum number of associated clients an AP permits. The default value is provided by PAF.
Enable the service template
service-template enable
Required
Follow these steps to configure a radio of a Fat AP:
Table 6-6 Configuring a Radio of an AP
To do…
Use the command…
Remarks
Enter system view
Specify a radio type for the radio
radio-type { dot11b | dot11g | dot11a }
Required
The default radio type depends on the device model.
Bind a service template to a WLAN-ESS interface for the radio
service-template service-template-number interface wlan-bss interface-number
Required
Specify a channel number for the radio
channel { channel-number | auto }
Optional
By default, auto mode is enabled.
Specify the maximum radio power
max-power max-power
Optional
By default, the maximum radio power varies with radio types and country codes.
Specify the type of preamble
preamble { long | short }
Optional.
By default, the short preamble is supported.
Follow these steps to configure a radio policy on an AC or a radio of a Fat AP:
Table 6-7 Configuring a Radio Policy on an AC or a Radio of a Fat AP
To do…
Use the command…
Remarks
Enter system view
Enter radio view
interface wlan-radio radio-number
Set the interval for sending beacon frames
beacon-interval interval
Optional
By default, the beacon interval is 100 time units (TUs).
Set the number of beacon frames between DTIM frames
dtim counter
Optional
By default, the DTIM counter is 1.
Specify the maximum length of packets that can be transmitted without fragmentation
fragment-threshold size
Optional
By default, the fragment threshold is 2346 bytes.
Specify the request to send (RTS) threshold length
rts-threshold size
Optional
By default, the RTS threshold is 2346 bytes.
Set the maximum number of retransmission attempts for frames larger than the RTS threshold
long-retry threshold count
Optional
By default, the long retry threshold is 5.
Specify the maximum number of attempts to transmit a frame shorter than the RTS threshold
short-retry threshold count
Optional
By default, the short retry threshold is 5.
Specify the interval for the AP to hold received packets
max-rx-duration interval
Optional
By default, the interval is 2000 milliseconds.
On a Fat AP
Table 6-8 Displaying and Maintaining WLAN Service
To do…
Use the command…
Remarks
Display WLAN client information
display wlan client { interface wlan-radio [ wlan-radio-number ] | mac-address mac-address | service-template service-template-number } [ verbose ]
Available in any view
Display WLAN service template information
display wlan service-template [ service-template-number ]
Display WLAN client statistics
display wlan statistics client { all | mac-address mac-address }
Cut off client(s)
reset wlan client { all | mac-address mac-address }
Available in user view
Clear WLAN client statistics
reset wlan statistics client { all | mac-address mac-address }
Network requirements
As shown below, a Fat AP is connected to a L2 Switch. The IP address of the Fat AP is 10.18.1.10.
Network diagram
Figure 6-4 Network diagram for WLAN service configuration
Configuration procedure
# Specify the country code.
[Sysname] wlan country code IN
# Define the WLAN BSS interface.
[Sysname] interface wlan-bss 1
[Sysname-WLAN-BSS1] quit
# Define a WLAN service template and enable it.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] ssid abc
[Sysname-wlan-st-1] authentication-method open-system
[Sysname-wlan-st-1] service-template enable
# Configure the radio of the Fat AP.
[Sysname] interface wlan-radio 2/0
[Sysname-WLAN-Radio2/0] beacon-interval 200
[Sysname-WLAN-Radio2/0] dtim 4
[Sysname-WLAN-Radio2/0] rts-threshold 2300
[Sysname-WLAN-Radio2/0] fragment-threshold 2200
[Sysname-WLAN-Radio2/0] short-retry threshold 6
[Sysname-WLAN-Radio2/0] long-retry threshold 5
[Sysname-WLAN-Radio2/0] max-rx-duration 500
[Sysname-WLAN-Radio2/0] radio-type dot11a
[Sysname-WLAN-Radio2/0] channel 149
[Sysname-WLAN-Radio2/0] max-power 10
[Sysname-WLAN-Radio2/0] service-template 1 interface WLAN-BSS 1
# Configure global WLAN features.
[Sysname] wlan client idle-timeout 3600
[Sysname] wlan client keep-alive 100
[Sysname] wlan broadcast-probe reply
