02-Static Routing Configuration
Chapters Download (77.41 KB)
Table of Contents
1 Static Routing Configuration
Application Environment of Static Routing
Displaying and Maintaining Static Routes
Static Route Configuration Example
Basic Static Route Configuration Example
When configuring a static route, go to these sections for information you are interested in:
l Displaying and Maintaining Static Routes
l Static Route Configuration Example
The term “router” in this document refers to a router in a generic sense or a Layer 3 switch.
A static route is a manually configured. If a network’s topology is simple, you only need to configure static routes for the network to work normally. The proper configuration and usage of static routes can improve network performance and ensure bandwidth for important network applications.
The disadvantage of using static routes is that they cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the routes will be unreachable and the network breaks. In this case, the network administrator has to modify the static routes manually.
If the destination address of a packet fails to match any entry in the routing table, the packet will be discarded.
After a default route is configured on a router, any packet whose destination IP address matches no entry in the routing table can be forwarded to a designated upstream router.
A router selects the default route only when it cannot find any matching entry in the routing table.
l If there is no default route and the destination address of the packet fails to match any entry in the routing table, the packet will be discarded and an ICMP packet will be sent to the source to report that the destination or the network is unreachable.
The network administrator can configure a default route with both destination and mask being 0.0.0.0. The router forwards any packet whose destination address fails to match any entry in the routing table to the next hop of the default static route.
Before configuring a static route, you need to know the following concepts:
1) Destination address and mask
In the ip route-static command, an IPv4 address is in dotted decimal format and a mask can be either in dotted decimal format or in the form of mask length (the digits of consecutive 1s in the mask).
2) Output interface and next hop address
While configuring a static route, you can specify either the output interface or the next hop address depending on the specific occasion. The next hop address can not be a local interface IP address; otherwise, the route configuration will not succeed.
In fact, all the route entries must have a next hop address. When forwarding a packet, a router first searches the routing table for the route to the destination address of the packet. The system can find the corresponding link layer address and forward the packet only after the next hop address is specified.
When specifying the output interface, note that:
l If the output interface is a Null 0, there is no need to configure the next hop address.
l If the output interface is a VLAN interface or a management Ethernet port (M-GigabitEthernet), you must specify the corresponding next hop for the output interface.
3) Other attributes
You can configure different preferences for different static routes so that route management policies can be applied more flexibly. For example, specifying the same preference for different routes to the same destination enables load sharing, while specifying different preferences for these routes enables route backup.
Before configuring a static route, you need to finish the following tasks:
l Configure the physical parameters for related interfaces
l Configure the link-layer attributes for related interfaces
l Configure the IP addresses for related interfaces
Follow these steps to configure a static route:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure a static route |
ip route-static dest-address { mask | mask-length } { next-hop-address | interface-type interface-number next-hop-address } track track-entry-number [ preference preference-value ] [ description description-text ] |
Required By default, preference for static routes is 60, and no description information is configured. |
Configure the default preference for static routes |
ip route-static default-preference default-preference-value |
Optional 60 by default |
l When configuring a static route, the static route does not take effect if you specify the next hop address first and then configure it as the IP address of a local interface, such as VLAN interface.
l If you do not specify the preference when configuring a static route, the default preference will be used. Reconfiguring the default preference applies only to newly created static routes.
l If the destination IP address and mask are both configured as 0.0.0.0 with the ip route-static command, the route is the default route.
l For detailed information about track, refer to Track Configuration in the System Volume.
To do… |
Use the command… |
Remarks |
Display the current configuration information |
display current-configuration |
Available in any view |
Display the brief information of the IP routing table |
display ip routing-table |
Display the detailed information of the IP routing table |
display ip routing-table verbose |
View information of static routes |
display ip routing-table protocol static [ inactive | verbose ] |
Delete all the static routes |
delete static-routes all |
Available In system view |
The IP addresses and masks of the switches and hosts are shown in the following figure. Static routes are required for interconnection between any two hosts.
Figure 1-1 Network diagram for static route configuration
1) Configuring IP addresses for interfaces (omitted)
2) Configuring static routes
# Configure a default route on Switch A.
[SwitchA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Switch B.
[SwitchB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[SwitchB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on Switch C
[SwitchC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
3) Configure the hosts.
The default gateways for the three hosts A, B and C are 1.1.2.3, 1.1.6.1 and 1.1.3.1 respectively. The configuration procedure is omitted.
4) Display the configuration.
# Display the IP routing table of Switch A.
Routing Tables: Public
Destinations : 7 Routes : 7
0.0.0.0/0 Static 60 0 1.1.4.2 Vlan500
1.1.2.0/24 Direct 0 0 1.1.2.3 Vlan300
1.1.2.3/32 Direct 0 0 127.0.0.1 InLoop0
1.1.4.0/30 Direct 0 0 1.1.4.1 Vlan500
1.1.4.1/32 Direct 0 0 127.0.0.1 InLoop0
# Display the IP routing table of Switch B.
[SwitchB] display ip routing-table
Destinations : 10 Routes : 10
1.1.2.0/24 Static 60 0 1.1.4.1 Vlan500
1.1.3.0/24 Static 60 0 1.1.5.6 Vlan600
1.1.4.0/30 Direct 0 0 1.1.4.2 Vlan500
1.1.4.2/32 Direct 0 0 127.0.0.1 InLoop0
1.1.5.4/30 Direct 0 0 1.1.5.5 Vlan600
1.1.5.5/32 Direct 0 0 127.0.0.1 InLoop0
1.1.6.0/24 Direct 0 0 192.168.1.47 Vlan100
1.1.6.1/32 Direct 0 0 127.0.0.1 InLoop0
# Use the ping command on Host B to check reachability to Host A, assuming Windows XP runs on the two hosts.
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=255
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to check reachability to Host A.
[HostB] tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 1.1.6.1
2 <1 ms <1 ms <1 ms 1.1.4.1
3 1 ms <1 ms <1 ms 1.1.2.2
Trace complete.
