02-IP Performance Optimization Configuration
Chapters Download (106.75 KB)
Table of Contents
1 IP Performance Optimization Configuration
IP Performance Optimization Overview
Enabling Reception and Forwarding of Directed Broadcasts to a Directly Connected Network
Enabling Reception of Directed Broadcasts to a Directly Connected Network
Enabling Forwarding of Directed Broadcasts to a Directly Connected Network
Enabling the SYN Cookie Feature
Enabling Protection Against Naptha Attacks
Configuring TCP Optional Parameters
Configuring ICMP to Send Error Packets
Displaying and Maintaining IP Performance Optimization
When optimizing IP performance, go to these sections for information you are interested in:
l IP Performance Optimization Overview
l Enabling Reception and Forwarding of Directed Broadcasts to a Directly Connected Network
l Configuring ICMP to Send Error Packets
l Displaying and Maintaining IP Performance Optimization
In some network environments, you can adjust the IP parameters to achieve best network performance. IP performance optimization configuration includes:
l Enabling the device to receive and forward directed broadcasts
l Enabling the SYN Cookie feature and protection against Naptha attacks
l Configuring TCP timers
l Configuring the TCP buffer size
l Enabling ICMP error packets sending
Directed broadcast packets are broadcast on a specific network. In the destination IP address of a directed broadcast, the network ID is a network ID identifies the target network, and the host ID is all-one. If a device is allowed to forward directed broadcasts to a directly connected network, hackers may mount attacks to the network.
Follow these steps to enable the device to receive directed broadcasts:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the device to receive directed broadcasts |
ip forward-broadcast |
Optional By default, the device is enabled from receiving directed broadcasts. |
Currently, this command is ineffective on the S5810 series Ethernet switches. That is, the switches cannot be disabled from receiving directed broadcasts.
Follow these steps to enable the device to forward directed broadcasts:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter interface view |
Enable the interface to forward directed broadcasts |
ip forward-broadcast [ acl acl-number ] |
Required By default, the device is disabled from forwarding directed broadcasts. |
l If an ACL is referenced in the ip forward-broadcast [ acl-number ] command, only packets permitted by the ACL can be forwarded.
l If you repeatedly execute the ip forward-broadcast acl [ acl-number ] command on an interface, the last executed command takes effect only. If the command executed last time does not include the acl acl-number, the ACL configured previously will be removed.
As shown in Figure 1-1, the host’s interface and VLAN-interface 3 of Switch A are on the same network segment (1.1.1.0/24). VLAN-interface 2 of Switch A and VLAN-interface 2 of Switch B are on another network segment (2.2.2.0/24). The default gateway of the host is VLAN-interface 3 (IP address 1.1.1.2/24) of Switch A. Configure a static route on Switch B to enable the reachability between host and Switch B.
Figure 1-1 Network diagram for forwarding directed broadcasts
l Configure Switch A
<SwitchA> system-view.
[SwitchA-Vlan-interface3] ip address 1.1.1.2 24
[SwitchA-Vlan-interface3] quit
[SwitchA-Vlan-interface2] ip address 2.2.2.2 24
# Enable VLAN-interface 2 to forward directed broadcasts.
[SwitchA-Vlan-interface2] ip forward-broadcast
l Configure Switch B
# Configure a static route to the host.
[SwitchB] ip route-static 1.1.1.1 24 2.2.2.2
# Configure an IP address for VLAN-interface 2.
[SwitchB-Vlan-interface2] ip address 2.2.2.1 24
After the above configurations, if you ping the subnet broadcast address (2.2.2.255) of VLAN-interface 2 of Switch A on the host, the ping packets can be received by VLAN-interface 2 of Switch B.
As a general rule, the establishment of a TCP connection involves the following three handshakes:
1) The request originator sends a SYN message to the target server.
2) After receiving the SYN message, the target server establishes a TCP connection in the SYN_RECEIVED state, returns a SYN ACK message to the originator, and waits for a response.
3) After receiving the SYN ACK message, the originator returns an ACK message. Thus, the TCP connection is established.
Attackers may mount SYN Flood attacks during TCP connection establishment. They send a large number of SYN messages to the server to establish TCP connections, but they never make any response to SYN ACK messages. As a result, a large amount of incomplete TCP connections are established, resulting in heavy resource consumption and making the server unable to handle services normally.
The SYN Cookie feature can prevent SYN Flood attacks. After receiving a TCP connection request, the server directly returns a SYN ACK message, instead of establishing an incomplete TCP connection. Only after receiving an ACK message from the client can the server establish a connection, and then enter the ESTABLISHED state. In this way, large amounts of incomplete TCP connections could be avoided to protect the server against SYN Flood attacks.
Follow these steps to enable the SYN Cookie feature:
To do... |
Use the command... |
Remarks |
Enter system view |
system-view |
Enable the SYN Cookie feature |
tcp syn-cookie enable |
Required Disabled by default. |
l If MD5 authentication is enabled, the SYN Cookie feature will not function after enabled. Then, if you disable MD5 authentication, the SYN Cookie feature will be enabled automatically.
l With the SYN Cookie feature enabled, only the MSS, instead of the window’s zoom factor and timestamp, is negotiated during TCP connection establishment.
Naptha attacks are similar to the SYN Flood attacks. Attackers can perform Naptha attacks by using the six TCP connection states (CLOSING, ESTABLISHED, FIN_WAIT_1, FIN_WAIT_2, LAST_ACK, and SYN_RECEIVED), and SYN Flood attacks by using only the SYN_RECEIVED state.
Naptha attackers control a huge amount of hosts to establish TCP connections with the server, keep these connections in the same state (any of the six), and request for no data so as to exhaust the memory resource of the server. As a result, the server cannot process normal services.
Protection against Naptha attacks reduces the risk of such attacks by accelerating the aging of TCP connections in a state. After the feature is enabled, the device periodically checks the number of TCP connections in each state. If it detects that the number of TCP connections in a state exceeds the maximum number, it will accelerate the aging of TCP connections in this state.
Follow these steps to enable the protection against Naptha attack:
To do... |
Remarks |
Enter system view |
system-view |
Enable the protection against Naptha attack |
tcp anti-naptha enable |
Configure the maximum of TCP connections in a state |
tcp state { closing | established | fin-wait-1 | fin-wait-2 | last-ack | syn-received } connection-number number |
Optional 5 by default. If the maximum number of TCP connections in a state is 0, the aging of TCP connections in this state will not be accelerated. |
Configure the TCP state check interval |
tcp timer check-state timer-value |
Optional 30 seconds by default. |
l With the protection against Naptha attack enabled, the device will periodically check and record the number of TCP connections in each state.
l With the protection against Naptha attack enabled, if the device detects that the number of TCP connections in a state exceeds the maximum number, the device will consider that as Naptha attacks and accelerate the aging of these TCP connections. The device will not stop accelerating the aging of TCP connections until the number of TCP connections in the state is less than 80% of the maximum number.
TCP optional parameters that can be configured include:
l synwait timer: When sending a SYN packet, TCP starts the synwait timer. If no response packet is received within the synwait timer interval, the TCP connection cannot be created.
l finwait timer: When a TCP connection is changed into FIN_WAIT_2 state, the finwait timer is started. If no FIN packets is received within the timer interval, the TCP connection will be terminated. If a FIN packet is received, the TCP connection state changes to TIME_WAIT. If a non-FIN packet is received, the system restarts the timer upon receiving the last non-FIN packet. The connection is broken after the timer expires.
l Size of TCP receive/send buffer
Follow these steps to configure TCP optional parameters:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the TCP synwait timer |
tcp timer syn-timeout time-value |
Optional 75 seconds by default. |
Configure the TCP finwait timer |
tcp timer fin-timeout time-value |
Optional 675 seconds by default. |
Configure the size of TCP receive/send buffer |
tcp window window-size |
Optional 8 KB by default. |
The actual length of the finwait timer is determined by the following formula:
Actual length of the finwait timer = (Configured length of the finwait timer – 75) + configured length of the synwait timer
Sending error packets is a major function of ICMP. In case of network abnormalities, ICMP packets are usually sent by the network or transport layer protocols to notify corresponding devices so as to facilitate control and management.
There are three kinds of ICMP error packets: redirect packets, timeout packets and destination unreachable packets. Their sending conditions and functions are as follows.
1) Sending ICMP redirect packets
A host may have only a default route to the default gateway in its routing table after startup. The default gateway will send ICMP redirect packets to the source host, telling it to reselect a correct next hop to send the subsequent packets, if the following conditions are satisfied:
l The receiving and forwarding interfaces are the same.
l The selected route has not been created or modified by ICMP redirect packet.
l The selected route is not the default route of the device.
l There is no source route option in the packet.
ICMP redirect packets function simplifies host administration and enables a host to gradually establish a sound routing table to find out the best route.
2) Sending ICMP timeout packets
If the device received an IP packet with a timeout error, it drops the packet and sends an ICMP timeout packet to the source.
The device will send an ICMP timeout packet under the following conditions:
l If the device finds the destination of a packet is not itself and the TTL field of the packet is 1, it will send a “TTL timeout” ICMP error message.
l When the device receives the first fragment of an IP datagram whose destination is the device itself, it starts a timer. If the timer times out before all the fragments of the datagram are received, the device will send a “reassembly timeout” ICMP error packet.
3) Sending ICMP destination unreachable packets
If the device receives an IP packet with the destination unreachable, it will drop the packet and send an ICMP destination unreachable error packet to the source.
Conditions for sending this ICMP packet:
l If neither a route nor the default route for forwarding a packet is available, the device will send a “network unreachable” ICMP error packet.
l If the destination of a packet is local while the transport layer protocol of the packet is not supported by the local device, the device sends a “protocol unreachable” ICMP error packet to the source.
l When receiving a packet with the destination being local and transport layer protocol being UDP, if the packet’s port number does not match the running process, the device will send the source a “port unreachable” ICMP error packet.
l If the source uses “strict source routing" to send packets, but the intermediate device finds that the next hop specified by the source is not directly connected, the device will send the source a “source routing failure” ICMP error packet.
l When forwarding a packet, if the MTU of the sending interface is smaller than the packet but the packet has been set “Don’t Fragment”, the device will send the source a “fragmentation needed and Don’t Fragment (DF)-set” ICMP error packet.
Although sending ICMP error packets facilitates network control and management, it still has the following disadvantages:
l Sending a lot of ICMP packets will increase network traffic.
l If a device receives a lot of malicious packets that cause it to send ICMP error packets, its performance will be reduced.
l As the redirection function increases the routing table size of a host, the host’s performance will be reduced if its routing table becomes very large.
l If a host sends malicious ICMP destination unreachable packets, end users may be affected.
To prevent such problems, you can disable the device from sending ICMP error packets.
Follow these steps to enable sending of ICMP error packets:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable sending of ICMP redirect packets |
ip redirects enable |
Enable sending of ICMP timeout packets |
ip ttl-expires enable |
Enable sending of ICMP destination unreachable packets |
ip unreachables enable |
The device stops sending “TTL timeout” ICMP error packets after sending ICMP timeout packets is disabled. However, “reassembly timeout” error packets will be sent normally.
To do… |
Use the command… |
Remarks |
Display current TCP connection state |
display tcp status |
Available in any view |
Display TCP connection statistics |
display tcp statistics |
Display UDP statistics |
display udp statistics |
Display statistics of IP packets |
display ip statistics |
Display ICMP statistics |
display icmp statistics |
Display socket information |
display ip socket [ socktype sock-type ] [ task-id socket-id ] |
Display FIB information |
display fib [ | { begin | include | exclude } regular-expression | acl acl-number | ip-prefix ip-prefix-name ] |
Display FIB information matching the specified destination IP address |
display fib ip-address [ mask | mask-length ] |
Clear statistics of IP packets |
reset ip statistics |
Available in user view |
Clear statistics of TCP connections |
reset tcp statistics |
Clear statistics of UDP traffic |
reset udp statistics |
Currently, the S5810 series Ethernet switches do not support the display fib ip-prefix ip-prefix-name command. That is, they do not display FIB entries matching a specified IP prefix list.
