00-Product Overview
00-Cover
Chapters Download  (68.3 KB)
00-Cover
H3C S5810 Series Ethernet Switches
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: 6W100-20090626
Product Version: Release 1102
Copyright © 2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Organization
H3C S5810 Series Ethernet Switches Operation Manual is organized as follows:
Volume
Features
00-Product Overview
Product Overview
Acronyms
01-Access Volume
Ethernet Interface
Link Aggregation
Port Isolation
Loopback Interface and Null Interface
DLDP
LLDP
MSTP
Smart Link
Monitor Link
VLAN
GVRP
Port Mirroring
02-IP Services Volume
IP Addressing
IP Performance Optimization
ARP
DHCP
DNS
FTP and TFTP
03-IP Routing Volume
IP Routing Overview
Static Routing
04-Multicast Volume
Mulitcast Overview
IGMP Snooping
Multicast VLAN
05-QoS Volume
QoS
06-Security Volume
AAA
IP Source Guard
SSH2.0
PKI
SSL
Public Key
ACL
07-System Volume
Login
Basic System Configuration
Device Management
File System Management
HTTP
SNMP
RMON
MAC Address Table Management
System Maintaining and Debugging
Information Center
Track
NTP
VRRP
Cluster Management
Stack Management
Automatic Configuration
Conventions
The manual uses the following conventions:
Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
Related Documentation
In addition to this manual, each H3C S5810 Series Ethernet Switch documentation set includes the following:
Manual
H3C S5810 Series Ethernet Switches  Installation Manual
It introduces the installation procedure, commissioning, maintenance and monitoring of the S5810 Series Ethernet switches.
H3C S5810 Series Ethernet Switches Command Manual–Release 1102
It includes Feature List and Command Index, Access Volume, IP Services Volume, IP Routing Volume, IP Multicast Volume, QoS Volume, Security Volume and System Volume commands.
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, operation, and maintenance.
[Technical Support & Document > Product Support > Software]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
