H3C S5810 Series Ethernet Switches Command Manual-Release 1102-6W100-07-System Volume
05-HTTP Commands
Chapters Download  (47.88 KB)
05-HTTP Commands
HTTP Configuration Commands
display ip http
display ip http
View
Default Level
1: Monitor level
None
Use the display ip http command to display information about HTTP.
# Display information about HTTP..
<Sysname> display ip http
HTTP port: 80
Basic ACL: 2222
Current connection: 0
Operation status: Running
Table 1-1 display ip http command output description
HTTP port
Port number used by the HTTP service
Basic ACL
A basic ACL number associated with the HTTP service
Current connection
The number of current connections
Operation status
Operation status, which takes the following values:
l      Running: The HTTP service is enabled.
l      Stopped: The HTTP service is disabled.
ip http acl
ip http acl acl-number
undo ip http acl
View
Default Level
2: System level
acl-number: ACL number, in the range 2000 to 2999 ( basic IPv4 ACL).
Use the ip http acl command to associate the HTTP service with an ACL.
Use the undo ip http acl command to remove the association.
By default, the HTTP service is not associated with any ACL.
After the HTTP service is associated with an ACL, only the clients permitted by the ACL can access the device.
Note that: If you execute the ip http acl command for multiple times to associate the HTTP service with ACLs, the HTTP service is only associated with the last specified ACL.
Related commands: display ip http and acl number in ACL Commands in the Security Volume.
# Configure to associate the HTTP service with ACL 2001 and only allow the clients within the 10.10.0.0/16 network segment to access the device through the Web function.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ip http acl 2001
ip http enable
ip http enable
undo ip http enable
View
Default Level
2: System level
None
Use the ip http enable command to enable the HTTP service.
Use the undo ip http enable command to disable the HTTP service.
By default, the HTTP service is enabled.
The device can act as the HTTP server and the users can access and control the device through the Web function only after the HTTP service is enabled.
Related commands: display ip http.
# Disable the HTTP service.
[Sysname] undo ip http enable
ip http port
ip http port port-number
undo ip http port
View
Default Level
3: Manage level
port-number: Port number of the HTTP service, in the range 1 to 65535.
Use the ip http port command to configure the port number of the HTTP service.
Use the undo ip http port command to restore the default.
By default, the port number of the HTTP service is 80.
Note that this command does not check whether the configured port number conflicts with that of an existing service. Therefore, you must ensure that the port number is not used by another service before the configuration.
# Configure the port number of the HTTP service as 8080.
[Sysname] ip http port 8080
HTTPS Configuration Commands
display ip https
display ip https
View
Default Level
1: Monitor level
None
Use the display ip https command to display information about HTTPS.
# Display information about HTTPS.
<Sysname> display ip https
HTTPS port: 443
SSL server policy: test
Certificate access-control-policy:
Basic ACL: 2222
Table 2-1 display ip https command output description
HTTPS port
Port number used by the HTTPS service
SSL server policy
The SSL server policy associated with the HTTPS service
The certificate attribute access control policy associated with the HTTPS service
Basic ACL
The basic ACL number associated with the HTTPS service
Current connection
Operation status
l      Running: The HTTPS service is enabled.
l      Stopped: The HTTPS service is disabled.
ip https acl
ip https acl acl-number
undo ip https acl
View
Default Level
3: Manage level
Use the ip https acl command to associate the HTTPS service with an ACL.
Use the undo ip https acl command to remove the association.
By default, the HTTPS service is not associated with any ACL.
After the HTTPS service is associated with an ACL, only the clients permitted by the ACL can access the device.
Note that: If you execute the ip https acl command for multiple times to associate the HTTPS service with ACLs, the HTTPS service is only associated with the last specified ACL.
Related commands: display ip https and acl number in ACL Commands in the Security Volume
# Associate the HTTPS service with ACL 2001 and only allow the clients within the 10.10.0.0/16 network segment to access the HTTPS server through the Web function.
[Sysname] ip https acl 2001
ip https certificate access-control-policy
undo ip https certificate access-control-policy
View
Default Level
3: Manage level
policy-name: Name of the certificate attribute access control policy, a string of 1 to 16 characters.
Use the ip https certificate access-control-policy command to associate the HTTPS service with a certificate attribute access control policy.
Use the undo ip https certificate access-control-policy command to remove the association.
By default, the HTTPS service is not associated with any certificate attribute access control policy.
Association of the HTTPS service with a certificate attribute access control policy can control the access rights of clients.
Related commands: display ip https and pki certificate access-control-policy. (In PKI Commands in the Security Volume)
# Associate the HTTPS server to certificate attribute access control policy myacl.
[Sysname] ip https certificate access-control-policy myacl
ip https enable
ip https enable
undo ip https enable
View
Default Level
3: Manage level
None
Use the ip https enable command to enable the HTTPS service.
Use the undo ip https enable command to disable the HTTPS service.
By default, the HTTPS service is disabled.
Note that enabling of the HTTPS service triggers an SSL handshake negotiation process. During the process, if a local certificate of the device already exists, the SSL negotiation is successfully performed, and the HTTPS service can be started normally. If no local certificate exists, a certificate application process will be triggered by the SSL negotiation. Since the application process takes much time, the SSL negotiation often fails and the HTTPS service cannot be started normally. Therefore, the ip https enable command must be executed for multiple times to ensure normal startup of the HTTPS service.
Related commands: display ip https.
# Enable the HTTPS service.
[Sysname] ip https enable
ip https port
ip https port port-number
undo ip https port
View
Default Level
3: Manage level
port-number: Port number of the HTTPS service, in the range 1 to 65535.
Use the ip https port command to configure the port number of the HTTPS service.
Use the undo ip https port command to restore the default.
By default, the port number of the HTTPS service is 443.
# Configure the port number of the HTTPS service as 6000.
[Sysname] ip https port 6000
ip https ssl-server-policy
undo ip https ssl-server-policy
View
Default Level
3: Manage level
policy-name: Name of an SSL server policy, a string of 1 to 16 characters.
Use the ip https ssl-server-policy command to associate the HTTPS service with an SSL server-end policy.
Use the undo ip https ssl-server-policy to remove the association between the HTTPS service and an SSL server-end policy.
By default, the HTTPS service is not associated with any SSL server-end policy.
Note that:
l          The HTTPS service can be enabled only after this command is configured successfully.
l          You cannot modify an SSL server-end policy or remove the association between the HTTPS service and an SSL server-end policy after the HTTS service is enabled.
Related commands: display ip https and ssl server-policy in SSL Commands in the Security Volume
# Configure the HTTPS service to use SSL server-end policy myssl.
[Sysname] ip https ssl-server-policy myssl
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
