06-Security Volume
02-IP Source Guard Commands
Chapters Download  (33.33 KB)
IP Source Guard Configuration Commands
display ip check source
display ip check source [ interface interface-type interface-number | ip-address ip-address | mac-address mac-address ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Displays the dynamic bindings of the interface specified by its type and number.
ip-address ip-address: Displays the dynamic bindings of an IP address.
mac-address mac-address: Displays the dynamic bindings of an MAC address (in the format of H-H-H).
Use the display ip check source command to display dynamic bindings.
With no options specified, the command displays the dynamic bindings of all interfaces.
Related commands: ip check source.
# Display all dynamic bindings.
<Sysname> display ip check source
Total entries found: 3
  MAC                  IP          Vlan       Port                        Status
  040a-0000-4000      10.1.0.9     2          GigabitEthernet1/0/1        DHCP-SNP
  N/A                 10.1.0.8     2          GigabitEthernet1/0/1        DHCP-SNP
  040a-0000-2000      10.1.0.7     2          GigabitEthernet1/0/1        DHCP-SNP
Table 1-1 display ip check source command output description
Total entries found
Total number of found entries
MAC
MAC address of the dynamic binding. N/A means that no MAC address is bound in the entry.
IP
IP address of the dynamic binding. N/A means that no IP address is bound in the entry.
Vlan
VLAN to which the obtained binding entry belongs. N/A means that no VLAN is bound in the entry.
Port
Port to which the dynamic binding entry is applied
Status
Type of dynamically obtaining the binding entry
display user-bind
display user-bind [ interface interface-type interface-number | ip-address ip-address | mac-address mac-address ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Displays the static bindings of the interface specified by its type and number.
ip-address ip-address: Displays the static bindings of an IP address.
mac-address mac-address: Displays the static bindings of an MAC address (in the format of H-H-H).
Use the display user-bind command to display static bindings.
With no options specified, the command displays static bindings of all interfaces.
Related commands: user-bind.
# Display all static bindings.
<Sysname> display user-bind
Total entries found: 4
 N/A               1.1.1.1          N/A    GigabitEthernet1/0/1         Static
 0001-0001-0001    2.2.2.2          200    GigabitEthernet1/0/1         Static
 0003-0003-0003    N/A              N/A    GigabitEthernet1/0/1         Static
 0004-0004-0004    4.4.4.4          N/A    GigabitEthernet1/0/1         Static
Table 1-2 display user-bind command output description
Total entries found
MAC
MAC address of the binding. N/A means that no MAC address is bound in the entry.
IP
IP address of the binding. N/A means that no IP address is bound in the entry.
Vlan
VLAN of the binding. N/A means that no VLAN is bound in the entry.
Port
Port of the binding
Status
Type of the binding. Static means that the binding is manually configured.
ip check source
ip check source { ip-address | ip-address mac-address | mac-address }
undo ip check source
View
Ethernet interface view, VLAN interface view
Default Level
2: System level
ip-address: Specifies to bind source IP address to the port.
ip-address mac-address: Specifies to bind source IP address and MAC address to the port.
mac-address: Specifies to bind source MAC address to the port.
Use the ip check source command to configure the dynamic binding function on a port.
Use the undo ip check source command to restore the default.
By default, the dynamic binding function is disabled.
Note that: You cannot configure the dynamic binding function on a port that is in an aggregation group.
Related commands: display ip check source.
# Configure dynamic binding function on port GigabitEthernet 1/0/1 to filter packets based on both source IP address and MAC address.
[Sysname-GigabitEthernet1/0/1] ip check source ip-address mac-address
user-bind
user-bind { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
undo user-bind { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
View
Layer-2 Ethernet interface view
Default Level
2: System level
ip-address ip-address: Specifies the IP address for the static binding. The IP address can only be a Class A, Class B, or Class C address and can be neither 127.x.x.x nor 0.0.0.0.
mac-address mac-address: Specifies the MAC address for the static binding in the format of H-H-H. The MAC address cannot be all 0s, all Fs (a broadcast address), or a multicast address.
vlan vlan-id: Specifies the VLAN for the static binding. vlan-id is the ID of the VLAN to be bound, in the range 1 to 4094.
Use the user-bind command to configure a static binding.
Use the undo user-bind command to delete a static binding.
By default, no static binding exists on a port.
Note that:
l          The system does not support repeatedly configuring a binding entry to one port.
l          A binding entry can be configured to multiple ports.
l          You cannot configure a static binding on a port that is in an aggregation group.
Related commands: display user-bind.
# Configure a static binding on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] user-bind ip-address 192.168.0.1 mac-address 0001-0001-0001
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
