00-Cover
Chapters Download (41.78 KB)
H3C S5810 Series Ethernet Switches |
Installation Manual |
Hangzhou H3C Technologies Co., Ltd.
Manual Version: 6W100-20090626 |
Copyright © 2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint,
SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG,
PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
About This Manual
Organization
H3C S5810 Series Ethernet Switches Installation Manual is organized as follows:
Chapter |
Contents |
1 Product Overview |
Briefly introduces the appearance, system description, as well as the features and applications of the H3C S5810 series switches. |
2 Installation Preparations |
Describes the requirements on installation site, the safety recommendations before and during installation, and the required tools. |
Covers the procedures for installing the H3C S5810 series, ground wire connection, power module installation, interface module installation, and so on. |
4 Initial Power-On |
Helps you get familiar with the basic knowledge of how to boot and configure the H3C S5810 series, including device startup, power-on, and initialization of system files, and so on. |
5 Loading Software |
Introduces how to loading application files and upgrading the Boot ROM program by using the host software package. |
6 Maintenance and Troubleshooting |
Introduces how to maintain software and hardware of the H3C S5810 series. |
Appendix |
Appendix A: Lightning protection of the H3C S5810 series switch. |
Conventions
The manual uses the following conventions:
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means a complementary description. |
Related Documentation
Manual |
H3C PSR300-12A & PSR300-12D1 Power Modules User Manual |
Introduces the features, specifications, installation and removal of the PSR300-12A and PSR300-12D1 power modules. |
H3C LSW1FAN & LSW1BFAN Installation Manual |
Introduces the features, specifications, installation and removal of the LSW1FAN and LSW1BFAN fan modules. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
