H3C EPON OLT Command Manual(Release 5200 SeriesV1.02)
DownLoad Chapters Download(65 KB)
00-1Cover
H3C EPON
OLT Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08193M-20070415-C-1.02
Product Version: Release 5200 Series
Copyright   2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C EPON  OLT documentation set includes the following:
Manual
H3C EPON  OLT Operation Manual
It introduces EPON system configuration, OLT configuration, ONU configuration, ONU UNI configuration,  alarm configuration, and supported features.
H3C EPON  OLT Installation Manual
It introduces the switching engine, service board, installation, booting, configuration and maintenance of the EPON OLT devices (the S7500 series Ethernet switches applying EPON feature).
Organization
H3C EPON  OLT Command Manual is organized as follows:
Chapter
1 EPON System Configuration Commands
Details the commands for the entire EPON system configuration.
2 OLT Configuration Commands
Elaborates the commands for the configurations about the OLT.
3 ONU Configuration Commands
Elaborates the commands for the configurations about the ONU.
4 ONU UNI Configuration Commands
Elaborates the commands for the configurations about the ONU UNI.
5 Alarm Configuration Commands
Presents the commands for the configurations about the alarm types supports by the EPON system.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
