Manage backup tasks
View backup tasks
  1. On the top navigation bar, click VMs.
  1. From the left navigation pane, select External VMs > Backup Management.
  1. Click the Backup Tasks tab to view ongoing and finished backup tasks.
Delete backup tasks
  1. Click the Backup Tasks tab.
  1. Click the  icon for a backup task, and then click OK. Alternatively, select multiple backup tasks, click Delete, and then click OK.
The backup files created by the backup tasks will also be deleted.
Create a restoration task
You can restore a VM to UIS or VMware from a backup file. An external VM is not overwritten when it is restored. Instead, a new VM is created.
To create a restoration task:
  1. Click the  or  icon for a backup task.
  1. Configure the parameters as described in "Parameters."
  1. Click Finish.
Basic Info
Only the Restore to New VM option is available.
Configure VM
Storage
Network
For a VM restored to VMware, configure its network parameters according to those of the source VM.
For a VM restored to UIS, configure the following parameters:
Restore
