Perform this task to import a VOI desktop image according to the endpoint type.
ARM hosts do not support VOI desktop images in current software version.
From the navigation pane, select Images > Desktop Images.
Click the Desktop Images tab. Click Import.
Select desktop image type VOI, configure the parameters, and click OK.
Select Image Pool: Select the target storage path for the imported image. If no image pool is available, you can go to the image pool management page Create an image pool.
Parent Image: Parent image of the desktop image. When the image is used to build another image, the image becomes a parent image. When you upload a child image, you must select its parent image.
Operating System: OS type for the desktop image to import.
Endpoint Type: Endpoint type of the desktop image to import. The image can only be bound to endpoints of the same type.
