Import an IDV desktop image
Perform this task to import an IDV desktop image according to the endpoint type.
ARM hosts do not support IDV desktop images in current software version.
  1. From the navigation pane, select Images > Desktop Images.
  1. Click the Desktop Images tab. Click Import.
  1. Select desktop image type IDV, configure the parameters, and click OK.
