From the navigation pane, select Images > Desktop Images.
Click Import.
Select image type VDI, configure the parameters, upload the image file, and click OK.
Select Image Pool: Select the target storage path for the imported image. If no image pool is available, you can go to the image pool management page Create an image pool.
