VRF
Introduction
Virtual Routing and Forwarding (VRF) implements route isolation, data independence, and data security for VPNs.
A VRF has the following components:
An RD is added before a site ID to distinguish the sites that have the same site ID but reside in different VPNs. An RD and a site ID uniquely identify a VPN site.
An RD is a string of 3 to 21 characters in one of the following formats:
VRFs can be bound to the multiple instances of a multicast or routing protocol to implement service isolation. For example, if a device supports multiple OSPF instances, you can bind a VRF to each OSPF process, so that routes learned by an OSPF process are added into the routing table of the bound VRF.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure a VRF
Complete the following tasks before you configure this feature:
  1. Click the Network tab.
  2. In the navigation pane, select Interface Configuration > VRF.
  3. Click Create.
    Figure-1 Creating a VRF
  4. On the Create VRF page that opens, configure the VRF parameters.
    Figure-2 VRF configuration page
    Table-1 VRF configuration items
    Item
    VRF
    Enter the name of a VPN instance (VRF).
    Configure a description for the VPN instance.
    RD
    Configure a route distinguisher for the VPN instance.
    The address spaces of VPNs might overlap. RD is used to distinguish the overlapping IP addresses of VPNs. An eight-byte RD is added to an IPv4 prefix to form a unique VPN-IPv4 address.
    IPv4 route limit
    Specify the maximum number of active IPv4 route prefixes in the VPN instance.
    IPv6 route limit
    Specify the maximum number of active IPv6 route prefixes in the VPN instance.
    Alarm threshold
    Set an alarm threshold in the range of 1 to 100 in percentage.
    This parameter is not available if you select the Reject new routes action.
    Associated interfaces
    Select the interfaces to be associated with the current VPN instance.
  5. Click OK.
