Simple Network Management Protocol (SNMP) is used for a management station to access and operate the devices on a network, regardless of their vendors, physical characteristics, and interconnect technologies.
SNMP enables network administrators to read and set the variables on managed devices for state monitoring, troubleshooting, statistics collection, and other management purposes.
The SNMP framework contains the following elements:
The device supports SNMPv1, SNMPv2c, and SNMPv3. For an NMS and an SNMP agent to establish an SNMP connection, they must use the same SNMP version.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure a security policy as shown in the following figure:
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
SNMPv1 and SNMPv2c are configured in the same way.
Click the
In the navigation pane, select
Enable SNMP.
Figure-1 Enabling SNMP
Select one or multiple SNMP versions and set the common settings for the versions as described in the following table.
Figure-2 Configuring global settings
Table-1 Configuration items for SNMP versions and their common settings
Item | Description |
Version | Specify SNMP versions. Options are:
The device can receive packets of an SNMP version only after you specify that SNMP version. For an NMS and device to communicate, they must use the same SNMP version. If settings of multiple SNMP versions take effect, the device and NMS will negotiate for an SNMP version to communicate. The community name and data carried in SNMPv1 and SNMPv2c packets are in plaintext form, which has security risks. As a best practice, uses SNMPv3. To use SNMP notifications in an IPv6 environment, specify SNMPv2c or SNMPv3. |
Trap source interface | Select an interface as the source interface of traps. The system will use the primary IP address of that interface as the source IP of traps. The NMS will use that IP address to identify the agent. Even if the agent sends traps from multiple interfaces, the NMS can use that IP address to filter all traps from the agent. If the specified interface is configured with a valid IP address, the device will use that IP as the source IP of traps. This configuration does not take effect if the specified interface is not configured with a valid IP address, and will take effect automatically after the interface is configured with a valid IP. |
Location | Enter physical location of the device. For the device to be easily identified and managed, configure this parameter to record the physical location of the device on the device. |
Contact | Enter contact information of the device. This information helps the maintenance personnel to contact the device vendor in time when the device fails. |
Click
Select SNMPv1 and SNMPv2c.
Figure-3 Configuring SNMPv1 and SNMPv2c settings
Table-2 SNMPv1 and SNMPv2c configuration items
Read community | SNMP read community name, case sensitive. Using this community name, the NMS has only read access to the MIB objects on the agent. You can also specify escape characters (a backslash \ followed by characters) as the read community name. |
Write community | SNMP read-write community name, case sensitive. Using this community name, the NMS has read and write access to the MIB objects on the agent. You can also specify escape characters (a backslash \ followed by characters) as the read-write community name. |
Trap target host | Create the trap target host. You can configure multiple trap target hosts as required for the device to send traps to multiple NMSs.
Click
Set the common settings for the versions as described in Table-1.
Click
Select SNMPv3 and configure the settings as required.
Figure-4 Configuring SNMPv3 settings
Table-3 SNMPv3 configuration items
Username | SNMPv3 username, case sensitive. If the username changes, you must reconfigure the authentication and encryption passwords. |
Authentication algorithm | Select an SNMPv3 authentication algorithm. Options are:
Authentication password | Set an authentication password, which is case sensitive. For the device and NMS to establish an SNMP connection, the device and NMS must use the same authentication password. |
Encryption algorithm | Select an SNMPv3 encryption algorithm. Options are:
Encryption password | Set an encryption password, which is case sensitive. For the device and NMS to establish an SNMP connection, the device and NMS must use the same encryption password. |
Click
