This help contains the following topics:
Server connection detection (SCD) enables the device to identify and classify legal and illegal connections initiated by given servers based on user-defined rules. This helps the administrators to monitor internal servers and prevent them from becoming part of a botnet and launching attacks or performing internal network penetration.
SCD configuration involves the following tasks:
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure SCD as shown in the following figure:
Figure-1 SCD configuration flow chart
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
SCD learning enables the device to learn connections initiated by given servers. The learning results provide the basis for administrators to create SCD policies to monitor and log illegal connections initiated by the servers.
To configure SCD learning:
Click the
In the navigation pane, select
Click the
Figure-2 Configuring SCD learning
Enter or select the IP addresses of the servers for server-initiated connection learning and set the learning period.
To create an IPv4 address object group, see "Object groups."
Click
The device starts to learn the connections initiated by the specified servers for the specified learning period and displays the learning results in a list.
To set a server-initiated connection as a legal connection, select the connection and click
The device automatically creates an SCD policy for the server and creates an SCD rule for the selected server connection in the policy.
Click the
Click the
Click
Create an SCD policy.
Figure-3 Creating an SCD policy
Figure-4 Creating an SCD rule
Table-1 SCD policy configuration items
Item | Description |
Policy name | Enter a name for the SCD policy. |
Server address | Enter a server IP address. The SCD policy will monitor connections initiated by the server. |
Enable policy | Select whether to enable the SCD policy. |
Logging | Select whether to log connections initiated by the server that do not match any SCD rules. |
SCD rules | Each SCD rule defines a set of legal connections initiated by the server. Connections initiated by the server that do not match any SCD rules are considered illegal. To create an SCD rule:
