Public key management
This help contains the following topics:
Introduction
The public key management feature is used to manage and advertise keys of asymmetric key algorithms.
Asymmetric key algorithm overview
Asymmetric key algorithms are used by security applications to secure communications between two parties, as shown in Figure-1. Asymmetric key algorithms use two separate keys (one public and one private) for encryption and decryption. Symmetric key algorithms use only one key.
Figure-1 Encryption and decryption
A key owner can distribute the public key in plain text on the network but must keep the private key in privacy. It is mathematically infeasible to calculate the private key even if an attacker knows the algorithm and the public key.
Asymmetric key algorithms include Revest-Shamir-Adleman Algorithm (RSA), Digital Signature Algorithm (DSA), Elliptic Curve Digital Signature Algorithm (ECDSA), and SM2.
Security applications (such as SSH, SSL, and PKI) use the asymmetric key algorithms for encryption/decryption and digital signature.
Managing local asymmetric key pairs
Creating a local key pair
On the local device, you can create RSA, DSA, ECDSA, and SM2 key pairs. You can select an encryption device for a SM2 key pair.
Importing a local key pair
On the device, you must import a local key pair from a key pair file. If the key pair to be imported is encrypted, you need to enter the key pair password to successfully import the key pair.
Displaying or exporting a host public key
On the device, you can display or export the local host public keys.
Destroying a local key pair
To ensure security, destroy the local key pair and generate a new key pair in any of the following situations:
Managing peer host public keys
To encrypt information sent to a peer device or authenticate the digital signature of the peer device, you must configure the peer device's public key on the local device. On the local device, you can import, display, and delete the host public key of the peer device.
You can configure the peer host public key by using the following methods:
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
When you configure a peer host public key, follow these restrictions and guidelines:
Configure public key management
Configure a local key pair
Create a local key pair
To create a local key pair, perform the following operations:
  1. Click the Objects tab.
  2. Select PublicKey Cert > Public Key Management > Local Key Pairs.
  3. Click Create.
  4. Create a local key pair.
    Figure-2 Local Key Pairs page
    Figure-3 Creating a local key pair
    Table-1 Configuration items for local key pair creation
    Item
    Name
    Specify a name for the local key pair to be generated.
    Algorithm
    Specify an algorithm for the local key pair to be generated. Options include:
    • RSA.
    • DSA.
    • ECDSA.
    • SM2.
    Key length
    Specify a key length for the local key pair to be generated.
    This field is available for only an RSA or DSA key pair. The longer the key length, the higher the security, and the longer the key generation time. When you create an SM2 key pair, you do not need to specify the key length. Only a 256-bit SM2 key pair can be created.
    Elliptic curve
    Specify an elliptic curve for the local key pair to be generated.
    This field is available for only an ECDSA key pair. The elliptic curve determines the ECDSA key length. The longer the key length, the higher the security, and the longer the key generation time.
    Storage device
    Select a storage device for the local key pair to be generated.
    This field is available when the algorithm is SM2.
  5. Click Apply.
Import a local key pair
On the device, you can import a local key pair from a key pair file. If the key pair to be imported is encrypted, you must enter the key pair password to successfully import the key pair.
To import a local key pair, perform the following operations:
  3. Click Import.
  4. Import a local key pair.
    Figure-4 Local Key Pairs page
    Figure-5 Importing a local key pair
    Table-2 Configuration items for local key pair import
    Item
    Name
    Specify a name for the local key pair to be imported.
    Algorithm
    Specify an algorithm for the local key pair to be imported. Options include:
    • RSA.
    • ECDSA.
    • SM2.
    Import file
    Select the key pair file storing the local key pair to be imported.
    Overwrite existing key pair
    Specify whether to overwrite the existing key pair if the name of the key pair to be imported is the same as that of an existing key pair using the same key algorithm.
    The name of a key pair must be unique among all manually named key pairs that use the same key algorithm.
    Key pair password
    If the key pair to be imported is encrypted, enter the key pair password to successfully import the key pair.
  5. Click Apply.
Display or export a host public key
To export a local key pair, perform the following operations:
  3. Select the local key pair to be exported.
    Figure-6 Selecting the local key pair to be exported
  4. Click Export.
  5. Configure related parameters.
    Figure-7 Configuring related parameters for local key pair export
    Table-3 Configuration items for local key pair export
    Item
    Name
    Name of the local key pair to be exported.
    Algorithm
    Algorithm of the local key pair to be exported. Options include:
    • RSA.
    • DSA.
    • ECDSA.
    • SM2.
    Export format
    Select the export format for the local key pair. Options include OpenSSH, SSH1, and SSH2.
    Export to
    Select the export destination for the local key pair. Options include File and Monitor screen.
    File name
    Specify a name for the file storing the local key pair to be exported.
    Overwrite existing file
    Specify whether to overwrite the existing file if the file name is the same as an existing one.
  6. Click Apply.
Destroy a local key pair
To ensure security, destroy a local key pair and generate a new key pair in any of the following situations:
To destroy a local key pair, perform the following operations:
  2. Select Public Key Management > Local Key Pairs.
  3. Click the Objects tab.
  4. Select PublicKey Cert > Public Key Management > Local Key Pairs.
  5. Select the local key pair to be deleted.
  6. Click Delete.
  7. Click Yes.
Configure a peer host public key
  2. Select PublicKey Cert > Public Key Management > Peer Key Pairs.
  3. Click Import.
  4. Import a peer host public key.
    Figure-8 Peer Key Pairs page
    Figure-9 Importing a peer host public key
    Table-4 Configuration items for peer host public key import
    Item
    Public key name
    Specify a name for the peer host public key to be imported.
    Import method
    Select the import method for the peer host public key. Options include Import peer public key from file and Type or copy peer public key.
    Import file
    If you specify the import method as Import peer public key from file, you must select the file storing the peer host public key to be imported.
    Public key data
    If you specify the import method as Type or copy peer public key, you must type the public key in this field or copy the public key to this field.
  5. Click Apply.
