Policy-based NAT
This help contains the following topics:
Introduction
Network Address Translation (NAT) translates an IP address in the IP packet header to another IP address. Typically, NAT is configured on gateways to enable private hosts to access external networks and external hosts to access private network resources such as a Web server.
Policy-based NAT contains a set of NAT rules to identify and translate matching packets. The packet match criteria include source security zone, destination security zone, source IP address, destination IP address, and service.
Policy-based NAT is applicable to the scenario where the external interface is not fixed. You do not need to change relevant configurations if the external interface changes, which reduces maintenance costs.
Rule types
Policy-based NAT supports the following types of rules, which are applicable to different scenarios:
Translation modes
Policy-based NAT supports the following translation modes:
Hot backup for NAT
If only one NAT device is deployed in the internal network, internal users cannot access the external network when the NAT device fails. To avoid this situation, configure a two-node hot backup system to provide redundant NAT services. The two devices in the system synchronize session entries, session relation entries, NAT port block entries, and NAT configurations through the hot backup channel. When one device fails, the other device takes over. For more information about configuring a hot backup system, see "Hot backup".
Typically, the master device in the VRRP group processes NAT services in the hot backup system. On an active/standby hot backup system, some translation rules for static, source, or destination address translation issue the translated public IP addresses or the public IP addresses of internal servers to the address management module. Then, both the active and standby devices advertise the mappings between the public IP addresses and MAC addresses of their own physical interfaces to all nodes in the same LAN or local link. As a result, the upstream Layer 3 device directly connected to the hot backup system might incorrectly send downlink packets to a VRRP backup device, causing service anomalies. This issue might also occur on a dual-active hot backup system.
To avoid such an issue, bind address translation methods to the VRRP group in use. This ensures that only the VRRP master device responds to the ARP requests or NS requests for the translated public IP addresses or the public IP addresses of internal servers. The MAC addresses in the responses are the virtual MAC address of the VRRP group.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure policy-based NAT
NAT can be performed in the inbound or outbound direction.
Figure-1 NAT on an inbound security zone
Figure-2 NAT on an outbound security zone
Configuration flowchart
Policy-based NAT supports packet match criteria including security zone, address object group, and service object group. Policy-based NAT supports source address translation, destination address translation, and source and destination address translation. Figure-3 shows the configuration flowchart.
Figure-3 Policy-based NAT configuration flowchart
Complete the following tasks before you configure this feature:
Configure a policy-based NAT44 rule
  1. (Optional.) Create a security zone. (Details not shown.)
  2. (Optional.) Create an address object group. For more information, see "Object groups."
  3. (Optional.) Create a service object group. (Details not shown.)
  4. (Optional.) Create a NAT address group.
    1. Click the Objects tab.
    2. In the navigation pane, select Object Groups > NAT Address Groups. For more information, see "Object groups."
    3. Click Create.
    4. Create a NAT address group.
    5. Click OK.
  5. Create a policy-based NAT44 rule.
    1. Click the Policies tab.
    2. In the navigation pane, select Policy-based NAT.
    3. Select a translation mode as required.
      Figure-4 Selecting a translation mode
      Table-2 Translation mode description
      Translation mode
      Create SNAT
      Translates the source address information of packets.
      Create DNAT
      Translates the destination address information of packets.
      Create SNAT+DNAT
      Translates both the source and destination address information of packets.
    4. Click the NAT44 tab.
      Figure-5 Configuring a policy-based NAT44 rule
      Table-3 Configuration items for policy-based NAT44 rules
      Item
      When IP addresses match the following criteria
      Source zone
      Select source security zones for packet match.
      Destination zone
      Select destination security zones for packet match. This field is displayed only when you select the Create SNAT translation mode.
      Source IP
      Select a source IP address, IP subnet, or address object group for packet match.
      Destination IP
      Select a destination IP address, IP subnet, or address object group for packet match.
      If the translation mode is destination address translation or source and destination address translation, this field must be specified.
      Service
      Select a service object group for packet match.
      Translate source IP addresses to
      Translation mode
      Select a source address translation method:
      • Easy IP—Uses the outgoing interface IP address of the device for source address translation.
      • Dynamic IP—Uses the PAT or NO-PAT method to perform address translation.
      • Static IP—Translates the source IP addresses of packets to a fixed IP address.
      • No translation—This rule and rules with lower priority than this rule are not used for source address translation.
      Address
      Select a NAT address type for source address translation:
      • Address object group—Uses IP addresses in an address object group for source address translation.
      • NAT address group—Uses IP addresses in a NAT address group for source address translation.
      • IP address—Uses a fixed IP address for source address translation.
      • Network address—Uses IP addresses on a network for source address translation.
      Source IP after NAT
      Select a NAT address for source address translation.
      Associated IPv4 VRRP Group
      After you configure this feature, the master device in the IPv4 source VRRP group uses the virtual IP address and virtual MAC address to reply packets. On a stateful failover network, you must configure this feature. Support for this feature varies by device.
      Allow reverse NAT
      Enable reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network.
      This option is available only when the translation mode is set to Dynamic IP.
      Port translation
      If you enable port translation, the device uses the PAT method to translate the source IP addresses and source ports of packets. If you disable port translation, the device uses the NO-PAT method to translate only the source IP addresses of packets.
      User original port preferentially
      Preferentially use the original port for PAT. When the original port has been allocated, another port is used.
      This option is available only when the translation mode is set to Dynamic IP or Easy IP.
      Translate destination IP addresses to
      Translation mode
      Select a destination address translation method:
      • Static IP—Translates the destination IP addresses of packets to a fixed IP address.
      • Address object group—Translates the destination IP addresses of packets to addresses in an address object group.
      Destination IP after NAT
      Set the destination IP address after translation.
      Port after NAT
      Set the destination port after translation.
      After you configure this feature, the master device in the IPv4 destination VRRP group uses the virtual IP address and virtual MAC address to reply packets. On a stateful failover network, you must configure this feature. Support for this feature varies by device.
      General settings
      Name
      Name of the NAT44 rule, which supports Chinese characters.
      Rule status
      Whether to enable the NAT44 rule.
      Auto generate security policy
      After you enable this feature, the device generates a security policy based on the original packet information configured above.
      Advanced settings
      Remarks for the NAT44 rule.
      VRF before NAT
      VPN instance to which packets belong before address translation.
      VRF after NAT
      VPN instance to which packets belong after address translation.
      Counting
      Enable the counting of times that the NAT44 rule is matched.
    5. Click Apply.
Configure a policy-based NAT66 rule
  3. (Optional.) Create a service object group. For more information, see "Object groups."
  4. Create a policy-based NAT66 rule.
      Figure-6 Selecting a translation mode
      Table-4 Translation mode description
      Translation mode
      Create SNAT
      Create DNAT
      Create SNAT+DNAT
    4. Click the NAT66 tab.
      Figure-7 Configuring a policy-based NAT66 rule
      Table-5 Configuration items for policy-based NAT66 rules
      Item
      Source zone
      Destination zone
      Source IP
      Destination IP
      Service
      Translation mode
      • NPTV6—Uses the NPTV6 method to translate the prefixes in the source IPv6 addresses of packets to the configured prefix. To use this method, you must configure packet match rules for original packets.
      Source IP after NAT
      Port translation
      Associated IPv6 VRRP Group
      After you configure this feature, the master device in the IPv6 source VRRP group uses the virtual IP address and virtual MAC address to reply packets. On a stateful failover network, you must configure this feature. Support for this feature varies by device.
      IPv6 prefix
      Configure the IPv6 address prefix for the prefix translation method.
      This option is available only when the prefix translation method is NPTV6.
      Prefix length
      Configure the IPv6 prefix length.
      Translation method
      • NPTV6—Uses the NPTV6 method to translate the prefixes in the destination IPv6 addresses of packets to the configured prefix.
      • Static IP—Translates the destination IP addresses and destination ports of packets to a fixed IP address and a fixed port, respectively.
      • No translation—This rule and rules with lower priority than this rule are not used for destination address translation.
      Port after NAT
      IPv6 prefix
      This option is available only when the translation method is NPTV6.
      Prefix length
      General settings
      Name
      Name of the NAT66 rule, which supports Chinese characters.
      Rule status
      Whether to enable the NAT66 rule.
      Advanced settings
      Remarks for the NAT66 rule.
      VRF before NAT
      VRF after NAT
      Counting
      Enable the counting of times that the NAT66 rule is matched.
    5. Click Apply.
Configure a policy-based NAT64 rule
  4. Create a policy-based NAT64 rule.
    3. Click the chevron icon next to Create SNAT, and then select Create SNAT+DNAT.
      Figure-8 Selecting Create SNAT+DNAT
    4. Click the NAT64 tab.
      Figure-9 Configuring a policy-based NAT64 rule
      Table-6 Configuration items for policy-based NAT64 rules
      Item
      Translation method
      V4toV6
      Translates the source IP address and destination IP address of packets when an IPv4 host first initiates a connection to the IPv6 network.
      V6toV4
      Translates the source IP address and destination IP address of packets when an IPv6 host first initiates a connection to the IPv4 network.
      Source zone
      Source IP
      Destination IP
      Service
      Source address translation
      Translation method
      • Prefix translation—Uses IPv6 prefixes to translate the source IP addresses of packets.
      Source IP after NAT
      This option is available only when the translation method is Dynamic IP or Static IP.
      Port translation
      Prefix translation
      Select a prefix translation type:
      • General prefix—Uses the general prefix for source address translation.
      • IVI prefix—Uses the IVI prefix for source address translation.
      • NAT64 prefix—Uses the NAT64 prefix for source address translation.
      This option is available only when the translation method is Prefix translation.
      IPv6 prefix
      This option is available only when the prefix translation type is General prefix or NAT64 prefix.
      Prefix length
      Destination address translation
      Translation method
      • Prefix translation—Uses the IPv6 prefixes for destination address translation.
      • NAT server mapping—Translates the destination IP addresses and destination port numbers of packets to a fixed destination IP address and destination port number.
      • Static translation—Translates the destination IP addresses of packets to a fixed IP address.
      Prefix translation
      IPv6 prefix
      This option is available only when the prefix translation type is General prefix or IVI prefix.
      Prefix length
      This option is available only when the prefix translation type is General prefix.
      After you configure this feature, the master device in the IPv6 destination VRRP group uses the virtual IP address and virtual MAC address to reply packets. On a stateful failover network, you must configure this feature. Support for this feature varies by device.
      Port after NAT
      This option is available only when the translation method is NAT server mapping.
      General settings
      Name
      Name of the NAT64 rule, which supports Chinese characters.
      Rule status
      Whether to enable the NAT64 rule.
      Advanced settings
      Remarks for the NAT64 rule.
      VRF before NAT
      VRF after NAT
      Counting
      Enable the counting of times that the NAT64 rule is matched.
    5. Click Apply.
