This help contains the following topics:
Protocol Independent Multicast (PIM) provides IP multicast forwarding by leveraging unicast static routes or unicast routing tables generated by any unicast routing protocol. PIM uses the underlying unicast routing to generate a multicast routing table without relying on any particular unicast routing protocol.
Based on the implementation mechanism, PIM includes the following categories:
If you enable PIM-DM on an interface, the PIM-DM mode is used. If you enabled PIM-SM on an interface, the PIM mode on the interface varies by multicast group for which a multicast packet destines.
If the multicast group is in the SSM group range, the PIM-SSM mode is used.
If the multicast group is not in the SSM group range, the PIM-DM mode is used.
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
PIM provides IP multicast forwarding by leveraging unicast static routes or unicast routing tables generated by any unicast routing protocol. PIM uses the underlying unicast routing to generate a multicast routing table without relying on any particular unicast routing protocol.
To enable PIM:
Select
Select the public network or a specific VPN instance.
Figure-1 PIM page
Click
Figure-2 Selecting interfaces
Click
Select
Click
Figure-3 PIM page
Figure-4 Advanced settings page
Table-1 Advanced setting items
Item | Description |
SSM group range | When a PIM-SM enabled interface receives a multicast packet, it checks whether the multicast group address of the packet is in the SSM group range. If the multicast group address is in this range, the PIM mode for this packet is PIM-SSM. If the multicast group address is not in this range, the PIM mode is PIM-SM. |
Register checksum calculation | Select a checksum computing method for register messages. For information integrity of a register message, you can configure the device to calculate the checksum based on the entire register message. If a device cannot calculate the checksum based on the entire register message, you can configure the device to calculate the checksum based on the register message header. |
Click
