MLD
This help contains the following topics:
Introduction
Multicast Listener Discovery Protocol (MLD) establishes and maintains the IPv6 multicast group memberships between a Layer 3 multicast device and the hosts on the directly connected subnet.
MLD has the following versions:
After MLD is enabled on an interface, the interface can establish and maintain IPv6 multicast group memberships.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure MLD
Complete the following tasks before you configure this feature:
  1. Select Network > IP Multicast > MLD.
  2. Click Enable MLD on interfaces, and then enable MLD on the interfaces as needed.
    Figure-1 Clicking Enable MLD on interfaces
    Figure-2 Selecting interfaces
  3. Click Apply at the upper left corner of the page.
