Server load balancing session information
This help contains the following topics:
Introduction
Table-1 shows TCP connection information for Layer 7 server load balancing. You can click the icon on top of the list to select items to be displayed.
Table-1 LB session information
Item
Client-side client IP
Client-side client IP address used to establish TCP connections to the device.
Client-side client port
Client-side client port number used to establish TCP connections to the device.
Client-side server IP
Client-side server IP address used to establish TCP connections to the device.
Client-side server port
Client-side server port number used to establish TCP connections to the device.
Server-side client IP
Server-side client IP address used to establish TCP connections to the server.
Server-side client port
Server-side client port number used to establish TCP connections to the server.
Sever-side server IP
Server-side server IP address used to establish TCP connections to the server.
Sever-side server port
Server-side server port number used to establish TCP connections to the server.
Client-side connection state
State of a TCP connection between the client and the device:
  • CLOSED
  • LISTENING
  • SYN_SENT
  • SYN_RECEIVED
  • ESTABLISHED
  • CLOSE_WAIT
  • FIN_WAIT_1
  • CLOSING
  • LAST_ACK
  • FIN_WAIT_2
  • TIME_WAIT
Server-side connection state
State of a TCP connection between the device and the server:
  • CLOSED
  • LISTENING
  • SYN_SENT
  • SYN_RECEIVED
  • ESTABLISHED
  • CLOSE_WAIT
  • FIN_WAIT_1
  • CLOSING
  • LAST_ACK
  • FIN_WAIT_2
  • TIME_WAIT
Client-side VRF
VRF to which the client-side TCP connection belongs.
Server-side VRF
VRF to which the server-side TCP connection belongs.
Creation time
Time when the device started to establish the TCP connection.
Idle Time
Duration of the TCP connection being idle.
Idle TimeOut
Timeout time for the TCP connection being idle.
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
