This help contains the following topics:
Outbound link load balancing load balances traffic among the links from the internal network to the external network.
As shown in Figure-1, outbound link load balancing contains the following elements:
Figure-2 Relationship between the main configuration items
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Figure-3 shows the configuration procedure for outbound link load balancing.
Figure-3 Outbound link load balancing configuration procedure
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
(Optional.)
(Optional.)
(Optional.)
(Optional.)
(Optional.) Configure ALG on the
The ISP link selection configuration page fast generates outbound link load balancing configuration automatically by guiding you through the key configuration steps.
To perform ISP routing configuration:
Navigate to the
Configure ISP link selection settings.
Figure-4 Quick configuration for ISP link selection
Table-1 Quick ISP link selectionconfiguration items
Item | Description |
ISP name | Select an existing ISP or create a new ISP. |
Type | IP address type for outbound link load balancing. Options are IPv4 and IPv6. |
Next hop config method | Select a next hop configuration method:
Next hop IPv4 address | Specify an outbound next hop IPv4 address. The IPv4 address cannot be an IPv4 address of any interface on the device, loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X. |
Next hop IPv6 address | Specify an outbound next hop IPv6 address. The IPv6 address cannot be an IPv6 address of any interface on the device, loopback address, multicast address, link-local address, or all-zero address. |
Outgoing interface | Specify an outgoing interface for the link. The outgoing interface must be an interface whose IP address can be dynamically obtained. |
Click
An LB class classifies packets by comparing packets against specific rules. Matching packets are further processed by LB actions.
To configure a class:
Select
Click
Create a class.
Figure-5 Class settings
Table-2 Class configuration items
Class | Enter a name for the class, case insensitive. |
Match type | Select a match type:
Match rule | Configure a match rule. A class can contain a maximum of 65535 match rules.
Description | Enter a description for the class. |
Click
You can add links that contain similar functions to a link group to facilitate management. For example, you can create different link groups for different ISPs.
To configure a link group:
Select
Click
Create a link group.
Figure-6 Link group settings
Table-3 Link group configuration items
Link group name | Enter a name for the link group, case insensitive. |
Proximity | Enable or disable the proximity feature. Before enabling this function, you must configure proximity parameters from the |
Scheduling algorithm | Select a scheduling algorithm for the link group.
By default, the weighted round robin algorithm is used. |
Lower percentage | When the percentage of available links in a primary link group is smaller than the lower percentage value, the primary link group becomes unavailable, and the backup link group takes over. |
Upper percentage | When the percentage of available links in a primary link group is greater than the upper percentage value, the primary link group becomes available again to process services. The upper percentage value must be greater than or equal to the lower percentage value. |
Priority scheduling | Specify the upper limit and lower limit of links in a link group that can be scheduled. By default, all DNS servers with the highest priority in a link group are scheduled.
The link priority can be configured on the |
Probe method | Specify a probe template for the link group to detect the health and availability of its links. You can configure this parameter by using one of the following methods:
The parameter setting specific to a link takes precedence over the global setting. The probe result of a link affects the use of the corresponding link group member. The probe result of a link group member does not affect the use of the corresponding link. You can select an existing probe template or create a probe template. |
Success criteria | Specify the health monitoring success criteria for the link group.
Member list | You can add a link to a link group in one of the following ways: Create a link and add it to the link group.
Select an existing link.
NAT | Enable or disable NAT. In outbound link load balancing, NAT typically needs to be disabled. |
Fault processing method | Select a fault processing method:
By default, the fault processing method is |
Description | Enter a description for the link group. |
Click
A routing policy associates an LB class with an LB action to guide packet forwarding.
You can specify only one class in a routing policy. The device matches packets against routing policies in their configuration order. If a packet matches a class, the device takes the associated action on the packet. If a packet matches no class, the device takes the action associated with the system-defined class named
Select
On the
Figure-7 Common IPv4/IPv6 routing policy settings
Table-4 Common configuration items
LB service | Enable or disable load balancing. |
Link protection | Enable or disable link protection. If the traffic exceeds the bandwidth ratio of a link, the LB device distributes new traffic that does not match any sticky entries to other links. |
Session extension information synchronization | Enable or disable session extension information synchronization. |
Sticky entry synchronization | Enable or disable sticky entry synchronization. |
Sticky entry synchronization type | Select the sticky entry synchronization type:
This function is available only when sticky entry synchronization is enabled. |
Select
Click
Create an IPv4/IPv6 routing policy.
Figure-8 IPv4/IPv6 routing policy settings
Table-5 IPv4/IPv6 routing policy configuration items
Class | Select an existing class or create a class. |
Forwarding action | Select a forwarding action:
ToS | Enter the ToS field value in IP packets sent to the DNS server. IPv6 routing policies do not support this parameter. |
Primary link group | Select an existing link group or create a link group. When the primary link group is available (contains available links), the device forwards packets through the primary link group. When the primary link group is not available, the device forwards packets through the backup link group. |
Backup link group | Select an existing link group or create a link group. |
Sticky group | Select an existing sticky group or create a sticky group. Only address-port sticky groups are supported. |
Fallback action | Specify that the next rule is matched when a failure to find a link occurs. This parameter does not take effect on SIP virtual servers. |
Busy action | Specify that the next rule is matched when all links are busy. |
Insert before | Specify an existing routing policy before which the new policy is inserted. |
Click
