IPv6 multicast routing
This help contains the following topics:
Introduction
Only when IPv6 multicast routing is enabled, other IPv6 Layer 3 multicast features (such as MLD and IPv6 PIM) can take effect.
The following tables are involved in IPv6 multicast routing and forwarding:
vSystem support information
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
Configure IPv6 multicast routing
Complete the following tasks before you configure this feature:
  1. Select Network > IP Multicast > IPv6 Multicast Routing.
  2. Select the public network or a specific VPN instance.
    Figure-1 Enabling IPv6 multicast routing
  3. Click Enable.
