This help contains the following topics:
This feature limits the number of connections established per second to prevent DDoS attacks from degrading device performance.
The device supports the following types of connection rate limit:
Support of non-default vSystems for this feature depends on the device model. This feature is available on the Web interface only if it is supported.
You cannot configure both public network protection and private network protection on the same interface.
Figure-1 shows the configuration flow chart.
Figure-1 Configuration flow chart
Complete the following tasks before you configure this feature:
Assign IP addresses to interfaces on the
Configure routes on the
Create security zones on the
Add interfaces to security zones. You can add interfaces to a security zone on the
Configure security policies to permit the target traffic on the
You can configure connection rate limits for both public and private network protection. Public network protection is achieved by limiting connections from the public network to the private network, and private network protection is achieved by limiting connections from the private network to the public network.
To configure connection rate limits
Select
Select public or private network protection, and configure the following parameters:
Figure-2 Public network protection
Figure-3 Private network protection
Table-1 Configuration items
Item | Description |
IP type | Select an IP type. Options include IPv4 and IPv6. |
Protection action | Select a protection action.
Interfaces | Select interfaces to apply the rate limit. |
Per-IP Connection Rate Threshold | Enter a connection rate limit. |
Click
